Question about Whirlpool Washing Machines
Whirlpool w10254493a FO2 code
What is this code and how do I fix it
Error code F01 E02
For how long did you unplug the power cord? If it was under 5 minutes, unplug it for longer. Check if that clears the error code. If it doesn't, the motor control unit needs to be replaced.
Please double check your model number to get the correct part. Most of the Whirlpool washers have model numbers that start with 3 letters.
I hope this helps.
Dec 20, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool fo2 code
You may just have some coins clogging the pump. Better take it out side to take pump off. But is is easy.
Jan 02, 2013 | Whirlpool Duet GHW9150P Front Load Washer
How can fix f 02
whirlpool duet f02 codeHow to fix fo2 fault code on a whirlpool duet front load washing machine, The whirlpool duet is one of the machines that have a main computer control that operate and monitor the functions of the machine,
This control is usually mounted behind the front panel,sometimes at the back or to the side, it also has a speed control board that is mounted on the bottom usually at the right side.
Whenever a problem accur there is a fault code displayed on the machine, there is a technician sheet with the fault codes on the machine, the technician can use this guide to go directly to the problem,
This f02 code mean there is a problem with the drain, there is a drain filter that sometimes get clogged with lint and other things,
Removing the kick plate and removing the drain access on the pump will reveal the drain filter, use a small bucket, and towels to catch the water that will be in the pump
Nov 26, 2012 | Whirlpool duet Washing Machines
Won't drain error code fo2
There is something stuck in your drain pump
Jan 14, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Flashing a code fo2
clean your pump
take the bottom panel off
untwist the filter
make sure you have lots of towels to clean the water thats going to come out.
this should solve your f02
Dec 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fo2 on screen
your pump is jammed clean or, replace
Aug 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Drain
kathy..theres three screws at the bottom panel...remove them,,always unplug first...and you will see your pump claen your filter,,ok onthejob,,just screw it out
Jan 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
FO2 code?
It was my wall plug that was the problem, used an extention and my machine fine now, Thanx
Jun 20, 2008 | Washing Machines
Suds then F02 over and over and over again
Most likely (it happened to many owners), you get the FO2 code, because some small items like socks got sucked into drain system.
Dec 15, 2007 | Whirlpool GHW9200L Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
