Question about Vehicle Parts & Accessories
How can i know if the fan cluch is working? - Vehicle Parts & Accessories
  • 136 Answers
If the fan engages when the cooling system reaches switch-on temperature, and disengages when it has cooled sufficiently it will be working. If it NEVER engages, or NEVER disengages regardless of cooling system temperature, then it's not!
Posted on Aug 12, 2014
2009 Cummings turbo diesel 6.7 L why does the fan cluch working when I turn on the a/c but turn it off and the fan cluch not working ????? Why..
Temperature not getting hot enough in the engine(bad thermostat), bad engine coolant sensor. Codes help.
Aug 21, 2015 | Cars & Trucks
Cooling fans not working
a 2005 sierra comes with a cluch fan not an electric fan. sounds like you need to replace the thermostat
Mar 25, 2013 | 2005 GMC Sierra 1500
Cluch ***. off water pump
spray lube,wd40 rustbuster etc between where pulley and clutch meet the clutch sometimes sticks to the short stub that in middle of water pump than tap clutch by pulley and pulley should pop off may have to repeat a couple of times
Jan 21, 2010 | 1998 Chevrolet S-10 Pickup
How wolud i know if my fan cluch isn't working?
on them if u get out and look u can tell by moving fan with your hand if it move back and foward its bad thats if it dont have the one with computer chip in it if its that one it will start sounding like a jet
Oct 20, 2009 | 1995 GMC Yukon
99 dodge grand caravan a/c not working.compressor cluch working,fans don't come on lines hot down at compressor
Cooling fans must work with a/c on.With a/c turned on check voltage at fan motor plug.If no voltage have to back trace to fuse for fans or relay's,but I have replaced a few fan module's for this problem.
Aug 19, 2009 | 1999 Dodge Grand Caravan
Fan will not come on,but it turns.need to know if there's a reset button or cluch reset?
I think that some models have areset button on/near the motor. Look on the end of the motor for a red button.
--W/D--
Aug 18, 2009 | Lakewood MC-42 Fan
Need to replace fan cluch
the radiator fan is mounted to the clutch, in other words remove the bolts / nuts that is holding the fan assembly to the water pump usually just four nuts once you pull the fan assembly the part that yo seperated from the water pump is the clutch, now remove the fan blades and mount thm on the new clutch assembly the piece which mounts tt the water ump is the fan clutch
Jul 10, 2009 | 2000 Kia Sportage
I like to know how to take off a cluch and motor fan and a z71
clutch and fan assembly are connected to the pump with four bolts. Have someone push down on the drivebelt so the pump pulley won't turn and break each bolt free, then remove the bolts.
Jun 23, 2009 | 1997 Chevrolet K1500
Vehicle Parts & Accessories Logo
29 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
