Question about Frigidaire FAH106N1 Wall/Window Air Conditioner
My fridgidare window unit lra12hzt2 is not cooling its only a couple of years old. any suggestions?
Haier window ac constant red light? No label next to red light. Turns on and off fine. Cleaned filter, no change. couple years old. Still cools down the room but not as cold as it used to. Help?
Sounds like the unit is just dirty. The AC pulls air through coils and contains dirt, pollen, grease and all type of pollutants. These contaminants will cling to the coils, reducing the AC ability to transfer heat.
Here's a great YouTube video explaining how to properly clean a window AC. How to Clean Window Air Conditioner
AC units should be cleaned every year (including the whole house units), to maintain their ability to cool efficiently.
Aug 13, 2016 | Haier Heating & Cooling
What could be the problem with my Magic Chef mini fridge model number MCBR465S. It comes on when I plug it in but not cool at all, and the compressor hot, could I trouble shoot and how,freon? Thx
If the compressor is actually running and there is no refrigeration, I would suggest it has a gas leak and that's why it isn't cooling. Depending on what type of refrigerant is in it, it may not be worth repairing as its only a small bar fridge? Check the rating plate to see if its R12 (Older fridges) or R134A . If the unit is less than 5 years old, it may be operating on R32 or R600 (Butane refrigerant gases) If its only a couple of years old, it may still be under Manufacturer warranty. Most fridges carry a 2 year warranty on everything and up to 5 years parts warranty on what is known as the "Sealed system"
Apr 19, 2015 | Magic Chef Refrigerators
How do I fix heat on unit Frigidare Model LRA12HZT2?
There are no heating strips within this unit. This unit has a heater part 5304476390 that you would need to replaced upon a diagnosis.
Dec 24, 2012 | Frigidaire FAH106N1 Wall/Window Air...
Fridgidare washer front load won't spin & there's water in the tub. It's about 10 years old
If it's that old, you're better off buying a new unit. You'll spend about half the cost of a new one fixing it.
Jun 11, 2012 | Washing Machines
My dryer will not start. When I push the star button everything lights up but it will not start. It is a fridgidare and about 6 years old. It is an energy efficient Fridgidare.
Open the door, push in the door switch, press the start button and rotate the tub with your hand. If it starts running you have a bad motor. BE CAREFUL and this is obviously easier with 2 people but is possible with 1. Thanks for rating me after you view this.
Dec 12, 2009 | Dryers
Window air cond unit, several years old, doesn't blow as cold
The problem with window units and any service tech will tell you it cost more to repair than you can buy at Walmart or home depot. Unless you know someone who can charge it for you. Window units are a sore subject. A 200 dollar window unit might cost 200 dollars to charge system. SORRy rusty
Jun 13, 2009 | Maytag M6X06F2A Air Conditioner
Suddenly stopped cooling
Sounds to me like the run capacitor is bad. It is a dual one which means runs the fan and the compressor. No big deal capacitors are only 10 bucks and easy to replace.
First turn off the electricity to unit at breaker would be best. Next after you open the access panel locate the capacitor and make a note which wires go where one side is marked fan the other is herm. in the middle is comm. Take the old one in and get a new one same size and reinstall. Now parts only have one year warranty but they should have a discount on a person that bought a unit from them if you talk to them and tell them how can this happen only 2 years old. you know the story they might just throw one in for free to keep good business practice. Let me know how it goes. ken
Apr 16, 2009 | Intertherm P3RA-060K Air Conditioner
No longer cool
If the unit is operating normally but not cooling properly than you are low on refrigerant.
Oct 01, 2008 | Haier HWR06XC5 Wall/Window Air Conditioner
Dandy 8.8 fridge not working but freezer does
freezer works but fridge wont cool
Aug 29, 2008 | Freezers
Frigidaire FAH106N1 Wall/Window Air Conditioner Logo
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Donni Steen
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
