Question about Solis Maestro Electric Burr Grinder
Solis grinder burr removal
Want to change blades
z34aga
  • 137 Answers
SOURCE: Burrs
you can see at
http://www.youtube.com/watch?v=qu4t1uzOrF8
just you need to continue opening 2 part more than in 5 min and 40 sec, there you go further than the video shows.
Posted on Mar 29, 2009
z34aga
  • 137 Answers
SOURCE: how to take apart a solis conical burr coffee
i think it will help the solution that i give before:
http://www.fixya.com/support/t309782-burrs
Posted on Apr 01, 2009
  • 1089 Answers
SOURCE: Starbucks Barista Burr Grinder (Solis 166) motor does not run
Hi
Remove bean hopper
Remove grounds hopper
Remove timer knob on the side
Turn the grinder upside down
There are 4 slits on the outside edge.
Insert a screw driver into the **** and pry gently outward with a
little downward pressure on the outside until the side slips a bit.
Repeat on all 4 slits and the shell should slide off.
There is a fuse on the side of the motor that will blow and stop the motor. It is a thermal fuse and should be replaced by a qualified tech.
Posted on May 26, 2009
  • 1089 Answers
SOURCE: I can't remember the simple key to disassembling
Hi
Rotate the bean hopper counter clockwise until it stops. Lift the bean hopper out. Remove the outer burr with the wing-lets. Can go back in either way. Clean with air or vacuum out grounds. Use small brush to help clean grounds. Reinstall burr. Line up notches of the bean hopper with shell ( large tab in large slot, and small tab in small slot). Rotate bean hopper clockwise a small amount and test.
Posted on Nov 10, 2009
  • 1089 Answers
SOURCE: My Solis Maestro takes a
HI
Yes the burrs will wear out. They can be replaced. To remove the outer burr. Twist the bean hopper counterclockwise until it stops. Lift the bean hopper out. There is a cream colored ring with 2 tabs that will lift out holding the outer burr. To get the inner cone burr out is a little more difficult. We use a vice grip and grab the burr, and lock the pliers to it. Then with a quick movement clockwise on the pliers, you loosen it. Then clockwise unscrew the burr. When you install the new burr, it truns on counter clockwise until it stops. Insert the new outer burr. Push down so the tabs will lock in. Install the bean hopper into the correct slots ( 1 large tab and 1 small tab). Twist clockwise to turn on and test. Remember it must be grinding to turn to a finer grind but can be turned to a coarser grind any time.
Posted on Jan 24, 2011
My Solis Maestro takes a long time to grind and no longer grinds for espresso. How do you remove the burrs to clean them? Should they be replaces?
HI
Jan 24, 2011 | Solis Maestro Electric Burr Grinder
What do you do when the grinding blade will not come off for cleaning?
Hi
With the bean hopper on, turn the grinder upside down. Rotate the bean hopper to loosen any grounds that might be holding the burr holder. Now remove the bean hopper and try again to remove the holder. Only the outer burr comes off, this way.
Jul 19, 2010 | Solis Maestro G385 Electric Burr Grinder
Timer knob is broken, I need a replacement
Hi Contact Baratza at 877-701-2021 They should be able to help.
Feb 06, 2010 | Solis Maestro Electric Burr Grinder
Cleaned the Solis Maestro grinder and re set it to a fine espresso setting but the grind is coming out very course. What should i do?
Hi Your burr is not locked in. You need to remove the beans from the hopper. Remove the hopper. Remove the burr. Turn the grinder upside down over the trash can. Put the burr back in only make sure that the burr is down. Install the bean hopper and when you turn the bean hopper it should move the burr. Then you can adjust your grind. Make sure that the grinder is running is your going to a finer grind or you could break the grinder. You can turn it to a coarse grind any time.
Jan 12, 2010 | Solis Maestro G385 Electric Burr Grinder
Oily beans seem to have clogged our coffee grinder up. What can we do?
Rotate the bean hopper counter clockwise until it stops. Lift it off. Remove the outer burr with the 2 wings and clean under the burr. Clean the opening going to the chute for ground coffee(inside where the burr was).
Install the outer burr. Install the bean hopper. Rotate the bean hopper to the French press grind (coarsest) and operate the grinder. This will clean the burrs and the passages. If it starts to clog, repeat the last part to clean the burrs and passage. It must be grinding to go to a finer setting, but you can go to a coarser setting any time. Another thing. Turn the grinder upside down (empty) and rotate the bean hopper back and forth to clean the threads of the adjusting burr..
Dec 20, 2009 | Solis Maestro Electric Burr Grinder
Remove the inside conical burr
Hi
Try wrapping some leather, cardboard or cloth around the burr before putting the vice grips on and then it is a quick twist to break the burr loose.
Nov 28, 2009 | Solis Maestro Electric Burr Grinder
I can't remember the simple key to disassembling the Solis Maestro for more thorough cleaning. I need to get beyond the top burr removal stage.
Hi
Nov 10, 2009 | Solis Maestro Electric Burr Grinder
Clogged
The burrs need to kept clean otherwise it will create a lot of dust and jam it up. This is aggravated with oil coffee and flavored coffee. Thoroughly clean the burrs and chute.
Aug 24, 2008 | Solis Maestro Electric Burr Grinder
Burrs
you can see at
Dec 22, 2007 | Solis Maestro Electric Burr Grinder
Solis Maestro Electric Burr Grinder Logo
74 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
Colin Stickland
Colin Stickland
AZBen
AZBen
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
