Question about Poulan Pro " Pro" Self Propelled Mower
Electric Starter Battery is charged, will not start w ey, Is there a fuse?
No power. Put in new fuse by battery and started right up. sat for a week and wont start again. Battery is fully charged. tried another new fuse
Hi, Traci and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Security alarm needs a reset.
6. Starter control circuit, relay, or solenoid faulty.
7. Faulty starter button.
8. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
Good luck and have nice a day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 03, 2016 | Motorcycles
When i turn on the ignition, nothing happens
If it was the battery or a fuse it would just click, but if it doesn't click then the starter relay may be bad. Could be a wire in the switch also.
Jan 27, 2015 | Honda Mmd 5000 Watt Electric Start...
2006 jeep liberty turn switch on and have power.starter and battery gd but wont turn over wont even click
the tests are all easy,
check fuses first, on all electric fails, starter ,charge and EFI are all electric systems.
super easy.
  1. jumper cable cranked with donor running car work?
  2. yes, battery is dead, or only discharged, charge it work?
  3. yes jumps but charge fails, bingo battery toast.
  4. so the jumper fails. in #1 , all that is a bad starting system. (not a part, the system)
  5. clean battery lugs. check fuses, and then hot wire the starter solenoid lug (dinky lug ,not huge one) (in park and wheels chocked keys off)
  6. ok that fails the starter is bad.
  7. ok that works. so the KEY line is dead. try starting in neutral yet?> bingo works, bad PRNDL switch on tranny side.
  8. the KEY line can be interrupted with some alarms, on a jeep it has Immobilizer that cuts fuel not cranking. so.... PRNDL switch bad or the key switch is self .
  9. Using any voltmeter to do the checks is a WIN. 12.6vdc is a charged battery is yours 12.6v rested/???????????
Sep 17, 2014 | 2006 Jeep Liberty
2006 Honda CRF 150 will not turn over
Hi, Anonymous before testing any electrical component in the Starting Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter motor or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. Faulty ignition relay.
14. The electric starter is working but starter clutch has failed.
15. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
CRF150F Electric Start Not Working Help Please
06 crf150 electric starter problem
CRF150F service manual repair 2003 2013 CRF150 Download Manuals Technical $15
https://www.partsfish.com/page/oem-parts-for-honda
Honda CRF150F Owner Manual
Jun 25, 2012 | 2006 Honda CRF 150 F
Where are the fuses in 2005 fatboy
Fuses are located under the seat, in back of the battery, between the battery and the ECM connector. They are under a removable plastic cover. Try charging the battery to get rid of the clicking. Sounds like you may have enough juice to activate the starter solenoid, but not enough to crank the starter.
May 02, 2012 | 2005 Harley Davidson FLSTF - FLSTFI Fat...
Nissan Altama Starter Relay electrical problems or a fuse?
Or the battery cables ! Do you know how to use a voltmeter ?
Starter Voltage Drop
Do you know how to do basic automotive electrical testing ?
How to voltage drop test starter motor circuit
Electric Testing Techniques You Need to Know Here is a place to view wiring diagrams ! http://www.bbbind.com/free_tsb.html
Apr 08, 2017 | 2004 Nissan Altima
Trouble shooting electric start toro 20074
Check battery connections, make sure they are clean and TIGHT!
Check the harness where it plugs into the starter switch
Check the harness where it plugs into the battery wire harness
Check the cable at the starter, make sure it is clean and TIGHT
If you need it, you can go to toro.com and enter your model number and download both the Owner's manual and a parts manual if that helps you any
Sep 27, 2009 | Garden
Turn the key for electric start,nothing happens
If you never used the starter,You need to have it checked, possible that it i froze up. Or brushes in starter arn't making contact. Also check connections. Good Luck
May 19, 2009 | Toro Lawn Mower With Toro Power Tools
Craftsman 19.5 briggs & stratton mower new battery, new solenoid new brushes on starter. fuse & wiring good shape. when i attemp to start ignition all it does is click.
Check the voltage on the battery to see if it is 12 volts or higher. If not, charge battery.
Then check all starting-related electrical connections-- sounds like there is a dirty connection somewhere if the battery is charged.
May 03, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Poulan Pro " Pro" Self Propelled Mower Logo
26 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
