Question about Toshiba Sattelite A105-S2051 Notebook
The boot selection failed because a required device is inaccessible
OS is Windows 7 I was trying to go back to factory settings and now windows fails to start. I get status 0xc000000e I don't have a dvd drive with the notebook just usb port
Joed911
  • 4338 Answers
SOURCE: RESTORING WINDOWS/BOOT MANAGER
Sounds like you have Vista. Here is a link on creating a Vista recovery cd:
http://neosmart.net/blog/2008/windows-vista-recovery-disc-download/
This link is a how to document on repairing the BootLoader:
http://neosmart.net/wiki/display/EBCD/Recovering+the+Vista+Bootloader+with+EasyBCD
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 02, 2008
rockitman187
  • 2559 Answers
SOURCE: Booting Notebook using external devices.
This should do it for you.
On the Phoenix BIOS:
Go to "Advanced BIOS Features".
Go to the "1st Boot device" and set it to "USB-ZIP".
(Phoenix BIOS, Revision 6. you need to go to the Boot Order screen and select "Harddisk" and hit enter, giving you a list of IDE hard drives this BIOS prefers to call a USB device an IDE harddrive)
Posted on Jan 09, 2009
parrotheadpc
  • 2600 Answers
SOURCE: window failed to start
Windows Start-up Errors
Note: This troubleshooting step is usually used for the specific issue indicated above but it may also work for BSOD issues which recently occurred and you're unable to boot to either safe mode or normal mode.
First, The basics. You will need a Windows XP CD. If you only have a recovery disk set like the ones from a HP or Compaq, they will not do what you want. You can normally use a Dell disk, also retail box disks (XP Purchased from the store), or some OEM versions of XP will work (most of these will have the Microsoft hologram on them). You can also download a boot up Floppy disk set from Microsoft here: http://support.microsoft.com/kb/310994 There are a few other places with bootable CDs on the net, but the easiest thing to do if you don't have an XP CD is to borrow a Dell or Retail box disk and get right to work. If your computer already starts at the CD rom first, or you know how to make it go there skip to part C:
After you know that the computer will boot to the correct drive, insert your disk into the appropriate drive. If you have more than one cd rom or floppy drive you may find that your system only checks one drive before going to the hard drive for boot up. If this happens you can just move the disk to the other drive and restart your computer.
When you get the system started and it finds your startup disk you will see a screen that says Press any Key to boot from CD. I normally use the space bar as my any key and then you should see a blue screen that says Windows setup in the left hand corner. Wait until you see the welcome to setup screen and then click the "R" key to get to the Recovery Console How long it takes to get to each of these depends on the speed of your system, but I will tell you that it will take a few minutes to finally get to the Console.
Once you are at the Recovery Console you will be given at least one choice of Windows installations. Normally the choice you want is the number 1 choice. Click the number 1 key at the "top" of the keyboard and click enter.
You will be given a message asking for the administrator password. Unless someone or something has messed with your computer there is no password so you just click the enter key.
This will bring you to a prompt that says:
C:\WINDOWS>
Type: cd \ and then click enter
( Note: between "cd" and "\" there should be a "blank space" otherwise the command won't work. If you find that a command hasn't worked make sure you typed it correctly. These are similar to old DOS commands where spaces had to go between each command so DOS knew where one command stopped and another started.)
You are now at the ROOT of the drive where it all begins. The Prompt should now say C:\>
Now type: CHKDSK /R and click enter.
The chkdsk / r command also includes the P command and will also look for lost recoverable information in bad sectors.
Now after the chkdsk has run type: FIXBOOT then click enter.
It may prompt you with a warning but continue through it and once fixboot has finished type: EXIT and click enter.
Your system should reboot and when it does click the F8 button to get a windows start menu. Use the up or down arrow to highlight the LAST KNOWN GOOD CONFIGURATION and click enter. If it was a simple drive error this should have fixed it.
