Question about Arrow Fastener Co. Lt Duty Staple Gun - JT21M
Are there any staples I can out in my arrow JT-2IM stapler
I do NOT have Arrow JT-2IM stapler. Are there any other brand I can use? If so, what are they
  • 384 Answers
SOURCE: my jt 21m stapler is jammed and i cant get it to open
At the end of the stapler opposite where the staplers are driven out is a release. Push it in and turn it should come out with a long spring.
Posted on Jun 26, 2009
  • 2428 Answers
SOURCE: My husband got staples stuck
Its not your husbands fault Truthfuly the gun is a peice of junk it was never made to last they start to rust on the inside and that bindes it all up you have broken springs honestly throw it in the trash and get a new one but spray WD 40 in it this will make it last longer
Posted on Dec 07, 2010
ToolBoxHero
  • 171 Answers
SOURCE: What size staples and what size Arrow stapler do I
I would use 1/2 inch or larger. Set the staple into the wood and then pull gently to see if it holds.
Posted on Jan 06, 2011
SOURCE: I need instructions on how to refill the Arrow T50
remove the spring loaded magazine from bottom rear of unit by pushing down on piece about two inches below curve section of rear end of handle push down gently and pull to rear staples go in front ofin same slot from which this magazine is removed load normally two clips if your dead empty when you return the spring follower back into place it follows the staples if if doesnt go all the way in you probably have to many remove some good luckd
Posted on Mar 23, 2011
SOURCE: how do I load JT21
I was having the problems everyone listed... with the staples loading & firing... I guess the instructions are lousy .. should be ON THE PACKAGE to make it clear.. but.. on the stapler itself on the bottom.. it explains how to correctly load.. you don't put the staples on the piece that slides out.. you slide it out, load the staples in the open tunnel ..then slide the piece back.. that piece is the spring loader... since i finally figured it out ( by coincidence that I turned it over & noticed some faint words printed) - it works PERFECT every time! great little stapler... please fix your directions... seems to be a common misunderstanding!!!
Posted on Aug 30, 2012
Will the Arrow staples # 405 fit into my Craftsman 68464 staple gun ?
thats the picture of the manual staple gun
and the picture of type of staples you want
on the staple box confirms you can use the staples in that
sears craftsman
note the staple has inches and metric dimensions
all you need to check is the stapler eject system is not worn out
or cause a jam as you try to staple
if sticky .. try some sewing machine oil on the stapler workings
Oct 14, 2016 | Arrow Fastener 405 5/16" Flat crown...
Will Arrow #506 staples work in an Arrow JT27 manual stapler?
Hello, there. No, 506 staples will not work in the JT27 stapler. This staple gun takes JT21 staples in 1/4-inch, 5/16-inch and 3/8-inch. Did you have any more questions about your JT27?
Oct 02, 2015 | Office Equipment & Supplies
Where do I get staples for a B&D stapler? #9700
There are several brands of staples that will fit your stapler and the price will vary according to the depth of staple you are looking to buy. Arrow brand staples are the most common. All the ones I saw that fit the 9700 are Wide Crown Swingline Heavy Duty
Arrow 606 Wide Crown Swingline Heavy Duty 3 8 Inch Staples 1 000 Pack
Jan 06, 2015 | Staples Tools & Hardware - Others
Craftsman 68514
The replacement pack for this gun say the staples are compatible with "Craftsman 68514 and 68517; Arrow Brand T50 Staplers T50 and T55; and Stanley/Bostitch TR110 and BT110 staple guns", so I assume they are also backwards compatible. That's just an assumption though.
Mar 22, 2013 | Arrow Tools & Hardware - Others
How do you load new staples?
Find the button on the bottom of the stapler's back edge. Push the button in and down. Pull out the bar that pushes the staples into place. Slide in a row of staples with the points facing down. Push the bar back and lock it into place
Feb 20, 2011 | Arrow CHROME STAPLE GUN ARROW IND....
I would like to know where I can buy staples 804-809 for my Swingline Professional Saple Gun No. 10011
Hi,you can use any brand staples on your tool..
As an example here is a link on ebay for 5/16 staples..
Take care and please remember to rate me..Regards
Arrow 591188 300 Box 1/4"x5/16" Clear Insulated Stapleshttp://cgi.ebay.com/Arrow-591188-300-Box-1-4-x5-16-Clear-Insulated-Staples-/130360323235?pt=LH_DefaultDomain_0&hash=item1e5a14aca3
Nov 05, 2010 | Staples Swingline® 36115 Staple Guns Tools...
Directions for Arrow JT-21 staple gun
The jt 21 is that little red one, I have one in my shooting box, only takes the jt staples, and operates just like any staple gun. Feed it from the back.
Feb 20, 2010 | Hand Tools
How to put the staples
depress the handle enough to release the side catch on the stapler. now pull the bottom track down. insert a few rows of staples and snap the track back up into the stapler. the spring loaded follower goes in back of the staple stack.
Oct 20, 2009 | Arrow CHROME STAPLE GUN ARROW IND....
My jt 21m stapler is jammed and i cant get it to open
Jun 26, 2009 | Arrow Fastener Co. Lt Duty Staple Gun -...
Arrow Fastener Co. Lt Duty Staple Gun - JT21M Logo
46 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
