Question about Video Game Consoles & Games
Take me out, scratch my head, i am black, but once was red
    Problem Solver:
  • 7 Answers
A match.
Posted on May 07, 2014
What dos BK and CL lights mean?
BK is the black print head and CL is the color print print head.
Sep 08, 2015 | Canon PIXMA MG3520 Wireless Inkjet Photo...
My colours are not aligned anymore.
Go to printer menu, in services select clean print head nozzles, then perform align print heads,once align completed check for the print waht you checked earlier...
Feb 01, 2012 | HP Officejet Pro K5400 All-In-One InkJet...
Bought new ink and not all the colors are printing black ink works good but colors red and yellow not showing up
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Nov 16, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
My BN200 nailer has a crimped Oring. After firing once it stratd blowing air out the back port. I toke it apart a reajusted the Oring. after firing once it started blowing air out he back port again. How...
The oring on the headvalve/piston should be replaced. You can use any oring that fits snugly on the groove. Factory oring is vinyl but use black rubber oring, works just fine. Most likely place to find orings is Lowes in the plumbing department. Select oring smaller than groove so that it will fit snug and should be about 1/8 in thickness. There is a smaller oring behind piston, just make sure it not cracked and check for upper seal in head to be in place. Finally check that surface there oring seals on head is not scratched. Remove fine scratches with #400 grit paper.
Aug 29, 2010 | Porter Cable Tools & Hardware - Others
I've just installed both a new black cartridge and a colour one but after having to clean the heads a number of times to try and get the print quality back up to scratch the printer is now refusing to do...
.. is the light flashing alternate? if yes, then the printer porous pad need to be replaced and reset ink counter.. install your printer driver and status monitor and you should be able to find out whether it's the ink empty or maintenance needed. For this model.. I am sure your waste ink counter is full...
May 20, 2010 | Epson Stylus 680 InkJet Color Printer
Tonearm not emitting signal into Serato
there is a switch that cuts off the signal when the tone arm docks.check the wiring is not broken inside and that the switch is ok.typically,red green white black red and white are plus and left ground is green and right ground is black.the collar that screws on to the head unit has 4 pins.make sure the contacts are clean.measure the wires one at a time from the tone arm to the rca plugs on the back.the green and black go to the outside collars,and the red and white go to the center pin of the rca plugs
May 26, 2009 | Technics SL-1200 Turntable
MISSING COLOR IN MY PRINTS
try a test page first and see what that does
Aug 08, 2008 | Epson Stylus C46 InkJet Printer
2 many ceiling wires
ok lori connect the fan wires like this-----white from fan to both white wires---blue from fan to red---black from fan to both black wires then copper wires to a ground.let me know.
Jan 15, 2008 | Hampton Bay 46056 Callaway II Ceiling Fan
Head cleaning
This is that the black drum unit cleaning blade failed or the charge roller has toner stuck on it. To remove the drum open the front cover and using the green tool right hand side of opened door undo the two screws turn the transfer lock into the unlock position and lift. Once you have done this then remove the black drum this is the one at the top by moving the little green tag to one side and pulling out (Be Careful as if you scratch the drum you will have other problems)
Once remove you will be able to see the drum and a black roller above it see if that has the black line on it. If it has then clean with some alcohol based cleaning fluid once this is done reinstall and then print. If there is no line on the black roller try above the likely thing is that the drum cleaning blade has worn and the unit will need replacing.
Glad to be of some help
Thanks J
Dec 10, 2007 | Ricoh Aficio AP3800C Laser Printer
Video Game Consoles & Games Logo
16 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
