Question about Goldstar R7003 Air Conditioner
Goldstar R0800m how to take off front panel. - Goldstar R7003 Air Conditioner
My goldstar dehumidifier does not shut off when full, cannot adjust the control panels
There has to be a float switch or sensor that detects the full condition. You may find that the non-functioning control panel is the cause of the problem so the next step is to find out why the control panel does not work.
Sep 10, 2012 | Goldstar DH504EL Dehumidifier
I have a goldstar dehumidifier that runs for a couple min. then turns off. I unplugged the rheostat wires from the mother board and it runs just fine. Does that mean if I replace the rheostat switch the...
Runs for a few minutes then shuts off, easy fix. First, remove water catcher and slide filter out and clean it. Then find the two screws that hold on the front panel remove front panel. Make sure the unit is un-plugged. The humidity control dial has two wires connected to it. clip the inner wire. This will keep the unit on full. You could replace the humidity control dial, but why bother?
Dec 12, 2011 | Goldstar DH304 Dehumidifier
Power is on, lights and front panel work, just no heat
There are a few definite causes but if you would like to rectify problem without messing around, i wold replace magnatron: capacitor and HV diode.That will certainly sort the problem out.
Sep 25, 2009 | Goldstar MV-1501 Microwave Oven
Goldstar 10000 blows water out front
Two possible problems.
1. High humidity in the space being cooled
2. Drain line that runs from the front (where the water is blowing out) to the back where it is sent to evaporate. Clean out the drain line and condensate pan under the fins where the water is blowing out.
Jul 10, 2009 | LG Goldstar GWHD5000 wall/window Air...
Panel controls don't work
front panel is damage, need to replace
Jun 02, 2009 | Goldstar MV-1615 Microwave Oven
Do you know what the wattage is of the Goldstar MA-685M Microwave Oven? I checked the back panel and the door panel and it is not listed there.
600 watts, according to the repair manual.
Sep 27, 2008 | Goldstar MA-685M Microwave Oven
Front panel removal
You should see the tabs near each corner on the top and near each corner on the sides up towards the top. What I recommend is pull out slightly where you removed the screws. Then when you look closely you will be able to see the tabs. Once you see the tabs you can compress them with a small flat head screwdriver.
Jul 05, 2008 | LG Goldstar LD65EL Dehumidifier
Goldstar MV154SJ Over the range Microwave oven
check the touch pad , and check the control panel...
Sep 23, 2007 | Goldstar MV-1501 Microwave Oven
Goldstar R7003 Air Conditioner Logo
145 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
