Question about Canon PowerShot S230 / IXUS 179 Digital Camera
NO IMAGE ON THE DISPLAY, HOW DO I CHANGE BACK FROM THE LENS TO TH
ALL OF A SUDDEN THERE IS NO IMAGE ON THE DISPLAY, JUST THE BOX IN THE SMALL LENS ON THE CAMERA. WON'T TAKE A PICTURE. I HAVE CHARGED THE BATTERY PACK AND HAVE A NEW CF CARD IN THE CAMERA.
  • Canon Master
  • 4,738 Answers
Do you really mean won't take a picture, or are the pictures that it's taking black like the LCD screen? Download some of the pictures to your computer and check. If the camera's taking black pictures, see the following two links:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Posted on Jun 23, 2009
I am using a Fujifilm FinePix JX250 digital camera. Not the best I know to photograph jewelry but cannot afford a different camera now. After I've taken the picture I open it in IPhoto. I make...
The following will help to get the best possible pictures from your Fujifilm FinePix JX250:
TO CHANGE FILE SIZE:
  1. Press MENU/OK to display the shooting menu.
  2. Press the Selector UP or DOWN to highlight the option IMAGE SIZE and press the selector RIGHT to change IMAGE SIZE to 14M. This setting has a image resolution of 4,288x3,216.
  3. Press MENU/OK to select the highlighted option.
  4. Press DISP/BACK to exit from the menu.
TO CHANGE QUALITY:
  2. Press the Selector UP or DOWN to highlight the option IMAGE QUALITY and press the selector RIGHT to change IMAGE QUALITY to FINE (Less compression than NORMAL, meaning better picture quality).
NOTE: The focus range of the JX250 goes from 1.5 ft. - Infinity (Wide Angle), 2.6 ft. - Infinity (Telephoto), also make sure to clean the lens and adjust the focus before taking the photos. If the subject is close to the camera, select Macro mode. If the subject is far away from the camera, cancel Macro mode.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
May 28, 2011 | Cameras
All of a sudden every picture I take with the 55-200 zoom lens is blurry and slightly out of focus. Pictures with the 18-55 lens are still sharp. I have been using that 55-200 lens for years for sports...
Simplest answer is that you may have accidentally flipped the focus switch (A/M) on the lens to M. This turns off autofocus for that lens (which you might need to do if autofocus just can't resolve the image). Try turning it back to A.
Another possibility is that you're using an autofocus target different from the one you're expecting. The problem would be apparent regardless of lens choice, by being in focus in a different part of the image. You can press the arrow keys (while holding shutter release down halfway) to change AF targets, or change a menu setting to simply choose the closest target.
The shooting modes have no effect on focusing ability.
The camera would likely detect other focus-related problems (like servo failure).
May 09, 2011 | Nikon D40x Digital Camera
Camera won't show the image on the screen when taking the pictures. I have to use the small view finder to take photos. No image on the display until the photo is taken. How do you sqitch it back to the...
You don't. The D40 works as SLRs have worked for half a century. Only more recent dSLRs (Nikon started with the D3 and D300) have the LiveView capability that lets you handle your dSLR as a point&shoot.
Jun 11, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
How do you change out an LCD display lens on a Fuji S1000 fd. My 2 yr old threw the camera and LCD display cracked.
if you already have the display take all the screws out of th side and bottom of camera pull the back off and unscrew the display holder try not to touch the chips on the board
Oct 18, 2009 | Fuji FinePix Z10fd Digital Camera
Th-l1 no back lit screen
Although not fully familiar with your unit, many receivers have a small lamp behind the display panel. Sometimes they burn. It is not to easy to replace them bya DIY. If the unit works fine otherwise, it could be just that. lots of other units use Fluorescent type displays, and if they go bad, causes are more complex.
Good luck.
Oct 06, 2009 | JVC TH-L1 Theater System
Lens problem
you should have dropped your cam down to the floor or you should have forcibly tried to put your lens inside when the servomotor lens tried to bring the lens out..take your camera to the nearest service centre..you should not try to open the cam since the parts used in it are very small and even a slight modification might be responsible for huge change in the calibration.so my best advice is to take it to the nearest service centre available..
May 26, 2009 | Canon Powershot A1000IS 10MP Digital...
My nikon d60 is starting to take forever to show the picture after taking the photo, and now all the sudden is shows a black box with shooting details on it, i can't get that off!
In your manual you will find how to change the display format (picture only, histogram, etc.). The time it's taking to display your image "might" be that your memory card is getting quite full and you're shooting large images. I shoot a D80 and it uses an SD card. Make sure you but a fast memory card if your camera does not buffer the inage before writing it to your memory card.
Apr 23, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Color change-blue people
If you have cable or dish box check your HDMI rgb cables on set and digital box
Apr 29, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Canon Powershot A75 blurred LCD display
It sounds like the focus element in your lens is not functioning properly. Does the lens retract completely when you turn off the camera? When you push the button does the camera attempt to focus the image? If you do not see any change in the image when you push the button, and do not hear any sound - then your focus motor is either jammed or malfunctioning. David Millier Advance Camera Repair
Feb 13, 2007 | Canon PowerShot A75 Digital Camera
Canon PowerShot S230 / IXUS 179 Digital Camera Logo
185 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
