Question about Samsung DLP HL-P5663W 56" TV
I have a samsung dlp 50" model # hln5065xxa. After an hour or so the screen starts flashing in different areas in which makes the people on tv to look negative
    Guru:
  • 114 Answers
Do you have a picture so i can see better?
its to hard o tell you what is wrong because i don't have a lot of info..
maybe its the digital board.
try to go on your tv menu and let me know if it displays fine?
Posted on Feb 09, 2010
I have a 50" Phillips
Check ur owner manual or call Philip support Tech. ask it this tv model have a colors wheel design into it tv.Not sure for a Philip model tv 50" DLP tv,but the Samsung model 50" DLP tv this problems alway causes by a dying colors wheel that design into it tv.Which the colors wheel it is warp worn out and spinning off of it motor mount axis to cause grinding noises and tv colors to mess up and flashes or have flashes Black & White within it picture.
Jun 07, 2011 | Philips 50PL9126D/37B 50" DLP TV
I have a 50" samsung
Check the Fans make sure they are not dirty ,if they are clean them,Fan2 error means something is wrong with Fan2#
Nov 02, 2010 | Samsung HL-S5086W 50" HDTV
Samsung, DLP TV 50 inches Model # HL-T5075X/XAA
Samsung just told me they wouldn't fix my tv because it was produced in Nov. of '06 and the only ones they would fix were made in August of '06 or earlier. I am way too angry right now to call the service tech number they so very nicely provided.
May 19, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung HLP5674W DLP television shuts off after a few minutes
Make sure the color wheel is ok. If it is, replace lamp and ballast.
Dec 10, 2009 | Samsung HLP5085W 50" Rear Projection...
Samsung Model HLR4667WAX/XAA is making a buzzing sound
This TV is horrible. I have the same one and not even a year replaced the light bulb twice. Very disappointing for a Samsung.
Sep 21, 2009 | Samsung DLP HL-P5663W 56" TV
Numerous white spots on Smasung DLP TV
If your Mitsubishi TV has white spots in the picture , you can call Mitsubishi @ 1-800-332-2119 and request a free DLP Chip to fix the problem. They will send the New DLP Chip at no charge to a TV Tech in your area to install it for $200 flat rate. That is about a $250 savings if you had to pay for the chip . Call them with your TV's Model number and serial number and let them know when and where you bought the TV.
It saved me some hard earned money and now my TV is like New !
May 02, 2009 | Samsung 50" Slim-Depth DLP HDTV
See link below for "field of stars" fix:
http://www.avsforum.com/avs-vb/showthread.php?t=1107926
Worked a charm on my 50" Samsung DLP. Read thread carefully as there are 2 different version of the DMD chip you will need to replace. I ended up fixing mine for less than $165!
Chuck
Feb 07, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
50? Samsung DLP TV Model #HLR-5067W
Did you use an original replacement lamp or an aftermarket replacement? From the price you give, it sounds like an aftermarket lamp, which are notoriously buggy and the problem may be with the lamp. If not, the lamp driver is your next likely culprit. It is also called a lamp power supply or lamp ballast.
Oct 19, 2008 | Samsung DLP HL-P5663W 56" TV
Please Help!! Black Screen, Red Light Flashing
is this a plasma or a dlp tv? if is a dlp a have bad news for you get rid of the tv, if is a plasma then is something different, post the model # anyway to see if we can help you.
caypianan@yahoo.com
Aug 24, 2008 | Samsung FPT5084 50 in. Plasma HDTV
Dlp vertical lines
the person you talked to at samsung is more than likely a customer support rep that does know anything but what his computer tells him. i have seen this symptom several times in many makes and models. if you can give me your full model number i will give you a part number to fix this issue.
Oct 24, 2007 | Samsung HLN5065W 50" Rear Projection...
Samsung DLP HL-P5663W 56" TV Logo
197 people viewed this question
Jerry Greenberg
Jerry Greenberg
