Question about Whirlpool Washing Machines
My washing machine seems to keep filling up and then after so long the red light comes on to say tap is closed - tested all pipes etc - do not know what to do
SORRY BUT DO NOT WANT TO GIVE MY CREDIT CARD DETAILS OVER THE COMPUTER - NOT RELIABLE.
THOUGHT THIS SERVICE WAS FREE OF CHARGE FOR WHIRLPOOL
Posted on Jun 23, 2009
Hot water not coming into washing machine
The solenoid valve that lets hot water into unit is not opening. Check out the valve itself and the timer cam that feeds power to the cam.
Jul 04, 2015 | Maytag Washing Machines
Our miele w911 washing machine keeps stopping in the main wash cycle - red light above the tap symbol. What does it mean?
check that the water flow solenoid is operational and not blocking of the spray rinse requriement
Mar 23, 2015 | Miele Washing Machines
After washing a load, the next day I find water in bottom of tub in front load.
If it is clean water main couase is a leeky fill valve (not closing) after machine power off. Repalce or turn tap off. If it is hot & cold fill then turn one tap off after a wash and see if the water still comes in. Repeat with the other tap after the next wash.
If it is dirty water then it is filling back up from your drain system this would need to be inspectected for blockage etc.
Oct 01, 2014 | Washing Machines
Washing machine not filling
yes your problem is up the line somewhere. you have to have water coming out of the fill line when the washing machine is unhooked.
you will have to locate the valve to turn on the water.
good luck
Jul 05, 2012 | Russell Hobbs RH1042 Frontload Washing...
It will not fill with cold water. Could it be due to the cold weather - the cold water pipe frozen. Kitchen is very cold (pipe is next to an east facing wall). Same pipe also fills the dishwasher,...
If youve taken the fill hose off and checked for running water out of tap and its not coming through, your machine is ok, you have a water fault.the humming is the water valve working.
Dec 21, 2010 | Washing Machines
Machine fills and keeps filling and never goes to agitate. just fills. If you skip it ahead it will only go to rinse and spin.
Probably a siphon problem . Check your drain hose to make sure hose is not stuffed too far down drain and air can get between the hose and the drain pipe . If you have tapped the hose to the drain to keep water from coming out the drain pipe , go to home depot or an appliance parts house , and get a siphon break . When a washer fills , but water level doesn't rise in the machine , it's being sucked out by siphoning through your sewer pipe .
Aug 15, 2009 | Washing Machines
Bosch WFD 2460 Washig Machine
Hi, It sounds like you have the two water pipes fitting on the wrong connectors on the back of the machine.
IE: The hot water pipe (RED connector) on the cold water inlet on the back of the machine (BLUE connector)
Is should be red to red and blue to blue.
Jan 03, 2008 | Bosch Logixx WFT 2806 Front Load...
Washer/Dryer
it depends if you have a combie boiler if not should be cool but if so would recomend a screw on tap connector from any good hardware store for your cold pipe
Oct 23, 2007 | Whirlpool AWG320 Front Load Washer / Dryer
Washing Machines Logo
63 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
