Question about Canon ImageCLASS D1120 All-In-One Laser Printer
How to remove fuser unit in canon d1120? - Canon ImageCLASS D1120 All-In-One Laser Printer
3 Suggested Answers
  • 148 Answers
SOURCE: How to remove the scanner unit on Canon PC1060
you sould not have to remove the scanner unit to clear a jam in the fuser
open all doors and remove anything marked green
remove the the cartridge assembly if it will come out
open the fuser section (usually a release that takes pressure off of the fuser rollers
remove the paper feed cartridge
you now should be able to follow the paper feed path from the time paper goes i until it comes out
if you are not sure of path take a piece of card stock and simulate it goig through feed ara
there are small microswitches/ poto eyes that sense paper lok for an small pieces also clean thes poto eyes with q tip and rubbign alcohol
reassemble
unlug from the wall then plug back in and turn on p roblem sould be solved
Posted on Jan 05, 2009
  • 990 Answers
SOURCE: remove a paper jam under the fuser unit on a canon
Hello sir; I believe You have to detacth finisher unit then open the side door to reach the fusing unit see is there have jamming paper over there ,the paper under the fusing unit just open front door turn the knob clockwise on the fusing unit paper will coming out.
Posted on Aug 18, 2009
The device will not copy or scan. The display says check document but there isn't a document in the device
Try to reset the machine by unplugging the computer cable in the back of the D1120, wait about 30 seconds and plug in again. Should reset the system.
Sometimes when it keep saying jam, I remove the toner cartridge and then put back in. That works also to reset the system.
This is really a great machine with it's little querks, but for the most part, we get along pretty well..... hope this helps. :-)
Leslie
May 19, 2014 | Canon ImageCLASS D1120 All-In-One Laser...
How to replace the fuser unit in canon ir3300
open the left door see in fuser unit remov the 2 screw &3connecter
nd replace the unit
Feb 03, 2013 | Canon Office Equipment & Supplies
Canon 1180 error code E005 200
Nov 26, 2012 | Canon CLC 1180 Copier
I have a Canon D1120 and it says Check Document. There is no document in the feeder, no paper jams I can see... Any help? I tried turning it off and on, but got nothing
try to disconnect the feeder form the main unit and if still there is check document error then brother it is related to firmware(software)as i have encountered such in 3 machine before also but they were without feeder. so first disconnect the feeder connector from main unit .
Aug 18, 2011 | Canon imageCLASS D1120 Copier
Canon imageclass D1120 printer says: feeder paper jam,
Hi Try this method
To "Settings/Registration Table"
You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
  1. Press b_in_add.gif(Settings/Registration) ? [Function Settings] ? [Common] ? [Scan Settings] ? [Feeder Jam Recovery Method].
  1. Select [From 1st Page] or [From Stopped Original] ? press [OK].
Details of each item are shown below.
[From 1st Page]: If a paper jam occurs in the feeder, scanning starts again from the first page of the document. [From Stopped Original]: If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
Jun 10, 2011 | Canon ImageCLASS D1120 All-In-One Laser...
D1120 IMAGE CLASS CONTINUOUS PAPER JAMS ALTHOUGH NO PAER ACTUALLY JAMMED. APPEARS THAT PAPPER IN PAPER TRAY IS NOT FEEDING OR CATCHING UP TO BE COPIED.
first of all try to clean trays picked up rollers and also look for a piece op paper or something else in internal paper path
pifonski
Feb 20, 2011 | Canon imageCLASS D1120 Copier
I have a canon laser class 9500, i am unable take fuser
Hello sir ; The user manual you get it online, instrction to remove the fusing unit quit simple, open back door ( sometime require to remove back panel ) you may findout two blue knob release it and may be aalso need to removed two screw pull out this unit half way the unpug the connecter , whole unit coming out.
Aug 18, 2009 | Canon Office Equipment & Supplies
Canon ImageCLASS D1120 All-In-One Laser Printer Logo
63 people viewed this question
old marine
old marine
