Question about Samsung 51" 720p 600Hz Plasma HDTV PN51E450A1F
Samsung Plasma pn51e450a1f will not power on. It has a red light that flashes at bottom left of screen once every 10 seconds. I have replaced the power board.
  • 179 Answers
SOURCE: Samsung 42" Plasma-SPN4235 screen problem
the panel itself has failed
Posted on Dec 01, 2007
SOURCE: Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Posted on Oct 29, 2008
  • 304 Answers
SOURCE: Samsung TV Power Supply Board
I doubt that moisture damaged the SMPS bd.
There are many circuit boards in your set and it will take a trained samsung tech to find the problem.
Posted on Jul 17, 2009
SuperTech-11
  • 1591 Answers
SOURCE: i have a samsung LN32A330J1DXZA
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, this unit needs to go in for repair.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for different brand, but same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 11, 2011
SOURCE: Samsung PS42B430 42" Plasma tv. LED flashes and
what is the best solution here plasma tv ps43d491a4?
Posted on Nov 17, 2012
My screen has no picture
Seems like backlight is not turning on. Try to get different angles and bright light on the screen to see if there is something on the screen (not sure if this is true on plasma). If you see some text/image, troubleshoot the backlight board.
May 11, 2016 | Samsung 51" 720p 600Hz Plasma HDTV...
Who to fix broken panasonic plasma tv
Adam, 1 st thing to try is holding the power button in 20 seconds and see if it resets.Check the links below and do not be afraid to google search your problem yourself, there is a lot of info. out there onm this problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Panasonic Plasma TV Repair Understanding 10 Blink Code for 2011 Panasonic...
Panasonic 10 flashing red light
Panasonic Plasma 10 and 2 Blinks TEA1611 ETX2MM702 704 706 Power Supply TH...
May 02, 2016 | Panasonic TCP65VT25 65 inch VT25 1080p...
My tv wont turn on
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 30, 2015 | Samsung 51" 720p 600Hz Plasma HDTV...
I have a pn43D490A1DXZA it has no picture and the red light in the bottom left blinks
Check and replace the 15V SOS board. It is faulty. If you wish to get more details about these type of faults to Plasma displays, check this link.
Feb 06, 2013 | Samsung PN43D490A1DXZA 43 In Plasma 3d...
Samsung PN51E450A1F screen flashes and shuts off
how many times the standby light flashes? Count it carefully. The number of flashes are fault indications. Visit the site named 'Electro-help' for more details. Click this link.
View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 850 posts to different brand TVs now.
Sep 25, 2012 | Samsung 51" 720p 600Hz Plasma HDTV...
Philips flat screen 42" flashing red light 7 times it stops for 5 seconds and 7 more flashes if i unplug and plug it a few time it will come on
my 42 inch phillips, i turn it on green light comes on for 10 sec then red light comes on and flashes 4 times then stops for 5 sec then repeats.
Apr 20, 2010 | Philips 42PF9631D 42 in. Plasma Television
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
My plasma tv has a red light flashing on the
You have to bad compacitors on the power board. They will be buldged on the top. Once replace you TV will live again. The parts will cost you about $4
Jul 25, 2009 | Philips Televison & Video
Samsung 51" 720p 600Hz Plasma HDTV PN51E450A1F Logo
361 people viewed this question
Jerry Greenberg
Jerry Greenberg
