Question about Lexicon MX400 FX unit (with )
Lexicon mx400 fuse for 220volts - Lexicon MX400 FX unit (with )
I think I've a failed unit. Turning it on - the USB flashes and then it remains on the logo splash screen. I have tried numerous times to factory resent - holding down the System button on power on,...
It MAY be waiting for an UPDATE of firmware via USB. In other words you may have triggered an update mode that it will not exit without sending an update. The second possibility that comes to mind is that one of the buttons or the switch behind it may be stuck which can lock up the processor. Look for a button stuck in or that feels un-normal.
Aug 23, 2011 | Lexicon MX400 FX unit (with )
Lexicon MX200 screen coming up as "ER", nothing else happens, and no sound
hello I have the same problem, I'm told that updating the firmware of the Lexicon MX200 is solved but it turns out that my pc does not recognize the device via USB to update, any solution? thank you very much
Jul 06, 2011 | Lexicon Mx200 Reverb Delay 1u Effects...
Hi ihve soundcraft efx12 & the problem is in the effect, it hanges if i use the program selector, all the leds related to lexicon effects lit up.ithink the problem is in the the lexicon card. please...
If the LED's are level indicators, you are probably saturating the input of the effect and may cause it to hang. Effects use delay and feedback and can cause numerical overflow and the system to basically crash. I would first call the Lexicon support and ask them about this problem... I did have to return one Lexicon product myself for service under warranty.
Mar 25, 2011 | Soundcraft Efx12 - 12 Channel Sound Board...
I have Lexicon alpha, Condenser Mic, phantom power .If i record, the voice goes only to right speaker. I am using cubase le 4, stereo in/out are correctly.
Sorry, but the Lexicon Alpha does NOT have Phantom power and you can't use a condenser mic with it without a Phantom power injector or preamp.
If you mean you have a Phantom power injector then it should be working. Do you have seperate mics for the two channels of the stereo? If you have only one mic, then only one side will record unless you set for mono recording and then dump the recording into stereo voa Cubase. I would recommend you get a small mixer... even a 4 channel one to use ahead of the Lexicon so you can mix and PAN your mics the way you want them. The recording and trying to control the panning in Cubase can be frustrating... The Lexicon really doesn't have anything built in to PAN the mic to the center when stereo recording. Small mixers are inexpensive and often you can find them used or in pawn shops for cheap.
Feb 12, 2011 | Lexicon Alpha Personal Recording Studio
Whats the polarity of lexicon ionix u22 audio adaptor? should i set plus or minus polarity on the adcd transformer/adaptor? thankx
Easy answer: You DON'T set the polarity because this particular device takes a 9 VAC at 2.1 amp adapter. (Not a DC one like so called universal ones)
It sounds like you have one of those universal adapters which probably would not deliver the 2.1 amps required even if the lexicon took DC. Note that stuff might light up, but the unit will not work using a DC adapter..
You had better get an official power supply for this unit as what you have will NOT work, period!
I did a quick search to try and find a link to a supplier, but they are RARE !!! Every one I found would require you changing the plug to match the Lexicon.
You should just order the correct one from Lexicon.
Feb 04, 2011 | Lexicon U22 Ionix U-22
Lexicon Alpha got phantom?
The Lexicon Alpha does NOT have phantom power. The mic input expects a standard mic or a "self-powered" condensor mic. This means that you will neex external phantom power. There are power units available that use 9V batteries for this.
Dan
Sep 09, 2010 | Lexicon Alpha Personal Recording Studio
Lexicon alpha interface is recording a faint high pitched sound
Check for ground loops.
You MIGHT be able to cut the noise by setting the EQ's to clip the highs.
Jul 09, 2009 | Lexicon Alpha Personal Recording Studio
Lexicon MX400 FX unit (with ) Logo
54 people viewed this question
Top Lexicon Music Experts
Michial Gueffroy
dhnguyen
Gil Shultz
Are you a Lexicon Music Expert? Answer questions, earn points and help others
