Question about Proscan 37LC30S60 TV
Is this tv compatible for an antenna? - Proscan 37LC30S60 TV
I no longer have cable on my tv and tried to hook up a antenna to my RCA 32V420T tv. however i can't get a clear picture on the tv?? what should i do??
Hi Diane
If you have had cable for a long time the chances are that your antenna is the old type and not compatible with todays digital signal. It might by worth investing in a new antenna.
Feb 01, 2017 | RCA Televison & Video
We cut cable and are trying an antenna without success. Is the Sharp component-in Pip/mts compatible with an antenna?
is this a TV , if so it should work with an antenna if you select the proper input type which might be AIR or antenna
Nov 13, 2015 | Sharp Cameras
IS RCA DIGITAL TV CONVERTER BOX DTA880 COMPATIBLE WITH ANALOG MAGNAVOX TV COMBO MWC24T5B?
they sell those cable adapters almost every where tv antennas & cables are sold even home improvement stores like home depot and Menards
Sep 22, 2015 | RCA Televison & Video
Should i have a built in digital tuner
Your TV does have an inbuilt Tuner. You will need a Digital compatible Antenna. There is a big difference between digital and the old analog TV Antenna's
Hope this helps :)
Cheers Peter Smith
Apr 05, 2015 | Vizio VW32L 32 in. LCD HDTV
I need installation instructions for a tivo drt-400 humax dvr
No. There is no tuner in the Tivo . It will record cable or satellite but not off air antenna.
Nov 01, 2014 | Televison & Video
Is there a high-gain antenna compatible with my Adaptec router to improve a weak signal?
check with your local computer store for this issue.
There should be an antenna on market that is compatible.
I would relocate the router in another location and see if the reception is better. Try to relocate the router away from cell phones or cordless phone and or digital TV's about 20 ft is desirable.
Aug 06, 2010 | Adaptec Computers & Internet
No antenna siganl strength
Antenna may not be compatible with DTV signals or not aimed correctly.  Go the www.dtvanswers.com and click on the Antennas tab at the top for more info.
Jun 02, 2009 | RCA Universal Remote Control
I'm looking for rabbit ears/antenna for my Durabrand T.V.
Radio Shack, Wal-Mart, etc. all carry a selection of antennas that will work with your converter box. Depending on the strength of DTV signals in your area, you may need an amplified antenna (has a built-in booster) to get good reception. Analog broadcasts were watchable with a weak signal (the picture would just be fuzzy), but the digital system needs a good strong signal. The sales people may be able to suggest an antenna based on what other customers have purchased and their reports of how well they do. Outdoor antennas are also available if needed.
Jan 12, 2009 | Durabrand BH1304D 13" TV
I have an older symphonic 19in portable tv. i have just bought a converter to make it compatable to digital. my prob is i no longer have the antenna. can i buy one in stores? it has been used mostly for...
Digital tv converters and digital tv for that matter require a good signal to operate, a good quality rabbit ears available in a number of stores will get you some local stations. To get maximum reception you will require an outside antenna.
Dec 02, 2008 | Televison & Video
Proscan 37LC30S60 TV Logo
15 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
