Question about Dual XDVD8170 Car DVD Player
Flex cable xdvd9101 - Dual XDVD8170 Car DVD Player
I forgot my password for my dual xdvd 9101 how to unlock it
i bought a truck with thedual xdvd9101 radio and cant dont no the cod for it can you help me
Feb 13, 2012 | Dual Electronics XDVD9101 Car Video Player
How to stop my dual xdvd9101 screen from flashing
Hello
Do a factory reset to your set. Just refer to its user manual. OK.
Feb 12, 2012 | Dual Electronics XDVD9101 Car Video Player
How do i remove and replace my keyboard for satellite a205 laptop
Agree with LaptopRepair. The procedure for Keyboard removal is pretty close.
Wanted to add information on the FFC connector though.
If you have never dealt with a Flat Flex Cable connector, you are going to be in the dark, and could break something.
1) The flat cable from the Keyboard to the motherboard, is a Flat Flex Cable.
2) The connector on the motherboard the FFC connects to, is an FFC connector.
3) The Flat Flex Cable removes FROM the FFC connector.
> Just the flat flex cable, comes out of the connector on the motherboard.
Again, The flat cable by itself comes out of the connector, with no connector on it.
4) The FFC connector on the motherboard, does not come away from the motherboard. It is attached to the motherboard.
The FFC connector on the motherboard does not come apart in two pieces.
It opens to release the flat flex cable.
The FFC connector ONLY opens so far.
(1/8th inch ?) It is a two piece connector, but does Not come apart.
Looking at the FFC connector, you will spot a parting line going across the middle.
The top half of the connector looks like a fat T.
The two tabs on either side at the top of the Top half, make the T head shape.
These two tabs are pushed towards the LCD screen.
Ease one tab up a little, then ease the other tab up.
This opens the connector, and allows the flat flex cable to come out.
Install the flat flex cable from the New Keyboard, in the same direction as the old Keyboard's flat flex cable.
One side of the flat flex cable has exposed copper strips. (Contacts)
The other side does not.
Be sure to install the flat flex cable of the Keyboard in the correct orientation.
Do not rate this information. Just added info.
Oct 28, 2010 | Toshiba Satellite A205-S5879 Laptop
I want to replace my keyboard for my toshiba satellite P505
Sep 01, 2010 | Toshiba Satellite P505-S8945 Notebook
Where does the yellow and blue cable connects to?
The yellow connects to power, if the blue wire has no stripe its an accessory and simply needs connected to power if the blue one has a white stripe its the remote turn on wire for an amp.
Sep 17, 2009 | XO Vision XOD1742BT Car DVD Player
Does the flex cable of samsung e250 work on e251?
e250 itself has two type of flex cable , so you need put and check it . I think you should try with both type of flex it should work
Aug 27, 2009 | Samsung SGH-E251 Mobile Phone - Black
LG Shine CU720 Flex cable replacement
well take apart the lcd part and the keypad part and strat connecting the flex cable.
use this trick:
use ur digital camera to take shots for every step u performed so u not getiing lost after taking the phone one part.
aslo while repalcing the ld put the new on it place!!!
Jan 30, 2009 | LG Shine CU720 Cellular Phone
3230 help.,
The flex cable is the weak link in all Flip style phons, so yes replace the ribbon/flex cable and most likely it will cure the problem.
Oct 28, 2008 | Nokia 3230
3230 problem
flexcable need to be replaced
Help
you may have a faulty phone ...needs to be returned...the flex cable in the screen is damaged or loose.does the screen come on at all?
if it does that means your screen flex cable is faulty and if it doesn't your main flex cable is loose maybe from a fall or water damage.This needs to be handled by a qualified service tech. to get to the main flex cable the screen cover would have to be removed via the four screws located under the 4 rubber stubs on the main inner screen.You need to have a t6 otr a t4 screw driver to remove the cover.the main flex cable pops right off but the ear piece flex cable is a little more difficult.thanks !
sam !
May 12, 2008 | Motorola Mobility RAZR V3
Dual XDVD8170 Car DVD Player Logo
47 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
