Question about Whirlpool AWM5145/2 Front Load Washer
My front loader trips out when spinning and returns to the start of the spin cylce
When the spin cycle spins up it trips back to the start of the cycle
Coldcut
  • 1554 Answers
SOURCE: Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Posted on Mar 04, 2008
Slinteriors
  • 8617 Answers
SOURCE: Whirlpool AWM312/3 Front Loader Washing Machine - not spinning
I would recommend getting the service manual for your model as some models have clutches that control spin and others have belts. The service manual would be the best route if you are planning on repairing this yourself. If you would like the service manual let me know and I will post a link to where you can get one emailed to you.
Posted on Mar 27, 2008
  • 1294 Answers
SOURCE: i have a front loader whirlpool duet #ghw9100lw2
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
Posted on Apr 08, 2009
SOURCE: GE Profile - Loud knocking on spin cycle
Just random input, I apologize if this is of no help to you. I've only experienced this with my washer when clothes somehow get bunched up on one side of it.  The best I can tell you at the moment is to make sure there is relatively equal distribution of clothes around the "washer bucket thingy" if you hear the bang bang bang again.
Posted on Jul 07, 2009
  • 942 Answers
SOURCE: Whirlpool wfs1285aw noisy spin cycle
Hi..
If you washer is noisy,
  • Check that the water supply valves are turned on
  • Inspect the filter screen
  • Test for overheating
  • Inspect the water pump
  • Test the water inlet valve
  • Test the motor
General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Good luck !!!
Regards
PCmania
Posted on Jul 14, 2009
Whirlpoool front end loader washing machine showing an f 06 error
The F/06 is:
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
The tech. should check these:
Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
Check the Drive Motor
Check the MCU
Check the Wire Harness
Nov 04, 2012 | Whirlpool Washing Machines
My front loader was turned off during cycle because we had to leave house. upon returning we just started it back where we left off. upon entering the spin cycle it began to make a horrilbe banging noise,...
BUMMER. I would assume you shut it down during a spin and when it took off it got out of balance. Perhaps druing this it caused some damage.
I would start by unpluggin it for 1/2 hour..... and try it again... If it does then you'll need someone with some technical abilities to look inside at the mechanical parts and then electrical.
Good luck,
Shawn
Jan 31, 2011 | Maytag Neptune MAH5500B Front Load Washer
Main power flicks off when starting my simpson esprit 750 washing machine
Hi just read your posting,Now there are two types of Simp esprit,Is yours a top loader or a front loader? Does the machine trip the fuse when you select the spin cycle or only when it starts to fill?Have you tried putting it on a spin cycle?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Aug 28, 2010 | Washing Machines
Cylce stops after 1st drain before spin out
I have kenmore washer front load H2 after 1st circle of wash it stop and start beeping with code F11. My email address is anarfi1212@ live.com
Jan 21, 2010 | Kenmore HE2 Plus Front Load Washer
During spin cycle washer spins fine but toward the end of the cycle it spins out of control like it is out of balance? Any help is greatly welcomed.
Some front loaders have a super high speed at the end of the spin. Front loaders don't like small loads, the laundry does not spread out evenly enough for a balanced spin.
May 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Nov 04, 2008 | Zanussi ZWD1680W Front Load Washer / Dryer
Kenmore Elite shaking during spin cycle
Moved a Kenmore Elite and when we put it back in place it vibrates loudly. We tried leveling it and that has not worked. Any ideas?
Sep 27, 2008 | Kenmore 24032\24036 Top Load Washer
Aquarius 1300 spin trips residual circiur breaker
Hello
There can be two possible reasons for it triping..
Firstly what im pretty sure it is, the motor... either your motor is faulty or your carbon brushes are worn... Im saying this because when the motor has to work at its hardest during the sping cylce it just cannot cope..
The other thing could be is that the drum has play within it and when spining quickly it is cathing the heating element probably already damaged it and therefore triping.
There your most likely faults
hope this helps.
The motor is located at the at the back on the bottom of the drum.
the heater is located at the back on the bottom of the drum .
Most likely is will not be the heater as it is more common on the older hotpoints.. But i thought id mention it
Hope this helps......
Jan 14, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Whirlpool AWM5145/2 Front Load Washer Logo
19 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
