Question about Echo Chainsaw Cs-370
How do the fuel lines hook up on a cs 370 echo chain saw
  • 63 Answers
SOURCE: Echo cs-341 stalls out when cutting sideways
Make sure the fuel filter is indeed attached to the fuel line in the tank and pushed down to the bottom of the tank.
Posted on Mar 16, 2009
  • 398 Answers
SOURCE: need to know oil to gas ratio mix for echo 510 evl chain saw
50:1 or of its old 100:1
Posted on Mar 20, 2009
dontbother10
  • 2220 Answers
SOURCE: How do I change the primer bulb on my Echo CS-3000
The IPL for an Echo CS-3000 is here:
http://www.echo-usa.com/pdf/documentation/CS3000T1T1E_081303.pdf
See page 8. There is no shop manual offered, you will need to interpret the pictures. Didn't look to difficult. GL
Lou
Posted on Sep 07, 2009
Testimonial: "Having the parts list helped me to understand how the primer bulb was installed. A great help. Thanks, Ed"
dontbother10
  • 2220 Answers
SOURCE: trying to replace gear on echo cs 440 chain saw
The IPL for a model 400 Echo can be found here:
http://www.echo-usa.com/pdf/documentation/CS400_C090_11_081007.pdf
It should not matter but please verify this fits your serial number.
From the IPL your saw has an outboard clutch. Use this the following as a guide. I didn't see any special tools on the IPL.
R² Drive Link Outboard Clutch
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check at the IPL for your saw to see if any special tools are needed.
  2. A length of starter cord or nylon rope may be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. It is probably a left handed thread (tighten it to loosen it).
    Let us know how it worked for you. GL
    Lou
Posted on Sep 13, 2009
  • 4088 Answers
SOURCE: Chain brake jammed on Echo CS400 chainsaw
You will need to release the brake by applying a very heavy screwdriver to the + shaped part of the brake coupling. Check the action of the brake handle and duplicate it at the the +. Hope this helps!
Posted on Jun 26, 2010
How do you hook up the fuel filter line inside the tank on a cs400
If you go online and search for the drawings for that saw you will see that the fuel pipe enters the tank at the top through a grommet. You will have to pop out this and then pass the pipe through this after passing it up through the hole from inside, long nosed pliers or tweezers will assist. Once you have that done stuff the grommet back into the hole and don't pUll it out again!!!!!!!!
Apr 03, 2015 | Echo Chain Saw. 18 in. 40.2 cc Gas Chain...
My Echo CS 3400 chain saw has an air vent problem
Most handheld power tools have a tank vent that will hold some pressure, Don't quote me. But If I turn the saw sideways and the vent allowed fuel to drain out THIS WOULD CREATE A FIRE HAZARD. If the fuel is boiling when you open the fuel cap could this be a engine temperature problem? or low octane fuel.
Apr 07, 2014 | Garden
How to change the fuel filter on an Echo 315
Im going to assume that this echo saw is the same as most saws. Open your fuel tank and remove the cap completely. Empty the fuel from the tank, and try to swirl around the fuel to get the last bit out and any dirt that might be in the tank. Compressed air can be used to blow the tank out or flush the tank with some more fresh fuel. This is important to help your new fuel filter last longer and also the reason why the filter would need replacing. Using a length of wire, coat hanger or smaller, make a small hook on the end, small enough to get into the fuel tank, big enough to fit around the fuel line. Place the hook in the fuel tank and fish out the fuel line and the gently remove the filter from the tank, its on the end of the fuel line. Pull the old filter off and push the new filter on, Place back in the tank, Fit the fuel cap chain and fuel cap. Job done. Hope this helps
Oct 04, 2013 | Echo Chain Saw Service Repair Manual...
Brand new Echo cs-400 chain saw: The chain spins fast on idle. Should'nt the chain be stationary on idle?
The manual is available here:
http://safemanuals.com/user-guide-instructions-owner-manual/ECHO/CS-400-_E
The idle speed of the negine may be too high.
Page 26 of the manual gives instructions for adjusting the speed with the "T" screw on the carburettor.
May 12, 2011 | Echo CS400 18" Chain Saw
Chainbrake spring broke need new one
Parts Catalogs Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04511001001 - C04511999999 Language: English Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04612001001 - C04612999999 Language: English Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04713001001 - C04713999999 Language: English
Jan 05, 2011 | Echo CS310 14" Bar Length Fully Assembled...
How do you find and change the fuel filter on an echo cs-350wes
The filter should be hanging from a length of fuel line within the fuel tank. Drain the fuel to see it. Fish the filter out with a hooked piece of wire. If it is lying loose in the tank, then the fuel line is in trouble and should be replaced. In that case, check the condition of all of the fuel lines. Hope this helps!
Oct 20, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
ECHO CS 3000 chainsaw-while idling, shuts off if held on an angle
The idle speed screw may be set too low--adjust so that the chain stops moving, but the engine keeps running. Drain the fuel tank and see if the filter falls to the lowest point of the tank whatever the position. If it doesn't, replace the fuel line hooked to the filter as it may have lost flexibility. Hope this helps!
Apr 11, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Mar 14, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Echo Chainsaw Cs-370 Logo
59 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
