Question about Asko Dishwashers
Why won't asko dishwasher top basket slide open to allow loading of dishwasher
Top basket in asko dishwasher will not open fully
  • 351 Answers
SOURCE: asko d3530 dishwasher
theres two plastic clips at the front of the rails,turn them to the side and the basket will come out
Posted on Mar 02, 2008
  • 52 Answers
SOURCE: particle residue on glasses in top basket for glasses at the corners
The oldest dishwasher I have replaced was a Kithcenaid installed in 1953. It was a 24" built in with a smaller door, a handle looked like it was for a safe, and it had an s-trap underneath. The 90 year old customer said it did the same thing. My advice is to run a dishwasher cleaner through a hot cycle according to manufacturers directions. Check the holes in the spray arms carefully for any debris. Our service guys advise not to use gel or liquid type soap as it leaves a tiny residue after each load which will eventually clog your internal plumbing. Always use the least amount of soap you can get away with and POWDER is prefered.
Posted on May 02, 2009
  • 382 Answers
SOURCE: The top rack on my Asko D1796 dishwasher is defective
call manufactuerer and ask or a good appliance parts and repair they usually are on a spring clip and you just replace the whole roller
Posted on Dec 25, 2009
  • 4088 Answers
SOURCE: asko dw 95.2 model 1705 after 6 years of use the
Check the level and tightness of the slide rails--they may have come loose after the years of use. Make sure the dishwasher case itself is level. Hope this helps!
Posted on Jun 29, 2010
Testimonial: "Thank-you. The unit is perfectly level. The rails are spot welded and all bearing seems to be OK. Nothing to tighten, will investigate further now that I see the system is not complex at all. Thanks for replying so quickly. k"
Macmarkus
  • 2605 Answers
SOURCE: need replacement control selector pad
Hello, Welcome to FixYa.
The part you`re looking for on the Asko 1805, as I understand your description ( please correct me if I misunderstood )...
the overlay/decor insert across the top of the control panel is Asko part # 80-708-88 (then a -0 for white or -33 for black depending on the color the last digit?digits change).
Check "repairclinic.com" part number 764259, retail for approx. $80.
Hope that answer`s your question. Let me know if I can assist you further.
Thank you for choosing FixYa today.
Please take a moment to rate the information I provided for you and a testimony if you fell it`s warranted.
Good luck.
Regards,
Macmarkus :)
Posted on Sep 04, 2010
Testimonial: "Very helpful in identifying parts for replacemnt with part numbers. Quick response."
ASKO 1375 Dishwasher top rack keeps rolling out
Your dishwasher may have sagged since being level when installed.
May 20, 2016 | Asko 1375 Dishwasher
How do I balance dishwasher so drawer doesn't slide out
You need to level your dishwasher - extend the front leveling legs, or shorten the back leveling legs (if your dishwasher has rear leveling legs.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 20, 2014 | Asko Dishwashers
I have a Asko D3530 and the top basket isn't washing properly but in my menu section it doesn't come up upper basket wash anymore?? If someone could tell me how to get that option back that wo
Keep the Program button pressed until you see wash programs like Auto or Normal displayed. This should get rid of the Lower basket program.
Manual is available from here
Jun 27, 2012 | Asko 24 in. D3530 Stainless Steel...
I have a bosch dishwasher silence , when it finishs wash i open the door and find the tablet falling on the bottom or hanging on the container of the tablet part, which did not use at all..please advise,...
Check top basket is straight and moves back fully, remove top spray arm and check holes are not blocked. The water pressure from the top arm is deminished if they are blocked and once the dispenser door opens it is the top spray arm water that propels the tab into the tank. Also, check that when your tallest item is in the bottom basket it does not obstruct the rotation of the top one.
Hope this helps to give you a starting point to remedy fault.
Jul 22, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Asko dw 95.2 model 1705 after 6 years of use the dishwasher top drawer rolls out. Will not stay inside when main door is open.
Jun 29, 2010 | Asko 24 in. D3250 Built-in Dishwasher
Dec 25, 2009 | Asko 1385 Dishwasher
Top rack will not pull out all the way
Replace the upper basket wheels - these are available as spares. If the metal runners look angled - it may be the wheels on the side of the dishwasher that need replacing. These are also available as a spare part.
Ebay is actually a good place to shop for spares of this type.
Aug 04, 2009 | Asko 24 in. 1585 Built-in Dishwasher
Top Rack always slides out fully
Well, you are right on about the level. It is tilted just slightly forward. The only parts to go bad are the plastic ball bearing guides, and usually when they go, you get a rack that wont come out and gets jammed. You 've got the problem, you just need to remove the screws hidden in the holes that are sometimes coverd with rubber plugs so that the dishwasher may move freely, andjust it till it no longer rolls out, then screw it back to the counter to hold it in place. There are no springs in that rack, so either its still tilted forward, or the tank is bowed or bent somehow, and that would mean new dishwasher. Hope this helps!
Jun 19, 2007 | Asko 24 in. 1585 Built-in Dishwasher
Top basket spray not working
did you solve this problem mine is doing the same?
Aug 20, 2006 | Hotpoint 23 in. BF41 Built-in Dishwasher
Dishwashers Logo
22 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
