Question about Refrigerators
Where is the drain tube located - Refrigerators
    Sergeant:
  • 175 Answers
Hi..The refrigerator drain is either located on the floor of the
refrigerator beneath the vegetable crisper or in the wall behind
the drain funnel.
check it out..
thank u..
kindly rate my response..
Posted on Jun 22, 2009
Where is drain tube for A/C located 2000 S70
You may have debris clogging the drain tube.
Look for debris in any depression running below the windshield.
The drain is normally found there.
Jun 04, 2015 | 2000 Volvo S70
Frig-freazer. mannfactured 03 collecting water
The drain tube is attached to a tray at the base of the evaporation coils on the rear wall of the freezer section. You gotta remove the access panel to find and clear the drain. I recently worked on a frigidaire model and made a crude video:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 17, 2013 | Frigidaire Refrigerators
I have a 2006 saturn ion 2. Just recently, my ac is draining into the passenger floor board. How do i fix this ?
Bulletin No.: 03-01-39-011B
Date: November 22, 2005
TECHNICAL
Subject:
Water Leaks Into Passenger Compartment Through HVAC Module Condensate Drain Tube When Parked on Incline/Uphill Position (Install Auxiliary Drain Tube Extension)
Models:
2003-2006 Saturn ION Sedans and Coupes
Supercede:
This bulletin is being revised to include the 2005 and 2006 model years. Please discard Corporate Bulletin Number 03-01-39-011A (Section 01 - HVAC).
Condition
When vehicle is parked on an incline with the front end up during a rainstorm or when driving uphill during a rainstorm, water may leak into the passenger compartment through the condensate drain tube opening of the HVAC module.
Cause
Water may drain out of the cowl drain, then drain down the front of the dash panel in the engine compartment and seep into the HVAC module condensate drain tube opening. The water then collects in the heater core cover and upon acceleration may leak into the passenger compartment through the heater core cover seams.
Correction 1. Open the hood and locate the HVAC module condensate drain tube in the engine compartment on the right side of the dash panel.
Important: During installation of the auxiliary drain tube, do not make contact with the HVAC module foam gasket located at the base of the HVAC module condensate drain tube. If the auxiliary drain tube is pushed on too far and makes contact with the foam gasket, water may leak into the passenger compartment.
2. Slide the auxiliary drain tube onto the HVAC module condensate drain tube and make sure that the auxiliary drain tube is angled downwards after installation.cansmo_121.gifcansmo_122.gif
Aug 28, 2011 | Saturn Ion Cars & Trucks
Cant find ac drain tube
Pull the carpet down in the passengers foot well and locate the evaporator drain in the housing.
Drill a 1/4 inch hole in the center of the drain tube housing as shown. Clear the drain tube with a wire or suitable tool by inserting it through the hole and into the drain tube.
Insert plug, P/N5255217 into the 1/4 inch hole drilled previously. Verify that the drain is clear by operating the system in the A/C mode and observing that water is draining.
Hope this helps.
Jul 05, 2011 | 2007 Jeep Grand Cherokee Overland
When the sc fan is switched on I have water running into the passenger side floorboard
your a/c drain tube is blocked you need to locate drain tube and pick out the blockage, drain tube located in engine bay above passenger side chassis leg
May 30, 2010 | 1998 Jeep Wrangler
Wet carpet (driver's side) in a 2002 Nisan Pathfinder
drain tube located under the holding tank replace tube will fix problem
Jul 22, 2009 | 2002 Nissan Pathfinder
We have ice in feezer and water dripping into refrigerator section. I think the drainage tube is cloged. How do I access and fix problem?
hi thanks for the question yes the drain tube is clogged . turn power off pull fridge from wall clean all coils locate drain tube in the drain tray let fridge thaw with doors open once thawed clean drain tube thanks the appliance doc
Sep 28, 2008 | Whirlpool Refrigerators
Refrigerators Logo
215 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
