Question about Cosco Juvenile Cosco Sway n Play Swing Zambia
Turning off cosco sway and play
How do you turn off cosco swway and play
Cosco swing and play music plays but does not swing
Take it back they will replace it for you for up to 2 years.
Apr 25, 2014 | Cosco Juvenile Cosco Sway n Play Swing...
THE LEG AND COTTER PIN CAME APART FROM THE CENTER SPROCKET
From Paul182 himself: I FIXED THIS MYSELF. i HAD TO HOT GLUE THE PINS INTO THE TUBES, AND UNSCREW THE BOTTOM PLATE, THEN TURN THE TUBES 90 DEGREES PUSH DOWN INTO THE SLOT AND ROTATE BACK 90 DEGREES. NOT EASY BUT IT WORKS. THEN SCREW THE PLATE BACK ON.
Apr 14, 2014 | Cosco Juvenile Cosco Funsport Playard
I AM USING SOMEONE ELSE'S SWAY & PLAY. HOW DO I CHANGE THE BATTERIES AND WHAT SIZE ARE THEY?
tools needed : 1 Phillips head screw driver, 4 d cell batteries.
as you look at the swing, from the front, you will see a mobile set into the side of the leg on the RIGHT side.
it's the leg with the on off switch.
insert the screwdriver through the hole in the mobile and into the screw inset at the top of the leg. You will see that it's at the top of a rectangular door..this is the battery door.
unscrew the 1 screw and remove the door. the mobile will come off as it's attached to that door. change the batteries and put the door back on and re-install the screw.
hope this helps!
Aug 02, 2013 | Cosco Juvenile Cosco Sway n Play Swing...
How to fold down the cosco funsport play yard.
There is usually buttons under the cover in the middle of each side? Squeeze this and the side should collapse, then usually a pull up in the middle which reduces the cot right down. Hope it helps
Apr 16, 2012 | Cosco Juvenile Cosco Funsport Playard
I can't figure out how to switch from position 1 to position 2.
U have to grab the bar and like pull out and move it back and forth between positions. If your sitting in front of the swing(chid facing you) grab bar and pull away from you and move seat. Might have to hold the little side thing that says one and two to keep it still.
Mar 31, 2012 | Cosco Juvenile Cosco Sway n Play Swing...
Cosco booster seat (Summit)
turn the seat so you are looking at the bottom, insert the strap- one end on each side- turn the seat in an upright possition facing you, put the buckle pieces on appropriate side, attatch the center piece- at the chest- insert the strap into the appropriate slot- the adjustments- now turn the seat so you are looking at the rear of it, attatch the metal retainer.
Nov 25, 2008 | Cosco High Back Booster 22-200 /22-207
Cosco Juvenile Cosco Sway n Play Swing Zambia Logo
150 people viewed this question
Top Cosco Juvenile Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Cosco Juvenile Baby Gear Expert? Answer questions, earn points and help others
