Question about Golds Gym R Cycle Trainer 290 C Exercise Bike
How do i use manual mode - Golds Gym R Cycle Trainer 290 C Exercise Bike
My sony DSC-H200 mode dial does work as it should if I turn it to 'M' or any other mode the led screen show a different mode, if I press down on the mode dial it correct itself.
M is for Manual Mode which allows to shoot manually adjusting the exposure settings. It gives you host of another option and as well as activates other options.
https://docs.sony.com/release/DSC-H200_guide_EN.pdf
As you mentioned that when you press down the mode dial it corrects itself, actually it goes back Intelligent mode. For in depth detail i am attaching a link of a pdf manual you will get all the info about modes.
Dec 04, 2016 | Sony Cameras
How to modify kenwood th234 from channel mode to vfo mode?
[PDF]Page 1 INSTRUCTION MANUAL KENWOOD ...
manual.kenwood.com/files/B62-0790-10.pdf
o Contains 60 memory channels programmable with desired frequencies and ... o Do not modify this transceiver unless instructed by this manual or by ... BASIC TRANSCEIVER MODES . ..... 1 Press [VFO] to select VFO mode. P1'I switch, and ...
[PDF]INSTRUCTION MANUAL - Kenwood
manual.kenwood.com/files/TH-D7-English.pdf
memory channel to be named using up to 8 ... Do not modify this transceiver unless instructed by ...... In VFO or Memory Recall mode, use the keypad to select a ...
Modifying the Kenwood TH-78a handheld transciever
www.welcomehome.org/rainbow/.../kenwood/kenwood-th78-mods.html
Nov 17, 1995 - (When William's early-model TH-78 was upgraded his mods (removed .... channel (if in memory recall mode) or last frequency (if in VFO mode).Missing: th234
Dec 21, 2015 | Phylrich Mirabella 3/4 Inch Thermostat,...
P0826 Nissan - Rogue 2009
P0826 Nissan - Manual Mode Switch Circuit
Possible causes: - Faulty Manual mode select switch (Built into control device, shifter)
- Faulty Manual mode position select switch (Built into control device, shifter)
- Faulty Control Device (Shifter)
- Control Device harness is open or shorted
- Control Device circuit poor electrical connection
When is the code detected? When an impossible pattern of switch signals is detected, a malfunction is detected.
Possible symptoms: - Engine Light ON (or Service Engine Soon Warning Light)
P0826 Nissan Description: Manual mode switch is installed in shift control device. The manual mode switch sends shift up and shift down switch signals to Transmission Control Module (TCM) with Control Area Network (CAN) communication.
TCM sends the switch signals to combination meter via CAN communication line. Then manual mode switch position is indicated on the shift position indicator.
P0826 Nissan Manual Mode Switch Circuit
May 31, 2015 | 2009 Nissan Rogue
I am trying to program or override settings set by our gas supplier for our remote for model 3002. I want to be able to turn it on and off manually and it not work by thermostat mode. Can't seem to...
Love the SkyTech Remote Controls. Been selling them for years.
To override the thermostat feature and go back to manual operation, press the MODE button twice. That will turn the burner OFF. To turn the burner ON in manual mode. just press the mode button once. Everything will remain in Manual Mode, until you change it back to Thermostat or Time mode.
The link below is to your Owners Manual, which you can download and print.
http://www.skytechsystem.com/editor/assets/installation%20files/3002%20Instructions%20SSI.pdf
Hope this helped you. Please be kind enough to let me know.
Rich
Mar 06, 2011 | Skytech 3002 Fireplace Remote Control with...
I need NOMA N1508 manual.
answer 1 Function and operation
1 - This timer has 3 working modes
a - Auto Mode(AU)
b - Auto and Temperature Control Mode (AC)
c - Manual Mode (LL)
Press "MODE" button and the LED display will cycle through these three modes.
2 - There is an output indicator light which turns Green (On all modes) and red (Off - manual mode)
3 - There is a bettery backup that can retain programs for about 1 week after power outage.
Operation
1 - On first use . Connect the unit to 125V AC power source. The LED display blinks 'C'. The unit at this moment is in initial state, where time and program need to be set.
2 - Press the "TIME" button, the LED display will now show "12.00", now the unit is entering time setting mode
a - The time interval for this product is 15 minutes
b - Press "TIME" button again. LED dislays 12:15 with each press of the time button the time increases by 15 minutes. If you press and hold the time button for 2 seconds the LED will increase rapidly.
c - After setting the time, press the enter button and the LED will display current time setting.
d - To change the clock press the "Enter" and the "TIME" buttons simultanously to enter the editing mode. Press the "TIME" button to adjust the time. Press the enter button to confirm
3 - To program press "mode" button once and the LED will display "AU" which stands for Auto Mode, press the "MODE" button once again and the LED will display "AC" which is the Auto and Temperature Control Mode. Press the "MODE" button once more and the LED will display "LL" which is Manual Mode. Press enter to confirm the selected mode. Press "MODE" button to role over these three options.
a - Auto Mode
Press "MODE" button and the unit will enter Auto Mode, LED displays "AU"
- Press "ENTER" button to confirm. LED displays "P". Press "TIME" button to set program ON time.
