Question about Solar X10 Pro Xps3 Rock Style Switch White
What is the load wire for on a x10 switch - Solar X10 Pro Xps3 Rock Style Switch White
  • 3,382 Answers
It is AC therefore it doesn't matter, they need current to operate, about 5-8 watts per switch. It may be more cost effective to use LED lights and leave them on. I have problems with LED lights in the X10 because they do not use enough current.
Posted on Mar 03, 2015
Camera Wiring Diagram X10 SC18A
Can anyone tell me where i can find the wiring diagram for the x10 sc18a camera,i have two that was ripped from the wall..please send respone to philbakk.ap@gmail.com
Sep 04, 2013 | X10 Color Wired Video Camera Sc15a For...
Why do i keep getting x10 at the end of each answer
You're in scientific or engineering notation. Press SHIFT SETUP 6 followed by the number of digits you want after the decimal point to switch to fixed decimal notation.
Sep 06, 2012 | Casio fx-300ES Calculator
Would like to replace this switch with a standard light switch, whats the correct wiring connection
PLW01 has 2 wires: Black wire connects to Hot and Blue wire connects to Load wire.
http://lib.store.yahoo.net/lib/aaaremotes/PLW01.pdf
Remove PLW01 and you have Hot and Load wires.
Standard light switch has two brass colored screws, and one green ground screw.
Connect either wire to either brass screw.
Connect bare ground wire to green screw.
Aug 10, 2011 | X-10 X10 Pro PLW01 Standard Toggle Single...
How do you remove the wires from the back of the switch in order to replace it?
pull and turn side to side as these are called backstab connectors and theyre internally spring loaded
Apr 27, 2011 | X-10 X10 Decora Style Wall Dimmer - Model...
MY EXPERIA X10 IS SIM LOCKED TO UK 3. HOW CAN I UNLOCK IT. THANKS
you can unlock it and switch over to another network , if you want to unlock, you can get codes here http://www.prounlocking.com/sony-ericsson-xperia-x10/rs8wp9/
you need to specify the country and network provider
Jan 18, 2011 | Sony Ericsson XPERIA X10 Cell Phone
I have a GE Simon Security System with a GE Simon 3- X10 Line Carrier Transformer that powers a siren. Since the X10 transformer was installed, I constantly get sensor 'failures.' Although the panel...
X10 is a signal format transmitted over the power lines, there is no special X10 wiring in the house as such. The siren and your outside lights are X10 receivers which are sent a signal from the X10 transformer connected to the alarm panel. The alarm panel sends the codes which are transmitted as X10 to the X10 external devices. Most houses now days have at least two 120 volt feeds coming into the main power panel, this provides the 240 volt required for electric stoves and dryers. Because of the two separate feeds split at the panel, the 60 cycles is usually out of phase with each other. To get X10 to work and stay in phase on each side of the panel you need to have wired a passive coupler across both 120 volt inputs. This coupler keeps both 120 inputs in phase with each other and provides a clear X10 transmit across the house wiring.
Dec 19, 2010 | GE Security Simon 3 Wireless Home Security...
How do i transfer the pictures and videos from my Experia X10 to my laptop computer. i plug in the usb cable and double click on the portable device icon in My Computer and it asks me to insert a disk....
I Junebunny75
To Transfer pics/videos from X10 to PC/laptop...
first of all plug in the cable that comes with the X10. (It is the same one that plugs into the top of the charger)
into a USB port on your PC/Laptop.
Then Open the cover on the top of the X10 handset. (The one that hides the charger port)
Now plug the cable into the charger port.
Your handset should be switched on.
In the top left hand corner of the X10 display should now have a little USB symbol on it??.
If it does just ttp the symbol and drag your finger downwards.
This now shows what you would like to do with the USB.
It says something like. "Select to copy files to/from your computer" Just tap this prompt then a pop-up appears asking to "Mount" or "Don't Mount"
Tap "Mount"
This will now prompt your PC/Laptop to load the correct drivers.
If you are using a Windows PC/Laptop it should find drivers fairly easily as it is just a "Mass Storage" device.
When/If it has done this it will say "Device Connected" or similar.
You can now go into "Start"
"Computer"
And in there you should find a new drive.
This will be your phones memory
DCIM is the folder with your photos in it.
I hope this helps?
Aug 15, 2010 | Sony Ericsson XPERIA X10 Cell Phone
My sony ericsson is not reading my SD card
Hi.
I have had similar problems with my X10.
What I have found is...
Sometimes switching off the handset then restarting makes it work.
Sometimes removing battery, then SD card then replacing them again works too.
I hope this helps.
May 22, 2010 | Sony Ericsson XPERIA X10 Cell Phone
Sumsung X10
You can download it here from Samsung along with loads of other stuff. For drivers, click drivers.
Jan 16, 2008 | Samsung X10 XTC 1300 Notebook
Solar X10 Pro Xps3 Rock Style Switch White Logo
Top Solar Electrical Supplies Experts
Steve
loft404
loft404
Level 1 Expert
Craig Butler
Craig Butler
Are you a Solar Electrical Supply Expert? Answer questions, earn points and help others
