Question about GE Kitchen Ranges
Xl44 pressure valve
GE XL44 Gas Stove and Oven. Everything works normal except the oven which stopped working suddenly (no flame). Couldn't find the manual to check troubleshooting guide.
The oven uses a silicone carbide ignitor which requires 3.6 amps or better to open the gas safety valve.
If you don't see any glow from it then it is either blown or the gas valve has gone bad. If it is glowing but not real bright it probably is weak.
How it works: Silicone Carbide Ignition
XL44 gas stove manual
Jan 25, 2011 | GE Ovens
GE XL44 oven won't turn off. Knob off and pin is loose
My GE XL44 oven would not shut off and it turned out to be a worn out thermostat for the oven. I have written up a step-by-step tutorial on how to replace the thermostat on my blog: John Fixes Stuff GE XL44 Oven Will Not Turn Off How To Replace Oven...
Jan 17, 2010 | GE Kitchen Ranges
Natural Gas to Propane for Ge xl44 Gas range
The kit is located at the rear of the range right near the gas valve, there are probably 5 spuds and an extender for the large burner, directions are with the range. For the bake and broil you will need to tighten the brass orifice nuts down as tight as possible, also the brass nut on the gas valve needs to be reversed
your local LP dealer should be able to do this for you if you are uncomfortable doing it yourself.
Jan 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
MISSING PART OF MY XL44 OVEN
Hello, ammar738
Welcome to Fixya,
YOU SAID, YOU WANT TO BUY OVEN SAFETY VALVE, DUAL TYPE. BUT THE PROBLEM IT IS NOT IN MY COUNTRY (YEMEN) FORM WHERE I CAN BUY IT? INF: GE XL44 MODEL NO.JGBP28BEA2WH PLEASE HELP.
Below is the web site of one of our sponsors.
I'm pretty sure you can buy it online from them and have them mail or ship it to you. So tell them you pay the shipping.
Give them a try.
Let me know that you are successful
If not I'll find someone who will ship to you. If you have the part number it may help me search if these
people will not ship to you.
Parts house
www.RepairClinic.com
Huuum
Please remember to leave a rating when you are done.
Shookran
Oct 06, 2008 | GE JGBP24 Gas Kitchen Range
GE oven XL44
True, the flame must be short and blue, the valve is releasing the gas with far two much pressure. The oven as it is now is dangerous, do not turn it on. Being it a gas oven, safety issues are involved, you should be inspected by a qualified technician.
May 20, 2008 | GE JGBP28 Gas Kitchen Range
Top works bottom doesn't
I have XL44 oven JGBP26. I replaced the glow ignitore on the oven but still will not glow. I carfully tested the current to the ignitore and showed 125 volts, I also tested the resistance on the control valve lead and to ignitore and showed 1100.
Dec 15, 2007 | GE JGBP28 Gas Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
