Question about Poulan Pro 14" Gas Chainsaw 33CC P3314
How to adjust bar oil for Poulan 3314 - Poulan Pro 14" Gas Chainsaw 33CC P3314
  • 44 Answers
SOURCE: Bar sprocket smokes, gets hot spot
Sounds like you're not getting enough oil to the chain. Basically you've got an oil pump, pickup and filter involved in getting oil from the resovior to the chain/bar. If you cleaned the obvious area and the chain is not coated with oil, you may have a clog further up (inside) the oil delivery mechanisms. Also, drain the oil from the tank, and see if you can "blow" air through there. With the saw running & pointed down, you should be able to see oil on the ground being slung off the chain, if not, you are not getting enough oil to the chain.
Posted on Nov 29, 2008
  • 97 Answers
SOURCE: how do i remove or change the clutch on my Poulan
Remove cover,chain,& bar. Hold crank and turn clutch counter clockwise to remove.Replace in reverse order.
Posted on Mar 14, 2009
  • 132 Answers
SOURCE: poulan 14
Use actual bar oil sold for that purpose. It's thicker and won't run out like water. Synthetic oil is very thin does not have the proper density.
Posted on Jun 27, 2009
  • 583 Answers
SOURCE: I have a poulan pro 260 42cc chainsaw (2001 or so)
oil pump itself is probabley clogged or u.s youdoit
Posted on Jul 26, 2009
dontbother10
  • 2220 Answers
SOURCE: Trigger on poulan 3314 does not control speed.
Turn the "T" needle valve CCW a little (1/8 turn) blip throttle, no better, CW 1/4 turn, blip throttle. The "T" is below the other 2 needle valve adjustments. A saw running lean (air leak in intake somewhere) also runs fast. To lean destroys the saw. Post back (below) with results.
Lou
Posted on Feb 24, 2010
Chainsaw won't idle- runs fast only
Gently Tighten the carb adjustment screw fully tight then adjust it out 360 (full turn) then again a further 180 ( half a turn) and your idle speed should be set correctly. Let me know how you get on
Oct 02, 2014 | Oregon Poulan/Poulan Pro 10" Chain Saw...
Troubleshooting chainsaw
Sadly, the 3816 is not designed for larger timber. 38cc is only for smaller limbs, As a general rule also the largest timber to cut should only be 2/3 of the length of the bar
Jul 27, 2014 | Poulan/Pro 3314 3416 3816 3818 40184218...
On the poulan 42cc chainsw how do i adjust the flow of bar oil
To adjust the automatic oil flow, Turn the chainsaw upside down. Turn the screw marked with a "+" or "-" toward the "+" sign. If too much oil is present turn the screw toward the "-" sign. Repeat the oil test and adjust as necessary.
Read more : http://www.ehow.com/how_7767305_adjust-bar-chain-oil-flow.html
Jul 01, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 3816, back fires through carburator, wont start.
water in the gas or carb needs to be removed and taken apart and cleaned
Feb 20, 2014 | Poulan/Pro 3314 3416 3816 3818 40184218...
Poulan Wild Thing bar oiler adjustment
there is no adjustment for the oil flow i find the screws that hold the pump on loosen up and then leak oil
Jun 09, 2012 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What is the oil to gas ratio on Poulan 3314
Poulan and Poulan Pro chainsaws with 2-cycle engines require a 40:1 gas-to-oil ratio, which corresponds to 3.2 ounces of oil per gallon of gasoline.
Jun 15, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
How do I tighten the chain? 14 poulan 3314 or something likw that...thanks!
I dont want to be that guy that just links everyone to the answer, but in this case its easier for you to watch Vs me attempt to tell you correctly! Your should be very similar to adjust!
http://www.ehow.com/video_4419325_tighten-chain-chainsaw.html
Best Wishes and Good luck!
Apr 10, 2011 | Poulan 14" Chainsaw
Oiler on saw not pushing oil as fast as gas is there an ajustment screw or is it automatic and just needs to be cleaned
Your Operator's Manual does not address any oiler adjustment; an IPL for for your saw lists no oil adjustment screw.
Operator’s Manual
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2006/NOUS2006-PP4620AVX-952802146.pdf
IPL
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2009/NIUS2009-PP4620AV-545014314-952802075.pdf
Given the above I would conclude your saw has no operator adjustable oiler. If you think oil output is inadequate contact Poulan here:
Poulan.com
The dash number of your serial number is the type.
http://www.poulanpro.com/node4033.aspx or phone them
Handheld (Chainsaws, Trimmers, Blowers, Edgers)
1 (800) 554-6723 (Please have your saw within easy reach)
HTH
Lou
A shorter bar will oil better. with no adjuster I recommend you not go longer. If the bar is getting hot make Poulan repair it under warranty!!!
Nov 17, 2009 | Poulan Pro Chain Saw 46cc 20"
How do i remove or change the clutch on my Poulan model 3314 chainsaw???
Mar 06, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro 14" Gas Chainsaw 33CC P3314 Logo
75 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
