Question about Sony Playstation 3 (PS3) Console
White lines appearing on the screen also FIFA 09 problem
Hi.... i just bought a ps3 80GB . I connected it to my TV(3 wires-Red white and yellow) . On the first day it worked fine and on the 4th or 5th day i changed my theme to the Air Paint one...and the next it kept on showing white lines on the TV and a buzzing sound also comes. I really require help. Sometimes my ps3 works fine and sometimes this problem happens. Please help.
And i also bought a FIFA 09 from Vienna Airport.... when i run it on my ps3 the problem i have is that
1. There is no English Language
2. No English Commentry even
HELP!!
Thank You!
    Sergeant:
  • 321 Answers
I dont care and stop asking ps3s are crashing and call sony no one here can fix these problem so save urself time and call sony
Posted on Jun 22, 2009
I have a polaroid hdtv 32gsr3000 and trying to hook up a sanyo dvd to and when we play a dvd it has no coler all black and white we are using 3 cables that came with the dvd player.
Make sure you connected wires right both on player and tv. There are Two ways to connect it.
1. Use 3 wires: white, red, yellow. White and red are for audio and yellow is for video. Yellow need to be connect to yellow port on TV and DVD player
2. 5 wires. Again red and white are for audio. And there is another red plus green and blue. Those 3 are for video and have to be connected to corresponding ports on TV and pkayer. Make sure you don't mix up red wires
Dec 03, 2017 | Polaroid Televison & Video
I have trouble setting up my 50 inch T.V. It is connected to a VCR/DVD player recorder. I have a red, yellow, and white cable. Do I need anything more?
If possible use a AV SCART connection lead as you get audio & video! If you want to use the phono connection you need to connect all 3 red/white/yellow to the TV and the VCR/DVD! Red & white are audio, yellow video!
Dec 19, 2014 | Televison & Video
My dynex tv only shows channel not available message?
Okay- the three cables (red, white, and yellow) are called RCA plug connectors. They are commonly used to carry audio and video signals.
Plug them into your Xbox according to the color codes- red cable connector to the red socket (jacks); then white to white, and yellow to yellow.
Now connect these leads to the RCA input jacks in the back of your t.v. - maintaining the same color code connections (red to red; white to white, and yellow to yellow)
The RCA input jacks on your t.v. should be labeled with an input number, to distinguish itself from the other inputs, like HDMI, S-Video, and such.
After plugging in your Xbox to the wall outlet or surge strip, turn it on.
Turn your t.v. set on.
With the remote control that came with your t.v. set, open the menu bar, scroll to... and open the "External Output" menu.
You should see a list of [however many] inputs your particular t.v has. Scroll to the input number that the 3 RCA cables are attached to, and press that number as the default video screen.
Exit the prompts and your Xbox video screen should be displayed.
Nov 27, 2013 | Dynex DX-LCD32-09 LCD TV
Which cable should be hook up to tv. Trying to hook up DVD player. I have cable with Red, white, yellow.
hi that"s easy thing. first connect rca wire red white yellow to dvd hook up same colour red white & yellow female rca connection. then use another rca wire connect to your tv be video input in yellow one . red & white be sound input - red to red . white to white. just that. good luck!!
Jun 03, 2011 | JVC C-13920 TV
How do i connect the playstation 3 to tv, it was connected to hd tv then we have tryed to connect to normal tv and nothing. please help
You have to connect the wire that has 3 separate wires at the end into your television according to the color. Plug the red wire into the red slot, yellow in the yellow and white in the white. You will then have to take the other end of the wire and plug it into the back of your playstation. Also, make sure to plug your playstation into the electrical outlet.
Jan 08, 2010 | Sony PlayStation 3 40GB System
LCD TV Wii only displays black and white - no colour no sound
You have to option in LCD Source In-Put.All LCD Have this In-Put
Com posit-Yellow/Red/White (AV)
In LCD Select AV Mode After That Connect Yellow /Red/White as per color pin given in your LCD.
Component-Green/Blue/Red
If you have Component in put in your LCD than select from source component mode for Red/Blue/Green.
Dec 26, 2009 | LG 32LG30 32 in. LCD HDTV
How do I connect my Magnavox DVD/VHS player to my Element Flat screen TV?
Do you have a newer TV or a older one lets start with a newer models does your tv have 3 or more jacks on the back or front you should see a RED, YELLOW and WHITE if you have a HDTV you should see more. (LETS HOOK UP) Did your DVD/VCR come with a cables if not you will need to buy at least 2 they are called RCA cables Lets start with the dvd/vcr combo on the back you should see a (LINE OUT) this is where playback or your picture and sound come out. On the back of the TV you should see a (LINE IN) this is where you plug it in to. RED goes to RED, WHITE goes to WHITE and YELLOW goes to YELLOW. To Record you will need to hook up the line in on your combo and the line out to your tv. ( IF YOU HAVE AN OLDER T.V WITH NONE OF THOSE JACKS ) you will need to buy a RF- MODULATOR the are cheap it is a box that let you hook a cable wire to a little box and the RCA jacks to you combo and you will turn your tv to channel 3 or 4
Jul 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Static verticle lines on screen
wiis dont do that but many tvs do im sure its the tv not the wii so it wont matter
May 21, 2009 | Nintendo Wii Console
DVD player won't work on my 27gt615
alexa,
good day, if youre saying that you program the DVD to work on channel 2 or 4 does it mean you convert the signal of your dvd player from A/V output to RF out?
because the simpliest way to connect your DVD player to TV screen is by using RCA cable ( 3 wired cable being color marked as yellow/red/white) yellow = video red and white = audio
the connection would be: from dvd back part you'll see colored socket yello/red and white. connect the RCA to those socket following the same color .
and from the TV screen there should be A/V input socket. can be locate at the BACK/Side or FRONT of the screen marked as
"INPUT" ( AV1, AV2,AV3 if multiple inputs). Then select which input you want to place your DVD player ex.AV1 (from AV1 there will be 3 scoket in a row, yellow/red/white)
Connect the other end of your RCA cable following the same color code to TV "AV1 INPUT" yellow = yello/red =red/white=white. then from the remote commander of your TV screen locate a button marked as "TV/AV" or "A/V" press this button until the screen display switch to AV1.
cheers,
mark
Jan 31, 2009 | GE 27GT619 27" TV
Connect dvd home theatre system to bravia lcd digical tv
Amongst 3 audio and 3 video options on DVD, use only one for displaying picture on TV and one for getting sound.
Yellow Wire is for picture.
Red Wire is for sound.
White Wire is for sound.
Connect Yellow from TV to yellow at DVD
Red from TV to Red at DVD
White from TV to White at DVD
Hope this help.....
hometheaterstore.com
Nov 18, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Playstation 3 (PS3) Console Logo
217 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