- After the program ON time is set press "ENTER" button to enter program ending time. LED will display "E". Press the "TIME" button to set the ending time.
- Press "ENTER" button to return to normal time display mode.
- The program indicator will be turned on after the ON time and ending time have been programmed
- Press the "TIME" button to review the program ON time setting and program ending time setting. The LED displays "P" and "E" respectively. After that the LED displays the current time.
- In case you want to modify the setting repeat step "a".
*** Note: When entering your program if no action takes place within 15 seconds it will go back to the time screen.
Press the "MODE" button and the LED will display "AU". Press the "MODE" button again and the LED will display "AC". press the "ENTER" button to confirm.
- The timer activates the load only when the folloewing two conditions are met:
1 The temperature is below -10
2 The program on time p is reached
For instructionsn on how to set the program ON time and the program ending time please refer to the Auto Mode fucntion
- The program indicator will be turned on after the ON time and the ending time have been programmed.
- When the program ending time is not yet reached, the load will be deactivated if the temperature rises above -7 and will be activated again if the temperature drops below -10. Once the prgram ending time is reached the load will be deactivated regardless of the temperature.
C - Manual Mode
Press the "MODE" button to select Manual Mode. When the LED displays "LL" press the "ENTER" to confim. The LED returns to show the current time. Press the "TIME" button to activate the timer the LEd will display ON. Press the "TIME" button again the LED will display off.
- In Manual Mode the output indicator will display red when the load is deactivated and green when activated.
- To exit manual mode press "TIME" and "MODE" buttons simultanously and the unit will return to Auto mode. The loading will be activated and deavtivated according to the previous setting.
4 Output indicator
1 - In Auto Mode ort Auto Temperature Control Mode when the loadind is deactivated the output indicator tunrs off.
2 - In Manual mode the outpur indicator turns red when loading is deactivated.
3 - In Manual Mode, Auto Mode and Auto Temperature Control Mode the output indicator turns green when the output is activated.
To reset all of your settigns including current time and programs, press and hold the "ENTER" button for 5 seconds from the "TIME" mode. answered 3 weeks, 2 days ago by Anonymous
Jan 11, 2011 | Sport & Outdoor - Others
400D manual mode
You are exposure compensation in manual mode. If you want the shots lighter, either open up the aperture or slow the shutter. The exposure compensation feature is to override the automatic settings determined by the camera in the auto-exposure modes.
Dec 05, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Alpine CDA-9833, how do you tune frequencies manually,
1 Press SOURCE/POWER until a radio frequencyappears in the display.
2 Press BAND/TEL. repeatedly until the desiredradio band is displayed.
FM1 FM2 AM FM1
3 Press TUNE/A.ME to select the tuning mode. (the play/pause
button above source/power)
Distance mode:
Both strong and weak stations will be automatically
tuned in
(Automatic Seek Tuning).
Local mode:Only strong stations will be automatically tuned in
(Automatic
Seek Tuning).
Manual mode:The frequency is manually tuned in steps
(Manual tuning).
select manual mode to tune it one by one.
Nov 29, 2008 | Alpine CDA-9833 CD Player
Aperture priority only in manual mode?
Yes. You pick the apature (the 3000 keeps it aorund the setting you pick) and then it automaticly adjusts the speed for you.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Should I use automatic or manual while recording?
Select RCA camcorders feature both an Automatic and a Manual recording mode. Automatic recording places the camcorder into Auto Shotâ„¢ mode. Focus, exposure, iris control, white balance, and the video light are controlled by the camcorder during Automatic recording. This mode is particularly handy for those times when you want to be able to just point the camera and record. The Manual recording mode allows you to control many of the elements above yourself, as well as many of the camcorder's special features including Animation and Time Lapse. Manual mode is also where you access the menus and set the clock. Make sure you press in the LOCK button while setting the POWER switch to the desired setting, either "A" (Automatic) or "M" (Manual) record mode.
Sep 06, 2005 | RCA CC-432 Camcorder
Focus modes
There are four focus modes: S-AF (Single auto focus), C-AF (Continuous auto focus), MF (Manual Focus), and S-AF/MF (Simultaneous mode). (SINGLE Auto Focus): Focusing is performed once when the shutter button is pressed halfway. C-AF (CONTINUOUS Auto Focus): The camera repeats focusing while the shutter button is pressed halfway. (MANUAL FOCUS): The function allows you to manually focus on any subject while looking through the viewfinder. SIMULTANEOUS USE of S-AF mode and MF mode: You can fine-adjust focus manually by turning the focus ring after AF is performed in the S-AF mode.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Golds Gym R Cycle Trainer 290 C Exercise Bike Logo
Top Golds Gym Exercise & Fitness Experts
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Propulsive
Level 1 Expert
Are you a Golds Gym Exercise and Fitnes Expert? Answer questions, earn points and help others
