How to hook-up Gateway BBE SRS TV to cable - Computers & Internet
SOURCE: Sony WEGA Trinitron SRS BBE 32'
How do you get the green display off of the tv screen?
Posted on Jul 04, 2008
  • 59 Answers
SOURCE: Getting green display off of tv screen.
use the remote and press the display button
  • 32 Answers
SOURCE: We can't find the cable connection to a Protron tv.
can you tell me the model of your protron lcd?
Posted on Jan 07, 2010
SOURCE: Sony trinitron Srs BBE stand by light blinking and
ONE: Unplug it for at least 4 hours. That is what we call a hard reset.
TWO: If the hard reset does not help, then it will need further diagnostics.
The following bulletin may be of help in your learning about what is going on. Please refer to it below. Then let me know if you need further assistance.
Have a great day,
Cleggsan
Sony Blinking Codes
Many of the later model Sony TV's have a built in Self- Diagnosis function. If
the timer/standby indicator is blinking, this could be an indication of the
problem with the unit. The diagnostic blinking will occur automatically with no
action required by you to engage it.
The timing of the blinking you see would be as follows: two to eight blinks
(depending on the fault) about a third of a second apart, then pauses for 3
seconds, then the two to eight blinks about a third of a second apart again.
Here is a list of the problems that might have occurred indicated by the
number of blinks. The words in parentheses are those which you will see for
each of these faults on a diagnosis screen described later in this article.
Unit is dead and there are no blinks---Problem in the standby power
section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should
show open)
Continuous Blink Once A Second, No Pausing As Discussed Above---
No reply from the jungle IC301 (data bus is busy, shorted to ground or held
high), IK video path is defective.
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby
mode then displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single
horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and
blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
Intermittent problems ?? This is a great feature. You can also bring up
these fault codes ON-SCREEN to see a list of the problem numbers with the
abbreviation of the problem and the number of times this problem has
occurred. This is slightly different than entering the service mode. To see the
diagnostic screen, Press the following buttons:
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
a screen with a list of the problems and number of times they have occurred.
Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
We have repeated them in parentheses in the text for the "Blinks" described
above so you can correlate between the diagnostic screen and the blink
codes.
So, now that you know about these self-diagnostics, how do you use them?
Say that you have a set with a black screen. You see that the LED is blinking
4 times....This would tell you that you have no vertical and that is why the
video is muted. If it was blinking 6 times, you would know that you have a
horizontal fault.
It's not a sure cure, but it's a little better than a poke in the eye with a sharp
stick.
IMPORTANT: after you repair the unit, PLEASE clear the values on this
diagnostic screen. These codes do not reset themselves after the fault is
corrected, so if you don't clear them, you'll be seeing "old" fault codes the
next time you enter this screen.
Clearing is done by going into the service mode ( display, channel, 5,
volume plus, then power ) then press 8 and Enter, which of course returns
everything to the factory preset condition.
Posted on May 31, 2010
charuna35
  • 28 Answers
SOURCE: my sony wega trinitron srs
Power on is indication of current supply malfunction. For example, the battery supply requiring recharge before powers back on again once depleted of supply at prior usage. A completely depleted device battery would require full battery recharge before any images are displayable once more. Ascertain the full charge duration requirement to perform battery charging. Meanwhile, inspect the device for power device maladjsutments. For example, the battery compartment may have malalligned due to impact. verify that each compartments contributing towards powering up is in place. Open battery compartments to ascertain integrity. Thereafter, plugging device to power source should restore default power functioanlity soon after full charge is acheived. Also, the process of powering on the device may require continously pressing on extensively to acheive restore display for images. Refer to the device user manuals for diagnostic on power malfcuntions. Consult technical experts when required. Good luck
Posted on Jan 08, 2011
Is the 2004 sony trinitron srs bbe model nomber kv32fs120 analog or digital ?
Try this: http://tv.manualsonline.com/manuals/mfg/sony/fd_trinitron_wega_kv32fs120_kv36fs120.html
Apr 27, 2015 | Sony Televison & Video
Panasonic HDTV 10801 BBE TAU
Unplug it for a few seconds and
plug it back in if this doesn't
do it the call in a technician
may be HV or PWR Sply problem
Nov 29, 2007 | Panasonic CT-32HXC14 32" TV
Srs bbe
SRS means SurRound Sound which is simulated to what is called BBE high definition sound enhancement i believe this was got from a car radio device from the word PREMIO it was a toyota premio
its used in tv sets and hi fi audio and car audio systems and NO its not a tv but a monitor, u will need a dvd car audio thats compatible and given they r custom made for premio u will need the exact march to use it.
Jul 14, 2013 | Televison & Video
Need cable tv for sony trinitron bbe
have you been select ' cable ' at the settings of your tv. then where did you hooked up the cable box at the tv ?.have you been tried to reset the cable box.
Dec 04, 2012 | Televison & Video
I can't get any channels on Sampo SRS BBE
Hello
Check its tuner for defect. Replace it.
Mar 04, 2012 | Samsung Televison & Video
Re: Protron BBE Digital SRS Wow. Turned on TV and the sound came on but no picture. Pressing the Source button will change the sources but you can't see what it is changing to. The word Main will...
You don't list a model # If this is an lcd tv, you have an issue with the backlight inverter module, I would first check the power supply for potential of swollen capacitors, the tops will swell up and sometimes leak out electrolytic oil. Either or it's repairable with a little knowledge and some luck!
Jul 09, 2011 | Televison & Video
Jan 06, 2010 | Televison & Video
May 04, 2008 | Sony FD Trinitron WEGA KV-29LS35 29" TV
I have a Samsung HT-X50 Surround Sound, a LG 50" Plasma 50PC5D TV, and DISH Network Satellite.
How can I get surround sound to work on my tv. When I pull up my menu and go to audio the SRS Trusurround XT is not in bold so I cant figure how to connect it so I can have the surround sound coming from the system and not from the tv. Please help.
Dec 24, 2007 | Samsung HT-X50 System
Computers & Internet Logo
David Payne
David Payne
