Question about Nokia 5800 XpressMusic Smartphone
I am not geeting past nokia white screen
My phones battery drained out, so it got switched off, i tried to put it on charging but nothing is happening, the phone is just stuck on the white screen with nokia logo on it, wen i try to turn it on then also its stuck there, its not even powering down without taking out the battery, what can i do with it
Kenapa ini g ada yg jawab
Posted on Jul 18, 2009
My NOKIA 3110c phone got switched off by itself and has not come alive. If I try to switch it on, the screen blinks white thrice and then goes dead again!
Firstly, Remove Sim Card , Memory Card and try to reboot 3-6 times,sometimes this trick is working.Even if the problem still persist better to contact mobile repairing shop or follow the procedure below.
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 3110c file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
Sep 23, 2011 | Nokia 3110 Cellular Phone
Nokia n70 is showing white blank screen
possible the firmwar is damage or sum ics have burn because of a power spike, or brownage while it was on charge, take it to a repair shop to be checked
Oct 08, 2009 | Nokia N70 Cellular Phone
I'm having trouble when switching on my nokia 3110c
hey i have a solution but its quite rough though... take out all your memory card and sim card and battery... then without the battery press the on button. just put in the battery and keep holding the button. if it still restarts then take out and put the battery in again until it will start. this really works as it works for me 5 times when i had this problem. but the only thing i'm scared is that it might damage your phone. but once you have this problem your music player will be spoilt already. my music player was also spoilt but it works twice. now it doesnt work though. im not sure about music player
Aug 11, 2009 | Nokia 3110 Cellular Phone
Get my license key for nokia 7610
Old Nokia 7610. Battery charged, switch on. Some times it comes all the way on. I "reformatted" on one of those magic occassions. Most of the time, white screen only....you can hear the Nokia handshake music, but nothing but a white screen. any ideas?
Jun 14, 2009 | Nokia 7610
Nokia N70 Screen is White and shows NOKIA only
Open the back cover of the phone and remove the battery,the try blowing it hard where the battery pins are for 10 minutes or so then switch it back on.Your phone will run smoothly,but only for a short period.The best option is to press the *,green,3 at the same time after blowing the phone.if it does not want to work then let me know.josephsimaneka@aol.com
Dec 25, 2008 | Nokia N70 Cellular Phone
Nokia 6300 -Wont switch on , only has blue lights
your cp having a defective lcd now. it need to be replace and send it to repair center,
Nov 05, 2008 | Nokia 6300 Cellular Phone
Nokia 6300 does not boot up when started
Try this:
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know. You need someone to press the ON button.
Mar 26, 2008 | Nokia 6300 Cellular Phone
Nokia 7373 wont turn on
This might work:
Switch off.
Yes! I know, you need someone to press the ON button.
Mar 15, 2008 | Nokia 7373 Cellular Phone
Nokia N70 will not turn on
Actually when you want to switch on your phone, but it's not turned on,but when you charge the phone, the battery indicator goes up, it just mean one thing : YOUR ON-OFF SWITCH is broken!!
so how to replace this on off button? well, if you can, open the casing of your phone. you'll see the real on-off switch below the usual on-off button we have on the casing. press it. Good luck ^^
Btw if you have no luck pressing the real on-off switch, replace it, bring it to technician. It shouldn't cost you more than 10usd if you told them to problem (if you didn't tell them, they'll say, oh your IC got broken, oh your phone will cost much on the fixing, oh this oh that, they'll **** your money..). Just said, hey, my on-off switch got broken, please fix it.
You can get my head cut-off if I' wrong.. haha, I'm pretty sure that's the problem.. well there's a little case of broken circuit that might cost you much more, but shouldn't be more than 20usd too ^^ Good luck
Mar 07, 2008 | Nokia N70 Cellular Phone
Nokia 5800 XpressMusic Smartphone Logo
373 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
