Question about Tools & Hardware - Others
I have Arrow Stapler JT-2IM, what are any OTHER staples I can use?
I KNOW how to PUTe staples in, I need to Know if Bostitch SBS191/4" chisel point staples will work, or what OTHER staples will work?
5 Suggested Answers
  • 384 Answers
SOURCE: my jt 21m stapler is jammed and i cant get it to open
At the end of the stapler opposite where the staplers are driven out is a release. Push it in and turn it should come out with a long spring.
Posted on Jun 26, 2009
  • 27 Answers
SOURCE: I don't know how to load staples into the Arrow
there should be a spring loaded clip at the end of the stapler opposite from where the staples come out push it in to release
Posted on May 29, 2010
al_kupchella
  • 843 Answers
SOURCE: Stanely Bostitch 00540 stapler -
There is no adjustment other than using shorter staples.
Posted on Dec 21, 2010
SOURCE: I need instructions on how to refill the Arrow T50
remove the spring loaded magazine from bottom rear of unit by pushing down on piece about two inches below curve section of rear end of handle push down gently and pull to rear staples go in front ofin same slot from which this magazine is removed load normally two clips if your dead empty when you return the spring follower back into place it follows the staples if if doesnt go all the way in you probably have to many remove some good luckd
Posted on Mar 23, 2011
THE FRONT NOSEPIECE FOR THE BOSTITCH T5 WILL NOT MOVE. I CAN SEE THAT IT IS CLEARLY MARKED THANK YOU TO THAT PERSON BUT IT IS NOT MOVING ANYWHERE OR ANYWAY. I NEED HELP NOT SARCASM PLEARE.
How to Put Staples in the Bostitch T5 - YouTube
? 1:10
https://www.youtube.com/watch?v=wWOubLQ5luc
Jan 17, 2015 - Uploaded by Garage and Garden
I received free samples of staples for this video from SALCO Staple Headquarters: http://www ...
Bostitch T5 Stapler - YouTube
? 2:56
https://www.youtube.com/watch?v=ryIRg2xLijo
Mar 7, 2015 - Uploaded by krcvirbch
Stanley Bostitch T5 Stapler Staples T5-6 STCR 2619 3/32", 3/16", 1/4", 3/8", or 1/2".
BOSTITCH T5 Google Search
Nov 19, 2017 | The Computers & Internet
Rosetto tacker RT12. Vintage? Are there commom staples to arrow etc.?
looks like an old bostitch stapler I used and that used generic staples that were a common item for staplers
all you have to be careful of is the width of the staples in use as some do not slide easily in the rail if they are not made for that width rail in the stapler
prong length is of no matter as you can get different lengths for different materials
Feb 15, 2017 | Arrow Tools & Hardware - Others
What staples does a black and decker electric stapler 9700 take and where can I buy them?
Hi Stephen,
Of course the manual states to use their staples for best results.
However it does at least state it is designed for a wide variety.
Most hardware stores have a range of staples to choose from.
Home Depot, Harbor Freight, Lowes etc. Try a chisel point this may help penetrate the wood deep enough. All staples are not made the same. So again trial and error may be the quickest route. Fortunately you can purchase small boxes for your testing.
The manual for this stapler is here:
(Page 2 talks about the staples to use.)
Black Decker 9701 Instruction Manual Page 2
Good luck and hope this helps!
Jan 04, 2015 | Arrow Tools & Hardware - Others
How do I replace the staples in Stanley Bostitch B310HDS? I cannot seem to figure out how to open it.
"The staples load from the rear of the stapler. At the back end of the is a piece of black plastic that extends beyond the end of the stapler. This device holds the staples inside the stapler. To open the area where the staples are placed, push this extended button and lift up on it. The spring device that holds the staples inside the stapler will then slide out. Place a new strip of staples inside the stapler on top of the two metal guide rails. Then insert the spring device to lock the staples in place. The stapler is now loaded and ready to work. " hope this helps you out
Jan 06, 2011 | Stanley Bostitch 00540: 00540 AntiJam ?...
I HAVE A BOSTITCH NARROW CROWN AIR STAPLER AND THE STAPLES ARE NOT GOING FOREWARD FOR THE ROD TO DRIVE THEM IN. IS THERE SUPPOSED TO BE A SPRING BEHIND THE STAPLES TO MOVE THEM FOREWARD. PLUNGER COMES...
There is a spring to push the staples into place. Bostitch was purchased by Dewalt and moved their parts lists to the web address below. Enter your model number and order the parts needed. Good luck with your future projects.
http://servicenet.bostitch.com/
Sep 02, 2010 | Stanley Bostitch STB-MIIIFS Flooring...
My jt 21m stapler is jammed and i cant get it to open
Jun 26, 2009 | Arrow Fastener Co. Lt Duty Staple Gun -...
Tools & Hardware - Others Logo
22 people viewed this question
Top Tools & Hardware - Others Experts
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
