Question about Elna 945 Computerized Sewing Machine
How to rethread an elna 945 - Elna 945 Computerized Sewing Machine
Need manual for elna 945 computerized serger
The manual at the link is free. There is also online a youtube video about threading it.
https://www.manualslib.com/manual/378223/Elna-945.html
ELNA 945 Instruction Manual
May 23, 2018 | Elna Sewing Machines
How to thread the 945 elna serger for roll hemming
The instructions should be in the manual. Unfortunately, Elna manuals are usually not free, so unable to locate one online. However, this video may be helpful. How sergers do stitches is pretty similar across the board:
https://www.sewingpartsonline.com/blog/beginners-guide-serging-ep-7-rolled-edge
May 06, 2018 | Elna Sewing Machines
I am looking for a elna 945 foot control
check with a1sewingmachines.com for the part
Apr 02, 2013 | Elna 945 Computerized Sewing Machine
Hi, I have an Elna Supermatic model 722010 and the upper tension spring has broken! I am in South Africa and need a solution to fix it. Is there any way I can make this thin wire apparatus? Thanks...
Hi Fiona,
Have you tried Elna in RSA - always worth asking the central head office for a brand first, they may be able to supply the part or direct you to a local Elna dealer who can supply and fit it.
Elna Home Products - Cape Town
4 Pionier Street
Oakdale
7530 Bellville
W.P.
South Africa
icon_mobile.gif 27 (0) 21 945 1113
icon_printer.gif 27 (0) 21 945 2888
icon_mail_back.gif elnacape@elna.co.za
If that isn't an option then you could try this website to source the part www.whitesewingcenter.com? He is the old Swiss Elna specialist in USA and has a wide range of spares in stock. However, you'll need technical knowledge to fit it.
The other option is to join the Yahoo group called "Elna Heirlooms" and then ask the members there for assistance. They are usually pretty helpful to genuine Elna owners of these old Swiss machines.
However, I'd try to find an Elna dealer firstly, I recently purchased the screws for the bobbin case for the same model as you from a service person in NZ, he knew exactly what I wanted and was able to supply them. I found him on Trademe, their Ebay equivalent. The old Sewing Machine Guys are priceless.
Aug 31, 2011 | Elna Heirloom Edition 6005
Left needle stitches not being caught by looper
Is the tension on the left needle on its normal setting and is the thread feeding okay to this needle, not caught up somewhere on the aerial or around the cone?
You could try unthreading everything, changing the needles, then rethreading the machine again in the sequence of the threading diagram and test sew.
However, if you have had this machine for a while and are very used to threading it and this seems like a fault to you, then it could be that the looper has been knocked out of timing and it would need a trip to the sewing shop to investigate further.
Apr 08, 2011 | Elna 945 Computerized Sewing Machine
The presser foot lever on my Elna 945 is breaking/broken. I have ordered a replacement part and I'm wondering if I can do the replacement myself. Or should I take it to a pro?
here is a link to the service manual for the 925 http://www.arizonaexpressionz.com/elna_service/925_704%20suppl.%20service%20manual.pdf
I can't see one for the 945 but the above manual may give you some guidance as to what the replacment involves.
945 is a fairly new model so you may find that taking it to a pro and getting the timing and loopers checked at the same time is worthwhile. Also being computerised model, if you get something wrong and the computerised part is affected it could turn out more expensive to then take it to an Elna dealer.
I get my Bernette serger serviced every 2 years and it is now over 19 years old, and still performing well.
Apr 05, 2011 | Elna 945 Computerized Sewing Machine
Elna 945 Computerized Sewing Machine Logo
26 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
