Question about Northstar GPS
Northstar 958 Need to buy antena cable for 958 northstar
My DVD 958 not showing with the hdmi cable through the television
You first should hook the device up with AV cables, after you uses AV cables , you will get a picture, once you get a picture, you need to go into the setup menu and turn on HDMI, once you do this, then you can switch to the HDMI cable.
Jan 29, 2013 | Coby DVD-958 Theater System
The picture looks like it's moving in slow motion...
Ur tv incomming broadcasting tv channels signals are pick up and using are Free over the AIR broadcasting tv channels pick up are by a Antena signal wright?Not signals by a pay cables or satalites tvs incomming broadcasting input signals?Yes?This tv causes are low and weak ranges of a tv Antena incomming recieving broadcasting tv channels signal.Buy a better design Antena like a Digital Antena and used it will solved this problems.Plug it in ur Digital Antena and rescan ur Free over the AIR broadcasting tv channels again.
Aug 15, 2011 | TruTech PVS31170S1W 17 in. LCD Television
To hook up antena-do you need a special cable
No,buy a indoor digital antena have a wire already just plug the wire into the Ant. hole screw it in.Go into the tv menu goto SETUP.Go down to Ch.enter pick AIR enter again for scanning for free air broadcasting channels,after all done scanning.That it tv now have all free air broadcasting channels.
Jun 09, 2011 | Protron PLTV-26 26 in. HD-Ready LCD...
Do i need to buy a converter box for this tv
No,this tv is a digital tv,just reqiure a good antena like a digital antena or a roof antena.Hook it up.Just go into tv menu setup and set up to pick up AIR not CABLE and enter to scan for DTV free air channels.
Feb 01, 2011 | RCA L26WD26D 26 in. LCD TV
Cannot get TV to work on antenna...In menu I set cable to off, then initiate autoprogram but tv says "no signal". My antenna has a bulit in digital to analog converter. Suggestions?
Must buy a Digital converter box and to install it seperatly to devert back to tv anlogue tv signal to make the tv to work.Tv antena inverter alone can't convert analogue signal to digital signal only can give basic tv antena for better antena reception.Tries websites like Ebay.com,Amazon.com to buy a stand alone digital converter box to install and that didigal antena install and auto scan again u should able to get all the free DTV air stations.
Feb 01, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How can we view cable TV when the TV doesn't have a tuner?
Ur tv is a digital tv.Just buy a Digital antena or a roof antena hook it up.Go to SETUP menu go down to CH. SETUP pick AIR,not CABLE and than enter to scan.After ur tv done scanning,u will get all the free air DTV channels.
May 01, 2010 | Olevia LT37HVS 37 in. LCD HDTV
Power antena after markit how to make it work with radio
on the radio there is a cable that is for Power Antena you might have to set a cable out to the area you are instslling the antena if this car already had a power antena you only need to hook up the leds from the old if not then like i said you need to get positive cable out to the antena and ground it to chassis
Apr 01, 2010 | 2000 Mercury Sable
Can i connect my audio and video cable to a coaxial cable? so one side is coaxial cable and the other is audio and video cable one for the the wall and the other audio and video for the tv, this is beause...
U have HDMI ports,order HD from the cable or telicom compannies.Use a HDMI cable for the tv,also get HD channels.Do not have HDMI ports than ur Main signal board must replaced the Antena analog coaxial it broken.Well not able to buy the coaxial input for the antena along for part.
Jan 10, 2010 | RCA HD52W58 52" TV
Yes my northstar 6000i keeps losing gps signal
how old is you Gps antena ,with a older one it can happen that they lose fix
Where is the Gps antena fixed inside the boat or outside
Allway try to put tha antana outside. abou 20 % more signal
Look after the antenakabel if the kabel is a little bit broken water coms inside thae kabel an the signal gets lower.
Aug 27, 2009 | Northstar 6000I GPS Receiver
No Picture and No Sound on all Analog Channels
Ur tv shouldn't set in cable mode, if u don't have pay cable,or satalite,extra..Should set in air channels.Buy a digital antena or out side roof antena u get all the channels airs.
Aug 19, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
GPS Logo
16 people viewed this question
Top Northstar GPS Experts
Are you a Northstar GPS Expert? Answer questions, earn points and help others
