Question about Frigidaire GLTF2940ES Front Load Washer
Wiring harness disconnected
I cant see where to plug it in to!
    Champion:
  • 249 Answers
More info please
Posted on Nov 25, 2007
How many wire harness clips connect to module besides the antenna
Engine Control Module Wiring Harness Replacement - 1.4 L ...
workshop-manuals.com/.../repair.../engine_control_module_wiring_harn...
3. Unclip the 3 wiring harness clips (1, 2) from the engine control module wiring harness brackets. ... Disconnect the wiring harness connection adapter plug (4).
Engine Control Module Wiring Harness Replacement - 1.6 L ...
5. If equipped, disconnect the engine oil level sensor wiring harness plug (7). ... 10. Unclip the 2 wiring harness clips (2, 6) from the wiring harness brackets.
How to fix wires that break out of plug clips on a wire harness
Dec 01, 2015 | Cars & Trucks
Tanning bed wiring diagram
For a wiring diagram, contact Sunstar directly.
Sep 16, 2017 | Health & Beauty
Head light wiring
There is usually a small plastic clip on the top of the wiring harness that you need to separate in order to pull the plug apart.
Sep 19, 2013 | BMW Cars & Trucks
Spark plugs
Check this SPARK PLUG REPLACEMENT - REMOVAL PROCEDURE
1. Remove the ignition coils (lines at end this document), then return here once you have gotten the Coil
Packs off and precede with step 2 from here.
2. Clean the spark plug recesses with low pressure air. CAUTION: Wear safety glasses
when using compressed air, as flying dirt particles may cause eye injury. NOTE:
Clean the spark plug recess area before removing the spark plug. Failure to do so could
result in engine damage because of dirt or foreign material entering the cylinder head, or
by the contamination of the cylinder head threads. The contaminated threads may prevent
the proper seating of the new plug. Use a thread chaser to clean the threads of any
contamination.
3. Remove the spark plugs from the cylinder head. NOTE: Allow the engine to cool before
removing the spark plugs. Attempting to remove the spark plugs from a hot engine may
cause the plug threads to seize, causing damage to cylinder head threads.
4. Inspect the spark plugs.
INSTALLATION PROCEDURE
1. Measure the spark plug gap on the spark plugs to be installed. Compare the measurement
to the gap specifications. NOTE:
• Use only the spark plugs specified for use in the vehicle. Do not install spark
plugs that are either hotter or colder than those specified for the vehicle. Installing
spark plugs of another type can severely damage the engine.
• Check the gap of all new and reconditioned spark plugs before installation. The
pre-set gaps may have changed during handling. Use a round feeler gage to ensure
an accurate check. Installing the spark plugs with the wrong gap can cause poor
engine performance and may even damage the engine.
2. Install the spark plugs to the cylinder head. NOTE:
• Be sure that the spark plug threads smoothly into the cylinder head and the spark
plug is fully seated. Use a thread chaser, if necessary, to clean threads in the
cylinder head. Cross-threading or failing to fully seat the spark plug can cause
overheating of the plug, exhaust blow-by, or thread damage.
• Refer to Component Fastener Tightening Notice in Service Precautions.
Tighten the spark plugs to 18 N.m (13 lb ft).
3. Install the ignition coils.
IGNITION COIL(S) REPLACEMENT
REMOVAL PROCEDURE
1. Remove the air cleaner resonator and outlet duct.
2. Disconnect the engine wiring harness electrical connector (1) from the oil pressure sensor (2).
3. Disconnect the engine wiring harness retainers (1) from the power steering pump (2).
4. Disconnect the engine wiring harness electrical connectors (1, 4) from the following:
• The exhaust camshaft position (CMP) sensor (5)
• The camshaft position (CMP) actuator solenoid valve (6)
5. Disconnect the engine wiring harness retainer (2) from the camshaft cover (3).
6. Disconnect the engine wiring harness electrical connectors from the following:
• The engine coolant temperature (ECT) sensor (1)
• The fuel injector harness (2)
• The ignition coils (4)
• The heated oxygen sensor (HO2S) (5)
7. Disconnect the engine wiring harness electrical connector from the intake camshaft position (CMP) sensor.
8. Carefully disengage the engine wiring harness conduit from the camshaft cover, and position aside.
9. Remove the ignition coil bolts.
10. Remove the ignition coils from the camshaft cover.
1. Install the ignition coils into the camshaft cover. IMPORTANT: Ensure the ignition coil seals are properly seated to the camshaft cover.
2. Install the ignition coil bolts. NOTE: Refer to Fastener Notice in Service Precautions. Tighten the ignition coil bolts to 10 N.m (89 lb in).
3. Attach the engine wiring harness conduit to the camshaft cover.
4. Connect the engine wiring harness electrical connector to the intake CMP sensor.
5. Connect the engine wiring harness electrical connectors to the following:
• The ECT sensor (1)
• The HO2S (5)
6. Connect the engine wiring harness electrical connectors (1, 4) to the following:
• The exhaust CMP sensor (5)
• The CMP actuator solenoid valve (6)
7. Connect the engine wiring harness retainer (2) to the camshaft cover (3).
8. Connect the engine wiring harness retainers (1) to the power steering pump (2).
9. Connect the engine wiring harness electrical connector (1) to the oil pressure sensor (2).
10. Install the air cleaner resonator and outlet duct.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jan 23, 2012 | Cars & Trucks
How to change spark plugs in a 2005 chev colorado
contamination.
