Question about Philips Magnavox 51MP392H Rear Projection Television
Magnavox Digital Video Board E209262 - Philips Magnavox 51MP392H Rear Projection Television
Is the main board for a Magnavox LED 32ME303V/F7 expensive?
Under 20 bucks on eBay, but be sure that is the bad board
Oct 16, 2017 | Magnavox Televison & Video
Magnavox flat scr tv turns on and goes of 2-4times before it will stay on
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Feb 15, 2017 | Magnavox Televison & Video
I have a 50mf412b/f7 magnavox tv that will not power up. I have replaced the power board with no change. Any suggestions for my next step?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 24, 2017 | Magnavox Televison & Video
What do I do when my Magnavox flat screen TV volume is going up and down by its self?
Jan 14, 2017 | Magnavox Televison & Video
Need to find part for 50 inch dlp magnavox tv. I need new digital board. Where can i find this part?
Hi Wendi, I ha d a look and you can find some options online, for instance on Ebay if you look for "dlp tv board" and then search the page for MAGNAVOX. Good luck!
Dec 19, 2014 | Televison & Video
42MF437B/37 magnavox tv no power making buzzing sound
It sounds that there is some shorted component/s one either main power regulator board, or at the main digital board. Your TV need a through checkup.
Sep 11, 2012 | Philips Magnavox 42MF521D/37 Television
My magnavox 42'' TV ,plasma wont turn on when i push the on button it just makes a few clicking noises at different points then shuts off. i get nothing on the screen. what had happened was i accidentally...
Sep 06, 2017 | Philips Magnavox 42MF521D/37 Television
Philips Magnavox 51MP392H Rear Projection Television Logo
155 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