Posted on Oct 12, 2009
parrotheadpc
  • 2600 Answers
SOURCE: windows boot manager for TOSHIBA PRO L300
You will need an original windows installation disc and not a recovery disc. If you do not have one, then you have the option of taking to a shop that does and have them run the repair utility. Or, if you can find someone who has burned a copy of the windows ultimate boot disc, that will also help in repairing the boot manager and files.
Posted on May 23, 2010
joelwilcox
  • 1274 Answers
SOURCE: windows 7 problem insttaling
i'd read through this microsoft tech page, it should help you diagnose the problem http://answers.microsoft.com/en-us/windows/forum/windows_vista-system/status-0xc00000e9/53c26f2d-6880-49dd-b907-512c29b88c87
there's also the chance that your hard drive sata connection is not completely secure.
Posted on Apr 30, 2012
Dell-n5050 laptop; windows failed to start; code-0xc000000e; boot failed because required device is inaccessible. I have Dell OS media stick. and is there a free fix for this problem?
That code is a Windows boot error. I'm not sure what you can do with the Dell OS media stick but the traditional solution with a regular hard disk is to take a Windows 7 OS disk, boot with it, and run startup repair. Here's a link to Startup Repair: Startup Repair Microsoft Windows
Apr 01, 2015 | Dell Inspiron N5030
Google com
Possible hdd failure or a damaged file.
Windows Boot Manager
Windows failed to start. A recent hardware or software chance miht be the cause. To fix the problem:
1. Insert your windows installation disc and restart your computer.
2. Choose your language settings and click "Next."
3. Click "repair your computer."#
Status: 0xc000000f
Info: The boot selection failed because a required device is inaccessible.
Aug 04, 2014 | Acer Aspire Computers & Internet
How to format my Dell computer
Your drive may be toast. You need to find the right F key (typically F2 or F8 or F12) to open the BIOS menu. Start pounding on one while booting until you find it. You may have to try all 12 F keys. Once you get the BIOS menu (not the boot menu), there should be a device section. Make sure your C: drive is visible to the BIOS. If not, the drive is usually bad and needs replaced. You will need a drive preloaded with WIndows, or you will also need the Dell recovery CD set. However, if the C: drive looks OK, next find the right F key to open the boot menu. There should be options there to boot Windows, Safe Mode, Restore to a previous check point, or recover to factory settings. If this does not work, you will need to get the Recovery CD set from Dell for your model. Be warned this usually destroys all old data files.
Jul 25, 2014 | Dell Studio Computers & Internet
Windows boot manager
Turn computer off
When turning it on again press F8 before anything starts to happen
When asked enter safe mode
While in safe mode go to device manager and look for exclamation marks
Mar 13, 2014 | Fujitsu LifeBook AH531
Hi, my dell laptop having problem I have a
Press F8 when starting up to get into safe mode, then use system restore to revert back to a previous working state
Aug 10, 2013 | Dell Inspiron Computers & Internet
Hi, I have a windows 7 ultimate 32 bit. And when
Try first getting in via safe mode (Hit F8 when booting and then choose Safe Mode) - then use system restore to revert to a previous working state.
Aug 10, 2013 | Computers & Internet
Already press f8 and f11 and other f's still it shows WINDOWS BOOT MANAGER, and it says Info: The boot selection failed because a required device is inaccessible.
You need to press F11 or F8 before you get to the boot manager. This will allow you to choose a different boot device.
Mar 30, 2011 | Computers & Internet
You're getting that error message because the boot files on your hard drive (the required inaccessible device) are corrupted.
When first booting, press F8 repeatedly. Will the computer let you go into safe mode? If not, without the installation cd, you're kinda between a rock and a hard place. However, you can download a (free) vista recovery disk (repair only) from the people at easyBCD:
http://neosmart.net/wiki/display/EBCD/Recovering+the+Vista+Bootloader+from+the+DVD
Just follow the directions to do a start up repair.
If that works, by all means, make yourself a recovery cd before doing anything else.
Jan 26, 2009 | Microsoft Windows Vista Ultimate Edition
Toshiba Sattelite A105-S2051 Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
