Question about Radio Communications
XPR 8300 VHF Repeater Pushing to much power
I have installed a new motorola repeater xpr 8300. works well with my handheld radios. when used with the installed truck radios that are i think are 40 watt radios, there seems to be a lot of chopping in the radios. is the repeater pushing too much? is there a minimum distance i should be from the tower and repeater? please help.
icom andy
SOURCE: please Help me
MOTOROLA GP-2000 Programming Instructions
Switching between Dealer and User Configurations
- Turn off radio
- Press PTT + Monitor Buttom and + buttons together and turn radio on
- LCD Displays PRO-CLR
- To confirm switching to Dealer configuration, Press PTT. To cancel, press any other button
- Turn off radio. The radio now operates in Dealer configuration
From Dealer to User
- Turn off radio
- LCD Displays PROTECT
- To confirm switching to User configuration, Press PTT. To cancel, press any other button
- Turn off radio. The radio now operates in User configuration
ENTERING PROGRAMMING MODE
If the radio is turned on, turn it off. Press and hold the MON button and turn the radio on. A ringing tone will be heard,which indicates that the radio is in Programming mode. The PW and [] indicators are displayed.
EXITING PROGRAMMING MODE
To exit programming mode, turn off the radio
ACCESSING PROGRAMMING MODE PARAMETERS
In dealer config., Programming mode parameters are grouped into 3 (three) main categories.
RW = Radio Wide
Channel (001 to XXX) and
VFO (Variable Frequency Operation)
User + or - buttons to move from one category to another.
RW < >CH 001 < > CH 002 < > …. < > CH XXX < > VFO
Note : Radio operating in User Configuration is only restricted to PW parameters
Once you have selected the category and wish to view its parameter, use PTT or MON to move from one parameter to another.
Posted on Nov 20, 2007
  • 50 Answers
SOURCE: Looking to build a two way radio system.
Not knowing your back ground here are something to consider. Make sure all handhelds have at least 2 channels, the transmit can spread at least 5 MHz from channel 1 to channel 2, the mobile repeaters have high gain antennae, cable between repeater and antenna, is just long enough, and set each repeater up on a different CTCSS/DCS access.
If I think of anything else, I'll send a comment. If you have any further questions, please respond.
Posted on May 31, 2009
  • 19 Answers
SOURCE: is there any possible repeater
Your question does not make sense.
Yaesu is the amateur radio manufacturer for the Vertex Standard company. Motorola only makes commercial radio equipment. Both can be programmed or configured to use repeaters.
Posted on Sep 07, 2010
BillB-SA
  • 2761 Answers
SOURCE: Can you leave a Motorola XPR 6350 radio turned on
The radios will work just fine while they are charging, but the charging process will take longer, and I recommend that you do not charge the radios for more than 12 hours at a time. My Midland radios sit in the charger base all the time, and I just push them down to engage the charging function.
Bill B.
Posted on Nov 17, 2010
mrno757
  • 48 Answers
SOURCE: I need to wire external
usually when buying a 2way radio they come with a headset (a headphone and a mic) all you need to do is cut the mic and headphone off using the wires for the headphone solder them to a speaker.
(the higher the power of the speaker the more it will drain your battery)
Posted on Mar 22, 2011
How do I change the power up volume level.
David
Contact Motorola Solutions.
Get Support
Mark
Motorola Mobility Support
Jun 23, 2015 | Motorola XPR 4550 Two Way Radio
Xpr factory reset
Contact Motorola Solutions Get Support
Mark MotorOla Support
Mar 29, 2014 | Motorola Radio Communications
I am trying to program a xpr 4550 with a talkaround channel that is the same feq as a repeater channel with no luck.
Be sure "talkaround" is enabled on the code-plug, then use the "direct" or "talkaround" button on the front panel.
Jan 28, 2014 | Motorola XPR 4550 Two Way Radio
Xpr 6550 no mic audio
Be sure the level is set correctly in the CPS software for your codeplug.
Jan 22, 2014 | Motorola Xpr6550 Vhf 136-174mhz 160...
How do I adjust the range on my motorola XRP 4550?
Uh, stick with analog. Digital radios do NOT have better range than analog. You lose about 5-10% on the outer fringes. For range, those radios were designed to operate on a repeater, often called trunked radio relay system.
Your digital radio is likely on someone elses' frequency. Channels are controlled by the FCC and are not for consumers. You must have an FCC License or an agreement to use the mentioned Trunked Relay. You may have a thing called busy lockout programmed, which means when someone else is talking, you get blocked. The only thing you can do to get your radio(s) working well is to have them reprogrammed by a professional (Radio Shop). If you can, have them programmed for analog only.
For basic radio use and reasonable coverage, get a couple of 25-50 watt Vhf analog radios. Get a License and you will be very happy! Buy the best antennas, installed correctly and you will have decent range. Antennas matter on terrain, so high gain may not be the best choice. Been a radio dealer/repair since 1980, before the start of digital and beyond. Beware the over promising of digital.
May 21, 2017 | Motorola XPR 4550 Two Way Radio
Is there any possible repeater station with yaesu vhf radios like motorola radios
Aug 04, 2010 | Radio Communications
You will have to have a vehiclular repeater that is in another band than the mobile so if your portable hand held radios are on UHF then I would advise a VHF high band repeater set up.
It will have to be a cross band setup meaning it will recieve UHF and transmit on VHF and also the opposite direction.
It will have to be programmed with CTCSS or PL of some kind to avoid interference and don't forget it will need to be FCC licensed for those frequencies if it is in the Business band.
Some mobile radios can be wired up through a mini controller and run that way if it is compatible.
Apr 28, 2009 | Motorola For SP50 7.5v 1500mAh NiCd...
Radio Communications Logo
264 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
