Question about Soyo Dymond DYLT032A Television
Vertical red/green lines
I just purchased this 32" TV at a charity event. It was new in the box. The picture is not clear or sharp. And it has the vertical read/green lines from edge to edge. I have determined it is internal to the TV by adding and removing various devices. Its not the cable input as the same thing occurs on a DVD input. Not difference between standard RGB inputs or coaxial cable. Have not tried HDMI or S-video cable. On a default blank screen, I get the blue screen with vertical white lines.
Any thoughts?
  • DaveinFL Feb 21, 2008
    This is a very good suggestion and actually I had already tried this approach,. Unfortunately, the digital board costs $250. The factory wouldn't reduce the price. Thanks for trying to help.
  • 280 Answers
This set has a bad digital board.and or signal board
The company is in California and is a china inport.
Digital and signal board could cost $130+
Posted on Feb 21, 2008
LCD display problem
Are you sure the cable is properly seated? You will typically get a tint of red green or blue when a particular pin on the cable isn't making contact. The lines on the other hand would indicate a bad display. Best advice would be to check the cable and if its all the way in hen replace the monitor. They are not worth repairing and also dangerous to work on.
Nov 24, 2013 | Sharp LC 37A63M 37" LCD Flat Multisystem...
Green and purple horizontal lines
You will most likely need what is called a scan converter/scaler. It will convert your source signal to the desired signal for you. You can find these online.
Nov 21, 2012 | Mitsubishi Televison & Video
Sharp 32" lcd tv vertical lines on screen
sounds like you have receiver connection problem..
To test it try to play dvd on your TV..if the picture is fine your TV is good..your problem is on the cable box or receiver..
Nov 06, 2012 | Sharp LC-32AV22U 32 in. LCD TV
Acer lcd tv screen goes fluro green, only on some pixels not entire picture but rest of screen is not a very clear picture.
my acer lcd 32" tv just recently went of the blink. It has vertical, horizontal lines and fluro green screen. please need some advice...
Dec 30, 2009 | Acer AL1716WAB LCD Monitor
My Sharp tv has vertical multicolored lines that
my new lc60le820un sharp is doing the same thing after two weeks. i called sharp they want to fix it. i want a new tv. after a few minutes of this i hung up and and called hh greg to replace it with a sony. thanks hh greg the sony is fine
Nov 26, 2009 | Sylvania 32 in. Diagonal LCD HDTV
White Horizontal Lines @ the top of my 32" Sharp Black Box TV
This Problem is usually caused by Leaky Capacitors in Vertical deflection circuit.
If you are handy with electronics,
Get a can of FREEZE Aerosol.
Open the Back Cover.
Put a mirror in front of TV.
Locate the Vertical Circuit.
Turn the TV on.
Spray FREEZE on top of individual Capacitor to see if it corrects the problem.
If it does, Replace that Capacitor.
Feb 06, 2009 | Sharp 32C-240 32" TV
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Green vertical lines
Possibly needs a new control circuit board or lcd panel
Jun 20, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos LC-37D4ou
What kind of connections are you using?
If component (red, green, blue) double check to make sure they are seated properly. I'm thinking it sounds like the blue one got loose.
Mar 27, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Soyo Dymond DYLT032A Television Logo
227 people viewed this question
Top Soyo Televison & Video Experts
ted dux
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
