Question about HP Pavilion A730N (PJ510AA) PC Desktop
Usb ports on the front not working how to fix it
Computer freeze when inserting flash drive why?
cgpatel1948
  • 258 Answers
SOURCE: FREEZING WHEN TRYING TO USE USB PORTS
USB ports is not configured properly
Posted on Jul 28, 2008
myrlex
  • 674 Answers
SOURCE: all 4 usb ports failed on my hp pavillion
CHANGE THE USB PORT OR CHECK THE CHIP OF USB.. MAYBE SOME DAMAGE OR BURN FROM THEM.. AND NEED TO CHANGE IT...
Posted on Jun 25, 2009
Amith DSilva
  • 34 Answers
SOURCE: Accessing my USB drives
Since you have purchased your notebook yesterday don't take any chances and just give the notebook to the place from where you brought it
Posted on Aug 22, 2009
amit1goswami
  • 81 Answers
SOURCE: USB port unrecognized
disable the usb roots hubs from the device manager and restart the sys and then insert the thumb drives it should work out.
Posted on Feb 04, 2010
  • 497 Answers
SOURCE: the usb ports won't work on my hp pavilion dv4000.
TWO THINGS.. 1) open device manager and look to see if its listed there. If not, go to step 2. If its listed, at top click VIEW and choose "show hidden devices". Uninstall any devices that are currently listed and installed. Close and restart.
2) Go to http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodClassId=-1&prodTypeId=321957&prodSeriesId=453246 to download the current Updates for your system. That should solve your problem. By the way it would be a good idea to update your system on any account. Always a good idea!! :) GREAT LUCK!! Please rate me , k? Thank You- Lucky4lynn2
Posted on Mar 06, 2010
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to install a USB flash drive
Just plug your USB flash drive into the USB port of your computer or other USB-equipped device and drag the files you want to take with you into the folder that appears on your screen. Your files are instantly transferred to your USB flash drive. To transfer the items on your USB flash drive onto another computer, simply plug your USB flash drive into the computer that you want the files transferred to, open the folder that appears on your screen, and drag the desired files onto the computer's desktop.
1.) Insert Flash Drive into the USB Port of your computer.
-Where is my USB port? It is usually found in newer model computers in a hidden compartment on the front of the hard drive and in the back of the hard drive on older computers. The port for laptops is found on the side or back of the computer.
2.) Wait for the hardware to automatically install on your computer.
After the hardware is installed, it is ready to use!
3.) In most cases, an Options Window will automatically open. Select "Open folder to view files" Click "OK."
Jul 19, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I cannot get a SanDisk flashdrive to go into either of the USB ports on my new desktop computer. I am using the USB ports located on top of the computer
To test the functionality of the usb ports in front of the computer
1. Insert another flash drive or another usb device like a usb mouse on front the computer 2. If it detect the usb device that means 2 things flash drive might be bad and the front usb port is working 3. If it does not, It means that the flash drive might be bad or the usb port is not connected to the front panel of the computer 4. Try also inserting the flash drive at the back of the computer see if the usb drive is detected in all ports 5. Check the BIOS for any usb port associativity
Jul 05, 2011 | HP Computers & Internet
I have a Lacie mosKeyto 8GB USB Flash Drive. When it it inserted into a PC it just does not show up at all, meaning computers do not detect it. What can I do? thanks
hi have you try connect it to other computer? if is working i guess your usb port have problem try to connect your flash drive to other usb port at the back your cpu. if not working your usb flash drive have problem. thanks
May 28, 2011 | LaCie MosKeyto - USB Flash Drive - 16GB...
How do i go about hooking up a cruzer usb 2.0 flash drive to my computer
insert the usb flash drive into a usb port can be at the rear and front of a dessktop once inserted you will see a notice on the screen a new device has been added to your computer
hope this helps
Mar 23, 2011 | Computers & Internet
Computer freezes after inserting usb stick
if you are inserting it in front panel then try using it in other ports at the back if the it still hangs your system try usb stick in other pc....if it works well in other pc then you need to install chipset driver and usb driver....
Nov 17, 2009 | AOpen i915Gm-PL (918EM10I13) Motherboard
Flash drive ports on teh fron wont work on pc
If your system is USB 1 rather than USB 2 then some flash drives will not work. Not all usb 2 flashdrives are backwards compatible. My kids flasdrives will only work on my usb2 ports & will not work at all on my wife's computer which has the older usb 1 ports.
Dec 19, 2008 | E-Machines etower 500is PC Desktop
I have a 1g Lexar usb key it doesn't work. My computer doesn't reconise it plus the light on the key doesn't flash anymore... pls help as i have my good photo's on it
It could be your USB port that's not working. Try inserting your flash drive into a different USB port. It is possible that the line connecting the USB port was accidentally removed or loosened inside your CPU. You can also try opening your CPU and fix the connections of the front panel wires to the motheboard.
Sep 23, 2008 | Computers & Internet
Driver
For any computer there will be at least 4 usb ports. 2 at the front and other 2 at the back side of cpu. If any one is not recognizing then insert it in different usb port. If any of the port is not working then install the driver for your usb port. Download the usb driver from the below link.
http://global.msi.com.tw/index.php?func=downloadindex
Thank you......
Sep 13, 2008 | Intel Motherboard
Usb flash pen drive
Often it is due to electrostatic charges on usb. Unplug all USBs.Unplug PC from power cable for 10/15/ minutes. plug back computer to power outlet and restart. Plug back usb.
If it still does not work , flash memory may be faulty, test it on a different computer.
Mar 17, 2008 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
HP Pavilion A730N (PJ510AA) PC Desktop Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
