GE Heavy duty super capacity top loading washing machine: when turned on and water is pouring in, it had started to make a noticeable buzzing noise. Does anyone else knows if this is the water inlet valve going bad? Machine is 9 years old.
    Habit-Forming:
  • 88 Answers
Sounds like inlet solenoid valve fault
Posted on May 09, 2014
4 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Whirlpool heavy duty super capacity plus machine slow to fill.
This problem is commonly attributed to a water inlet valve that has become clogged with sediment or calcium deposits over time. If you live in an area that has hard water, or if you use well water, this is a common problem. You can remove the valve and attempt to clean it by soaking it in a 50/50 solution of distilled vinegar and water, or you can simply replace it all together. If you're going to go the route of removing the valve, it makes better sense to replace it, rather possibly having to repeat the steps again if cleaning the valve doesn't work. The following link explains how to access and replace one:
http://www.fixya.com/support/r3575881-replacing_water_inlet_valve_on_whirlpool
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
I have found these sites to be reputable and provide great service. Prices differ between them, so shop and compare. If you do not wish to order parts on line, look up the part numbers on the Sears site and check with your nearest appliance parts retailer. These is a common part that may be commonly found in their in-store inventory. The average cost is about $30 - $35.
If you DO wish to attempt to clean the valve to save some money, submerge the valve in a 50/50 solution of distilled vinegar and hot water for about 30 minutes and flush with clean water. DO NOT submerge the electrical connections.
You may also try any number of calcium, lime and scale removers on the market. CLR comes to mind as a good product, but use in a well ventilated area. It has some very strong fumes.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Posted on Mar 18, 2010
Testimonial: "Great advice. I will follow your clear and easy steps. Sounds like one or the other solution will be fine."
  • 1531 Answers
SOURCE: Washing machine will not aggitate.
if it fills with water then stops check you lid or door switch. will the unit drain or spin if so the the timer may be bad
Posted on Sep 16, 2009
MNTECH
  • 1543 Answers
SOURCE: GE super capacity heavy duty washing not filling w/hot water
On an older model washer, you probably have a bad water valve. (hot water solenoid coil electrically " open ") Newer models, now there's a can of worms. Some models use thermistatically controled water valves to limit water temps, so you may not be able to get true hot water. Also, if you are checking the temp as the machine fills, some models will only fill with cold if the lid is open. (safety feature) The only way to see what is really going on is to fill the machine with cold and use a thermometer to check the water temp, then, pump that out and fill (with the lid closed) with hot and check to see if that temp is higher. As stated previously, water temp may not really be " HOT " but may be warmer than " COLD ". That may be as good as you will be able to do, as all manufacturers are trying to reduce energy consumption. Thank your government.
Posted on Jan 21, 2010
I have kenmore 80 series heavy duty/ super capacity plus washer that after it fills with water,hot or cold and it starts the wash cycle, I noticed that the agitator only moves once in awhile and stops
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
Feb 17, 2015 | Kenmore Washing Machines
Heavy duty super capacity plus
You dont. If it is making noise drum bearings or idler needs replaced
Nov 03, 2013 | Kenmore 24032\24036 Top Load Washer
Sep 16, 2009 | Washing Machines
GE washer agitates but won't spin
I think you may have a stopped up pump does it drain the water out if not it will not spin. A putty knife inserted 2 inches in from each side will release the spring catches and gently pull on front as you release sprins then look to the bottom right hand side and there is the pump clamp the tub to pump hose or **** water out with a shop vac take off tub to pump hose and then two 3/8 in screws that hold down the pump turn over where you can look in the pump may have an obstruction as always disconnect power before service.
May 30, 2009 | General Electric WHDSR209DWW Top Load...
Won't spin or agitate
coupling.between motor and gearcase.
Nov 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Washer Model LSL9244EQO
shut off water remove rear hoses pull screen from inside opening and clean ..BE SURE TO REINSTALL SCREENS..if still slow or stopped altogether replace fill valve..remove rear screws in console lift and roll console back unplug lid switch pop the clips on each corner up and off cabinet will lift off valve is top right side
Aug 06, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Super Capacity stuck on rinse
Krom, sounds like the machine is syphoning. Check the drain hose and make sure there is a air gap and that it is not too far down the standpipe or drain. To test it hold the drain hose right at the drain top and see if the problem stops...Catriver...post back.
Jan 18, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
