Question about Frigidaire GLER331A Electric Dryer
Squeeky dryer My dryer dries the clothes fine but it squeeks very loudly during the entire cycle. What do you think the problem is?
  • 1,000 Answers
Typically what happens is over time the back drum supports wear out. Once they have worn thin the drum rides on the bare metal portion of the support and you get the "annoying" speek sound. Or if the supports are the roller bearing type, the bearing fails and it generates the noise.
Anyway, the supports or rollers are inexpensive to replace and not very difficult.
If you want to tackle the problem, let me know.
Good luck.
Regards,
Posted on Jun 22, 2009
    President:
  • 632 Answers
Noise is due to friction caused by the fan blades touching the motor casing..
Very squeeky dryer, starts out quiet then intensifies through the cycle untill it can be heard from outside; has a rhythmic squeek.
The belt is probably rubbed smooth. Since you already sprayed it, after the spray dried out, it starting squeaking again. I suggest examining the belt and replacing it if necessary.
Mar 22, 2016 | Dryers
Squeeky dryer
belt is stretched from a worn bearing in the belts idler pulley
Replace the belt along with the pulley sold at most Sears stores
Jun 20, 2010 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Won't dry clothes thoroughly
It could be or the moister sensor is bad. Do this first for most people never think of doing this. Disconnect the entire venting duct work. Inspect it and clean it. If you get a wad of lint every foot length from this vent this will be your problem in drying clothes. The clogged vent will not let the exhaust pass through and the moister sensor detects that and shuts off the heat automaticly
Apr 20, 2010 | Whirlpool LER7646E Dryer
My GE gas dryer makes a loud squeeking noise running
WE 3X 75 is the part number you need. Take a look at these repair pix
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 09, 2009 | GE Dryers
Squeeking while dryer is drying
i would suggest calling the repiar. The longer you wait the more expensive this will be. One of two things is happening. One, bearing is going out, or most likely the belt is slipping on the drum and needs replacement. Good luck
Jul 09, 2009 | Dryers
During the drying cycle, the dryer door opens
Chances are the little plastic latch keep is broken. Look at the door and locate a peice that will press into the front area where the clothes go in.
Once you see it, check the keeper and see if it is broken. The door should not just pop open.
Feb 25, 2009 | Dryers
Maytag gas dryer makes squeeking noise
it is more likely one of the drum rollers
Dec 20, 2008 | Maytag Dryers
Noisy dryer not drying clothes, water found in vent tube
You either have a restriction somewhere in the venting which you say you have already checked or maybe a bad blower (fan). it may be stripped off the shaft and not pulling any air through the machine. If you run the dryer with the hose removed at the back and it dries well you have a problem with your venting. If it still takes three cycles it's a problem with the dryer. Repair would probably run about $100-150
Oct 13, 2008 | Dryers
Smell
Have you recently painted or finished any woodwork or floors? A gas dryer will smell like gas when the vapors from paint or finishes reacts with flame. It can smell like gasoline.
Nov 12, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Loud/Soft signal
all i can figure is it is a strange method by kenmore to alert the user to throw in an antistatic cloth that gives softer clothes (clothes softener sheets)
May 25, 2007 | Kenmore 67052 Dryer
Frigidaire GLER331A Electric Dryer Logo
339 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
