Question about LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
My dishwasher wont empty of water
Why won't the dishwasher drain the water out of the machine, how do we clear the blockage in the pipe?
4 Suggested Answers
  • 3230 Answers
SOURCE: lg - LDS5811ST Dishwasher OE Error Code
hi
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Posted on May 06, 2009
heatman101
  • 43501 Answers
SOURCE: the water will not drain out of dishwasher
Here is a tip that I wrote that will help you with your problem...
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Apr 18, 2010
SOURCE: i have LG LD 2040
I traced the fault to one resistor on the controller board and replaced it for R0.10. The original quote to repair was R1480.00! So I saved myself a handsome amount, no thanks to LG!
Posted on Dec 28, 2011
Fixya login
Unfortunately this sounds like more than a blockage. If this was a blockage water would not drain, maybe fill in sink or dishwasher etc. If water is coming from walls probably means it is leaking from drain pipe in the wall. Which would mean opening wall to find leak.
Aug 14, 2013 | Mountain Plumbing Plumbing
Duets washer won't drain
Probably a blocked filter, outlet pipe or pump.
Take the drain hose and lay it flat and lower then the level of the drum and this will drain the machine providing the blockage is not solid. When machine is empty check filter , pipes and pump and remove any blockage found.
Replace drain hose and you should then be able to carry on with your wash or spin the clothes.
Dec 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Dishwasher completes programme but does not pump water away
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Feb 13, 2011 | Bosch Dishwashers
Drain pump running when unit starts but no water to appliance
The machine probably has water in the base (not visibly in the machine, but in the base where the conponents are). Pull the machine out, sit the front on a large towel and holding the back of the d/w pull it towards you. Any water trapped in the base will drain out. It may be a fair amount as the flood safety switch will activate on approx 1.5 ltrs. Once you've cleared the water run a prewash or quickwash to check d/w. Hope this helps.
Jul 05, 2010 | Bosch SHU5315UC Dishwasher
I have a Zanussi DE6850 free-standing dishwasher. Have just put on a 65 degree programme. After approximately 1 minute the machine has stopped functioning and the top two lights are flashing and water...
You seem to have a blockage,have you checked the filters lately.Also check the drain hose and the pipe that the drain hose goes into,if they are clear then the blockage is down in the bottom of the dishwasher in the pipes or the drain pump.
Hope this helps.
May 21, 2010 | Zanussi 24 in. DE6850 Free-standing...
My trusty Bosch s510 Dishwasher which has been going strong for about 17 years (at least) has just decided not to empty itself. I noticed the bottom was full of water after a wash. I emptied all the water...
Same problem, so went out and bought a new bosch. Problem with the S510 was cured by lubricating the pump out motor bearings with a squirt of WD 40. If you don't know which pump, follow outlet hose to pump outlet.
Les
Aug 15, 2008 | Bosch Dishwashers
Tecnik dishwasher tkd795/3
your machine has flooded and has trippedthe flood switch in the base of machine which turns on the pump to drain and that is the noise you hear
you will need to find cause of problem which is possible leak in machine
Mar 21, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Pump won't stop draining
you will almost certainly have a build up of water in the base. remove the water and retry. check to see if limit switch is not sticking or has possibly gone faulty.failing this, your board is faulty.
Sep 23, 2007 | Bosch 24 in. SHE44C05UC Stainless Steel...
Shu9915uc dishwasher wont drain
it should have water just below filter tray, if it does not actually empty then you have a blockage ,remove left side panel to gain access to drain pipe and side chamber. Regards Engineer
Aug 05, 2007 | Bosch SHU9915UC Dishwasher
LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Logo
19 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
