Home | Heaters | Cadet heater quite wor...
Heaters
Problem for Heaters
Generic problem for all Heaters
Cadet heater quite working
By greek1 on Nov 03, 2007
I've got a Cadet C122 wall heater that quite working. There's 240V to the heater and continuity across the reset switch. No continuity across a round metal device that's at the top of the heater above the coils. Is this normal or is this a shutoff device that can't be reset? If so can it be replaced or do I need to replace the heater? Thanks!
Comments:
Nov 04, 2007
Thanks, Buffalo12980! The element tests good so I'm off to find a klixon overload. I really appreciate the help!
greek1
Same Problem
Mar 11, 2009
-   heater just quit workin-   Guest
Best Solution
posted on Nov 04, 2007
Very Helpful)
Buffalo12980
Rank: Wiz
Rating: 84%, 1049 votes
that round metal thing is called a klixon overload. look on the side of it and an amperage range should be there. replace the unit and the element should work unless the element itself is blown. check for continuity across the element with your meter with the wires disconnected.
Was this helpful?
Yes
No
Popular Solutions for Heaters
Questions and Unsolved Problems for Heaters
Answer
What is the best portable heater for a 700 sq ft area
Answer
how can you buy things for less than what they ask for?
Answer
Need error codes for Fujitsu Halycon Mod. No. ASU12RLQ (1-ton ductless heat pump split system)
Answer
One panel does not glow red. The gas just burns blue around it.
Answer
i have a model sr30p it has 5 separate heating elements 2 on the left side have a blue flame instead... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Heaters:
Top Heater Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Heater Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