REMOVAL PROCEDURE
• The HO2S (5)
I cant determine which plug on the wiring harness
The Correct Plug Has a PINK Wire With a Black STRIPE on it
Sep 27, 2009 | 1994 Cadillac Fleetwood
Cant find the plugs for the wiring harness for the cd player
Radio wiring will start from the fuse box side to the back of the radio. Speaker wiring will be packed away with other related interior wiring
May 24, 2009 | 1992 Buick Regal
How to Replace a Heater Core
Removal & Installation
  1. Disconnect the negative battery cable.
    CAUTION After disconnecting the negative battery cable, wait 2 minutes for the driver-s/passenger-s air bag system capacitor to discharge before attempting to do any work around the steering column or instrument
  2. On diesel models, remove the passenger side battery and battery tray.
  3. Remove the instrument panel by performing the following procedures:
    1. Remove the air bag control module (ACM) and bracket from the floor panel tunnel.
    2. Remove the trim from both cowl side inner panels.
    3. Remove the steering column-to-instrument panel opening cover.
    4. Remove the 2 hood latch release handle-to-instrument panel lower reinforcement screws and lower the handle to the floor.
    5. Disconnect the driver-s side air bag module wiring harness connector from the lower instrument panel reinforcement.
    6. Place the wheels in the straight-ahead position and lock the steering wheel. Remove the steering column without disassembling it.
    7. From under the driver-s side of the instrument, disconnect or remove the following items:
      Parking brake release handle linkage rod from the parking brake mechanism located on the left cowl side inner panel. Instrument panel wiring harness connector from the parking brake switch located on the parking brake mechanism. Three wiring harness connectors (body wiring harness, headlight, dash) from the 3 junction block connector receptacles located closest to the dash panel. Head light/dash-to-instrument panel bulkhead wiring harness connector screw and disconnect the connector. Instrument panel-to-door wiring harness connector located directly below the bulkhead wiring harness connector. Infinity sound system wiring harness connector (if equipped), located at the outboard side of the instrument panel bulkhead connector. Stop light switch electrical connector. Vacuum harness connector located near the left side of the heater/air conditioning housing.
    8. Under the passenger-s side of the instrument panel, disconnect the radio antenna coaxial cable connector.
    9. Loosen both sides of the instrument panel cowl side roll-down bracket screws about 1 / 2 inch (13mm).
    10. Remove the 5 upper instrument panel-to-upper dash panel screws; remove the center screw last.
    11. Roll down the instrument panel and install a temporary hook in the center hole on top of the panel. Attach the other end to the center hole in the top of the dash panel. The opening should be approximately 18 inches (46cm).
    12. Disconnect the instrument panel-to-heater/air conditioning housing assembly wiring harness connectors.
    13. Using an assistant, remove the instrument panel from the vehicle.
  4. If equipped with air conditioning, perform the following procedure:
    1. Discharge and recover the air conditioning system refrigerant.
    2. Disconnect the refrigerant lines from the evaporator. Plug the openings to prevent contamination.
    3. Disconnect the refrigerant lines from the accumulator. Plug the openings to prevent contamination.
    4. Remove the accumulator.
  5. Drain the cooling system into a clean container for reuse.
  6. Disconnect the heater hoses from the heater core tubes.
  7. Remove the PCM from the dash panel and move it aside. Do not disconnect the PCM harness connector.
  8. In the engine compartment, remove the heater/air conditioning housing assembly-to-chassis nuts.
  9. In the passenger-s compartment, remove the heater/air conditioning housing-to-dash panel nuts.
  10. Pull the heater/air conditioning housing assembly rearward far enough to clear the studs and air conditioning drain tube holes.
  11. Remove the heater/air conditioning housing assembly from the vehicle.
  12. Remove the upper-to-lower heater/air conditioning housing screws and remove the upper housing.
  13. Remove the heater core from the lower housing.
    Fig. View of the heater/air conditioning housing assembly
    0900c15280225dc3.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. View of the heater core
Apr 07, 2009 | 1997 Dodge Ram
Power steering pump
This removal is rather involved: use a turkey baster to suction out PS fluid,disconnect neg battery cable, remove serpentine belt, raise vehicle, support on jack stands, disconnect Oxygen sensor wiring harness from vehicle wiring harness, (access to this connection is thru the wiring harness grommet in the floor of the vehicle) remove catalytic converter from the exhaust manifold, remove exhaust system hangers/isolators from the bracket on the exhaust system, move the exhaust system as far as possible to the rear and left side of the vehicle, remove accessory drive splash shield, detach the ps supply hose coming from the fluid reservoir, from the fitting on the ps pump, plug the hose to prevent fluid leaking all over, remove ps pressure line from pump, plug this line also, remove ps return hose, plug line, remove nut attaching pump (@ rear of pump) to mounting bracket, loosen 3 bolts at front ps bracket, remove pump and bracket as an assembly, now remove 3 bolts and separate, reverse to install. Yes, it's a b-itch. good luck, countrycurt0
Oct 07, 2008 | 1996 Plymouth Grand Voyager
Does my range have a disconnect plug?
If there was a disconnect plug it would be located either under the cook top, or inside the console. The plug is generally square white plastic. The illustrated parts breakdown at searspartdirect.com was inconclusive. It did not show any disconnect plug, but it also didn't show the wiring harness either. If there is no disconnect on this model, simply disconnect the terminal lugs at the element you are replacing. Just be sure to write down where they connect to (HINT: a digital camera also comes in handy), and make sure you disconnect the power cord BEFORE opening the appliance. There's still power present with the stove turned off. Good luck and let me know if I can help you further.
Apr 19, 2008 | Kitchen Ranges
Frigidaire GLTF2940ES Front Load Washer Logo
19 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
