Question about HP PL4260N 42 in. Plasma HDTV
Hp TV wont stay on cable setting
Our HP Plasma TV keeps switching from calbe to other settings. Then goes to a blueish green screen then switches again to channel 02.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 73 Answers
Contact us for legal action agaist HP for this model HP tv. They sold this TV with known defects. dorje@forexcafe.org
Posted on Jul 11, 2009
Sony tv no picture on screen
Hello, You probably hit the input button by mistake. If your using cable TV your input setting will depend on how the TV is connected. If your using an HDMI cable check to see what number HDMI the cable is plugging into on the back of your tv and then set the input button to the same port number. If your tv is connected with RCA cables (red,blue,green) Then hit the input to AV.
Feb 05, 2018 | Sony Televison & Video
Green light stays on when trying to turn off tv. picture go's off when cable remote is used but green light stays onand you can see that screen is still on?
You need to set up the cable box remote for your TV , now you are just turning off the cable box. Some cable boxes have a switched plug on the back that will turn on and off with the box. If yours has the switched receptacle you can use that to turn the TV on and off by plugging your TV into the switched receptacle. Make sure the TV power is on, the receptacle will kill the power so the clock on the TV wont work. Otherwise you need to set the code for your TVs remote and use the system power button.
Apr 23, 2014 | Mitsubishi LT-46153 LCD TV
Can't get my samsung hp-t4254 42" plasma tv to
make shure that the computer is set up to display on the screen. To check and see right click on your desktop, click on the option that says screen resolution, and then change your settings from their. The tv will not register that you have a computer plugged into it if the computer is not sending the tv a signal.
Mar 05, 2011 | Samsung HP-T4254 42 in. Plasma Television
Samsung HP-R4272 42" plasma. 3" blue/ green ribbon
This is caused by the LCD panel shifting in it's mounts. You will need to disassemble the frame holding the LCD screen in place and re-center it.
The lines will take some time to go away as the set warms up, but be patient, they usually disappear over time.
Oct 26, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
Panasonic viera 42 inch plasma, comcast digital cable. screen goes totally green. switch to comcast guide, green disappeared and switched channels, then back to original channel and all was normal. it...
It sound like you are using a component video connection to the TV, which is of variable specification. Try a different type of video feed from your Comcast box
Jan 27, 2018 | Panasonic Viera TH-42PX80U Plasma TV
Blue screen
Are you using component video cables? If so, check that these aren't loose on either end. Next I'd consider that whatever video cable/input might be bad, and switch cable or cable type... i.e. switch from component to HDMI or vice-versa. Then change up the source (cable box versus DVD player). If you're still seeing blue at this point, the TV internals are the bad.
Jul 23, 2008 | Panasonic TH-50PX75U Plasma HDTV
Plasma wnt stay on
I have had this problem in some models of plasma sets before. In most cases the power supply and main drive boards had to be replaced. In a small number of cases the failure was the screen itself.
In all cases, the cost of the repair was expensive. For the screen failure, the set was scrapped.
Jerry G.
Dec 30, 2007 | Hyundai ImageQuest HP4240 42 in. Plasma...
HP PL4260N 42 in. Plasma HDTV Logo
184 people viewed this question
Top HP Televison & Video Experts
Computer Links
vbalag
Level 1 Expert
Alun Cox
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
