Question about Kenmore 62802 Electric Dryer
Drier is all of a sudden no heat
IS it the element?
    President:
  • 632 Answers
Check continuity of plug cord and fuses..
Posted on Jun 22, 2009
Bosch next 500 plus burning smell in dryer
Sounds like to me, but I'm no expert, the heating element is "over-heating and not getting the m"air" it needs to cool down enough to keep from burning. Literally I mean burn because the way a drier works is there is a fan at the heating element to blow the heat from the element to dry the clothes and if the fan is filled with lint it can't blow much air across the element and causing it to have the burning smell. I would check the fan blades and those are usually connected directly to the drier drive motor. I wouldn't use the drier until issue is resolved for the reason being is you can burn out the element and have to replace it too. Hope this helps you in you quest to the repairs of you drier :o) Jesus loves you John 3:16-17 (KJV)
Jun 16, 2018 | Bosch Dryers
I have a Whirlpool LER4634PQ1 it was working just fine then all of a sudden the dryer just keeps running the knob on the dryer doesn't move and the air isn't warm. Any suggestions on what to s
there is a cycling thermostat in line with the high limit thermostat and timer circuit,on timed dry its disabled and the timer will run no matter what,on any sensor dry setting it uses the heat of the element to heat this cycling thermostat to move the timer as the clothes get drier as the heating element heats the timer doesn't move,when the heater cycles off from the high limit thermostat then timer moves again,you need to find out if its a bad heating element,thermal fuse or possibly even a circuit breaker in the homes electrical panel tripped out on one of the 2 phases that gives you the 240 volts required to operate the dryer element,the breaker may not show its tripped,so shut it off and back on and try this first
Dec 11, 2012 | Whirlpool Dryers
Heating element out, we think. No heat when turned on. My husband cannot figure out how to get to heating element to repair/change.
You access the heating element through the back of the drier. Pull the drier out from its resting place, un-plug it from the wall. Remove the back and look for a removable plate that will have wires mounted to it. That should be the heater coil / element. First find your make and model numbers, find a local appliance parts store, call and see if they have one and how much they cost. They will even have books that tell you how to fix it yourself. Hope this Helps FixYa up..
Aug 23, 2011 | Dryers
Strucke
If the drier is electric then more than likely the heating element has burnt out. This element is located at the bottom of the drier and can be accessed through the back. The element looks just like a toaster element. Take the model and serial #'s to an appliance parts house for the correct replacement part and you should be good to go. It is fairly simple to replace as you will see once you take the back of the drier off
Good luck hope this helped
Dave
Feb 24, 2010 | Kenmore 500 6952 Dryer
Hotpoint condenser drier - not heating up
I am going to attach a link to a video that I would like you to take a look at. Many dryers are similar in setup and this may help you will the heating element. Sure hope it does and best wishes.
http://www.youtube.com/watch?v=f1rebeCMVsk
Sep 01, 2009 | Dryers
Hotpoint CDT00 Tumble Drier has No Heat
you need to check the heating element also check the front drum supports they ussually wear out causing the tub to rub the element this causes the element to burn into
Jul 11, 2009 | Dryers
Amana electric dryer will heat but only when.../ LEA60AW
It seems there is some wire loose, check on the both side of heating element points.
The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter.
Good Luck!!
Thanks
Jun 22, 2009 | Amana Dryers
Roper electric drier will not turn off or heat happened suddenly
Replace the heating element. Located in the backside of the dryer
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 04, 2009 | Roper REX4634KQ Electric Dryer
Need a diagram to change heating element and sensors
unplug the drier pull it out from the wall about a foot facing the drier take a small putty knife and insert it about 3" from the edge push the knife in till you feel the spring clip push in on it and lift the top then repeat that on the other side fold the top back till it leans against the wall look in the drier on the front edge of the front door panel there are two 5\16 in screws there remove them and un plug the light switch and the door switch assembly .grasp the front door panel and give it a quick snap forward to disengage the retaining clips and the door from the drum remove the door .Lay on the floor reach in and remove the belt from the idler pulley and blower motor pulley .Then while standing at the side of the drier grasp the belt with one hand and the front of the drier drum with the other and **** up sharply on the belt to release the drier drum from the rear drum bearing then remove the drum out the front on the rear you will see the heating element there will be one sensor on the heater pan that's the safety or high limit thermostat the tiny one on the drier body is the thermal overload the one on the vent at the bottom is the operating thermostat but its rare to have a problem with them if the drier is not heating the first thing i recommend is check your voltage and connections and don't assume just because its running its getting full voltage check it with a meter driers will run on 110 but will not heat without 220
Mar 10, 2008 | Frigidaire GLER341A Electric Dryer
Kenmore 62802 Electric Dryer Logo
150 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
