Question about Kenmore Washing Machines
How many gallons of water load (not rinse) into my Kenmore M#110.92480200 with the water level set on Low? Set on Med? Set on High? Thanks
Low=11.9 gal
Med=16.7 gal
high=21.7 gal
according to the fine manual
Posted on Aug 16, 2009
How to control water levels in Maytag TOP LOAD WASHER, model #MAV 6000 AWW
What is the problem?
Water level is automatically controlled based on what you set it to low, med, or high.
Jul 14, 2017 | Maytag Washing Machines
Low level of rinse water. What can I do?
Possible that the water level sensor has failed and so it does not load to the level set by the program. You will need to check the level sensor to clear the water line of air block or dirt or faulty unit.Try to set a higher water level to the program settings and see if the water fills up on rinse, choose an different program
Mar 14, 2012 | Washing Machines
I am trying to clean earthen pottery plates in my dish washer and after washing half of the plates disappear.
The Kenmore PRO also has an Ultra Wash Filtration High Energy Filtration System that helps the majority of us with hard water. It features 2 spray arms, and a Turbozone that blasts away the most gunked up items you can make a mess on.
The Kenmore PRO also features 6 cycles. The High Energy Smart Wash Cycle is the most advanced and versatile. It actually senses the load size, soil amount, toughness of soil and uses minimal water and energy. The Smart Wash Cycle runs from 110 minutes to a max of 194 depending on toughness of soil and uses from 4.2 gallons of water to 6.9.
The Pots Pans Cycle also makes some adjustments depending on soil level and takes from 140 minutes to 203 minutes to complete. It uses 4.8 to 6.9 gallons of water.
There is also a self-adjusting Normal Cycle that runs from 110 minutes to 193 minutes and uses 4.2 gallons to 6.9 gallons of water.
The Kenmore PRO also has a self-adjusting China Gentle Cycle that provides a light wash and gentle dry for delicate items and runs from 105 minutes to 194 minutes and uses 4.2 gallons to 6.9 gallons of water.
It also has a 1 Hour Wash that runs for 58 minutes and uses 8.0 gallons of water and a 15 minute Quick Rinse Cycle that uses 2.1 galllons of water.
The Kenmore PRO also has 5 other options that are additional to the Cycles. Each option adds time and water to the selected cycle. They are:
TurboZone, HI Temp Wash which raises the water temperature to 120 degrees F, a Steam Sanitize which raises the final rinse to 155 degrees F, a Top-Rack Only Option, and a Heated Dry Option.
The Kenmore PRO also has a Delay Option that allows you to run the dishwasher on off-peak hours and delays the start time up to 6 hours.
I have not field-tested all these options yet, becaue I am such a skeptic -- and picky about my dishes, I usually go ahead and always use the TurboZone, the Hi-Temp Wash, the Steam Sanitizer, and the Heated Dry Option. But, hey if you are plunking down $1500 for a dishwasher--you should make use of all your options. I'll keep this review up-to-date as my dates with the Kenmore PRO progress with dinner parties and my very precious china, but for now (mostly because of the "ClangBanger") our good china is safely stored in the cabinets.
Aug 16, 2011 | Kenmore PRO 24 in BuiltIn Dishwasher with...
How do I ajust water level for more water for wm2240cw hardly adds water
water level is automatically set and adjusted for volume and type of clothing. (at a low level, below the bottom of the door) If you select a delicate cycle, the water level will be slighly higher. These water levels are all that is required to clean in these machines. Take that into account when adding your laundry detergent. Old top load machines used 40 or more gallons per cycle. Your machine uses about 13 gallons, so you should only be using 1 to 2 tablespoons of HE laundry detergent per load. (only 1 teaspoon of fabric softner if you use it)
Mar 05, 2011 | LG Washing Machines
Is there a water level setting control for the washer or does it automatically detect and control that? I wondered if the control that has the options high/med/low/hang dry/no spin(lights are on or off...
Water level is determined automatically by the load in the machine. A pressure switch senses the water level after the clothes soak up all they can and just enough more is added. The settings as you suspect are for the spin speed.
Eric
Sep 22, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Can't see water leverage
water level needs to be brought up alittle on your amount of level as in small med large loads...
Jun 09, 2009 | GE Energy Star WCVH6260F Front Load Washer
Lg wm2277h has low water level
The water level is very low on front load machines. (Below the bottom of the door) While the washer is running, push and hold the "spin speed" and "soil level" buttons at the time. Display should be between 230 and 255.(normal) If you do this while the machine is filling, you will see the numbers change. This machine only uses about 12 gallons of water for an entire cycle, vs. about 45 for some top loading machines. THIS IS NORMAL ! The machine will adjust the amount of water based on the type and volume of clothes in your washer. On a large load, you will see wet clothes, but no water sloshing around. PS. Because the machine uses so little water, make sure you use only one tablespoon of HE detergent (and only one teaspoon of fabric softner if you use it). This is very important.
If this info was helpful, please rate it as a "FixYa". Thanks.
Oct 01, 2008 | LG WM-2277HW Front Load Washer
Kenmore 70 Series heavy duty washing machine
Kenmore
remove edge decore trims from left and right side front of control panel
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on righ/underside of water level control body where it touches metal mount plate
rotate water level control body 90deg anticolckwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Mar 01, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
144 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
