Question about Trust Computers & Internet
What does a rhyperior fake card look like? - Trust Computers & Internet
Not reading in computer and camera
It's probably a fake one. I had the same problem; I bought a 16GB one for few bucks from an online store, but it was fake so I faced the same problem.
Read this guide to determine if your memory stick is fake or not: http://reviews.ebay.co.uk/FAKE-Sony-Memory-Stick-Pro-Duo-MagicGate-Cards-Exposed_W0QQugidZ10000000001535763
If it's not fake, then there might be a problem with your memory stick. Try replacing it with a new one if possible.
Hope this helped.
Dec 31, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
Which 3 pokemon are the best to defeat tower tycoon palmer
In my opinion, a great pokemon to face Palmer with is Vaporeon. Make sure it knows a good water move, Ice Beam, and Aqua Ring. Dragonite will fall to Ice Beam, Rhyperior will fall to a water move, and Milotic will use up all its move in a futile attempt to take out Vaporeon. Make sure to have a Leftovers attached to Vaporeon.
A good secondary would be Starmie. Starmie is fast, powerful, and knows a good variety of moves. For Rhyperior, use Surf. Dragonite, Ice Beam. Milotic, two Thunderbolts should do the trick.
The third choice can be based on user preference. Make sure it is high in Special Attack (Rhyperior is high in Physical Defense). Good Luck!
Jul 10, 2010 | Nintendo DS Lite
How to fix fake memory stick
you can't fix a fake memory card. i've bought several fake memory cards before not knowing they were fake but overall they are worth it. at the time the 8gigs were going for $85 - $140 where as the fakes were like $45. and so far only difference i see is that the real one would register 7.8 gigs of free space where as the fake would only register 7.5 or so.... some people say it access the data slower but its in miliseconds not enough to really matter. but going back to your question... can't fix a fake unless u mean reformatting. just don't buy a fake
Apr 29, 2010 | Sony Memory Stick Pro Duo For PlayStation...
R4i Card not reading as card inserted in game slot of DSi
Try and verify whether or not your R4 or R4i card was original by visiting R4DSRevolution.co.uk, they have a few guides to teach you how to test between real and fake cards.
As for the iEDGE, I would highly recommend it but be careful of some fakes, there are indistinguishable fakes out on the market that you may want to watch out for. Check out this link to understand how to tell the difference:
http://www.nintendodsicards.co.uk/fake-iedge-cards
If you're in the US I'd recommend trying DSCardWorld for your DS cards since a friend shopped there and said they were both genuine and good. I'm in London UK so I use NDS-Gear.co.uk, they're pretty much recognised as being the best around here.
Apr 21, 2010 | Nintendo DSi Black Console
I ordered a ttds and it doesn't look fake but says menu.
You should be able to download the correct software for your DSTT off the official www.ndstt.com website. If it doesn't work still then I'm afraid you might have a fake card.
If you suspect that you have unstable fake clone version you can get a genuine DSTT card here http://www.dscardworld.com I managed to find this site after I got burned at a few others. Loved having my emails responded to because I had loads of questions, and they were quick to ship it. They test each card before sending them. US based support and shipping I believe.
Sep 17, 2009 | Nintendo DS Lite Console
Edge Ds card stuck on booting?
This could be a problem with your EDGE DS software. Check you have the right software by visiting the official EDGE DS website at edge-ds.cn (NOT edgei-ds.cn, this is a FAKE site).
If you want info for now to tell the difference between a real and fake iEDGE, just in case, check out:
Tell a Fake iEDGE
Fake iEDGE different packaging
If you're looking to buy an iEDGE card...
If you're EU/UK - Buy iEDGE from NDS-Gear
If you're US/Canada - Buy iEDGE from DSCardWorld
Aug 04, 2009 | Nintendo Revolution Console
I have a ds lite with a micro ds card in it. when i turn it on it say's edge.dat tidak menemukan. does this mean the card is blank?
The software is missing that is needed on the micro sd card for the DS lite to read it.
Not all micro sd cards are suitable or work with the DS system's check the compatability of the card at the nintendo troubleshooting site. (google: nintendo official ds lite help guide)
Jun 09, 2009 | Nintendo DS Lite
Memory Card reads full when empty ? Pentax kd 200
Ok, first you mak have a fake card. The capacity of the card is coded into the card and fake cards often lie about their capacity.
If you know the card is not fake, then reformatting the card should clear it. You can do this in the camera. (Check the manual for instructions.) Or if you have an SD card reader that plugs into the USB port of your PC, you can download a SD card formatter for free. (The official SD card standard site has these.)
Dec 24, 2008 | Pentax K100D Digital Camera
Camera warning " this memory card may not be able to record or playback images correctly
This is maybe a Solution but I have the same problem. I have done some research on this and the memory card may be a fake. On the back of the memory card there is some serial code or something. The first like (if it is not fake) will have at lease one S that is kinda sideways for lopsided. Fake ones are not like that.
Jul 09, 2008 | Sony 4GB Memory Stick PRO Duo Memory Card
Computers & Internet Logo
Top Trust Computers & Internet Experts
micky dee
Computer Links
Josh Whitehead
Josh Whitehead
Are you a Trust Computer and Internet Expert? Answer questions, earn points and help others
