Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
My husqvarna yth2348 mower will not go past the compression stroke to start. replaced battery and still same problem. have to put a charger on it and get it on top of compression stroke to et it to start. if i pull one plug it will turn over fine. does this unit have an unloader ?
dgjtex
  • 405 Answers
SOURCE: I NEED BELT DIAGRAM FOR MY HUSQVARNA RIDING MOWER
http://www.usa.husqvarna.com/home.aspx try this out for your answers, I hope this helps you. MERRY CHRISTMAS!
Posted on Dec 23, 2008
SOURCE: Husqvarna LGT2654 with Briggs & Stratton Intek Engine won't start
If the fuel line is dry after the fuel pump its usally the diaphram thats stuffed does it have a fuel tap in place? is it off? also i know with nem mowers just been come over from freight the fuel filter is full of oil for the first start up as the valves need lubrication first startup... take the fuel line off from the carb just have it hanging down for a start, then crank the mower over, you should then have fuel coming out of fuel line by then... see if that helps jay QLD AUS
Posted on Feb 24, 2009
  • 95 Answers
SOURCE: Husqvarna Mdl YTH2448 Riding Mower - Electric PTO Not Working
It sounds like your charge system is not working. If you jump the battery the engine will run with a weak battery but the pto clutch needs a strong battery to stay engaged.Try this to test it,after you jump it leav the jumper cables hooked up and try to engage the blade clutch,if it runs it is either a battery that wont take a charge or a charge system not working. If you put a volt meter on the battery while the engine is running and the voltage is 13 volts the charge system is working and the battery is bad.
Posted on Jul 31, 2009
RonPark
  • 855 Answers
SOURCE: husqvarna yth2348 keeps blowing fuses as soon as
You have a dead short in the circuit for that fuse. Check for a pinched wire, or a wire rubbed thru a touching metal.
Posted on Sep 28, 2009
Testimonial: "very helpful with the problem"
  • 202 Answers
SOURCE: Engine will not turn over
Those boxes are probably relays. Sounds as tho one of your safety switches is not working correctly. Make sure you have the machines brake on, blade off, and any other safety measures are applied, such as the operator is sitting in the seat. Check the wiring connections at all the connections where the safety features are installed. Probably just a connection that is not letting the system know that all systems are indeed applied.
Posted on Nov 15, 2009
What battery does a 48" deck riding mower take
I would put in the largest amp lawnmower type battery you can get
Aug 07, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
18.5 hp lawn tractor will not turn over when on compression stroke . If you move it a little by hand past compression stroke it will start.
Sounds to me that you have a weak battery and is not putting out enough cranking amps..Takes more cranking amps during compression strokes to start than in down stroke...That is why you are able to start it in the down stroke less amps needed to turn motor over..
Jun 28, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Jd#la115 does not turn over past compression stroke
I'm guessing a "weak battery" is the problem. Sometimes a fresh new battery can make a piece of equipment run "like new"..... Also, you might make sure battery is high enough capacity... If all this does you no good, I'd guess you have a "tired" or worn out starter...
Nov 19, 2013 | Garden
My husqvarna tractor won't start. It has a new battery but no clicking or anything when I turn the key. If I hook up a portable battery charger and try to start it, I hear a grinding noise but the engine...
have you checked the fuse? there is a 20amp yellow fuse under the hood just below the solenoid same side as the blade engagement switch.also be sure all your lock out switches are working or by passed.
Feb 06, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
How to reset oil change indicator on my husqvarna riding lawn mower
depends on how old the mower is, for the past 3-4 years, Husqvarna made it so that you have to replace the unit, unable to just reset it.
Jul 02, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Need to obtain user manual - new owner
You can download one at the following:
http://www.lawnmowersworld.com/husqvarna/YTH2348.html
Just copy and paste the entire address in your address bar
If for some reason that doesn't work just go to www.lawnmowersworld.com and locate your brand and model numbers
Nov 06, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
We have a husqvarna cth 170 and we cant seem to reverse it... have any ideas on how?
I have a Husqvarna YTH2348 that clicks when i try to start... I had the battery tested and changed the solenoid and still won't start. How do I check the starter????
Jun 05, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
16 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
