Question about Dell PowerEdge 2600 Server
Usb cd boot
I am trying to boot from a USB attached CD. The internal CD is broken. Any ideas, anyone?
  • 212 Answers
You need to set the boot device priority in the BIOS in such a way that the computer will take an external CD/DVD-drive as first boot device. to do this, you need to enable USB legacy support first, save and exit from the BIOS settings and then return to the BIOS to set the USB-CD/DVD-drive as primary boot device.
Posted on Jun 22, 2009
Trying to reboot my PC
There is some posibilities that generate that error, this is some of them :
1. Your Hardisk error, your bootable psrtition is corrupt or something, can be caused by not properly shutdown, repair OS with CD recovery may help you.
2. Your hardisk is fine, but you attached new non bootable hardisk, if yes, you may need to change boot order on bios.
3. You attached USB FLASHDISK, or USB Hardisk, try to remove that and rebot your komputer.
Oct 29, 2017 | Computers & Internet
Can't boot from cd
go back and put the first boot as the internal hard drive
when that is done , insert the cd in a cd unit and auto run the cd
what ever you have will download onto the pc hard drive
Nov 27, 2017 | Dell OptiPlex 360 Desktop Computer
My emachines e350 won`t turn on it alweys says No bootable device--Please restart systam and I do that and it says it again
Check that you have not left a non-bootable CD, diskette, or DVD in the drives of your PC, nor have any USB devices plugged in that the system might be looking to try to boot from.
If the above check is clear, then go into the BIOS settings and check that your internal hard disk drive is set as the first boot device or is ahead of any other disk drives you may have installed.
You cannot connect computers to each other by just using a standard USB cable - it doesn't work that way.
If you still cannot boot from your internal hard drive, then you should consider downloading a copy of Hiren's Boot CD (which is a CD .ISO image) then burn this to a real CD and try booting from that media - you may have to select the CD as a boot device in your BIOS or if you get a boot options menu.
If you can boot the Hiren's CD ok, then your internal hard disk may have failed - you can test this with the DOS Programs of the Hiren's CD by selecting Hard Disk tools then selecting HDAT2 which will try to find any installed hard disks then allow you to test these and repair problems if possible.
Jan 01, 2012 | Computers & Internet
The screen says: "Intel UNDI , PXE-2.1 (buld 082) For Realtek RTL8101E/8102E PCI-E Ethernet Controller v1.06 (080225) CLIENT MAC ADDR: 00 03 0D A0 C7 C7 GUID:...
Your computer tries to "boot" from various devices:
* internal disk-drive
* internal CD/DVD drive
* internal 3.5" drive
* external USB device (memory stick, external CD drive, et cetera)
* via your network-adapter -- trying to connect to a "boot-server"
So, restart your computer, and enter BIOS SETUP mode.
Be sure that the disk-drive *IS* listed.
If you want, exclude the "network" boot-device,
since the error-messages that you are seeing are indicating that *NO* boot-server exists on your network.
What the messages *COULD* imply is that there is no media in the CD/DVD drive,
no media in the 3.5" drive, nothing "bootable" connected via a USB port,
*AND* that your computer *TRIED* but *FAILED* to boot from your disk-drive.
That is, your disk-drive either is electrically disconnected (no power reaching it)
or electronically disconnected (the "data" cable is not attached)
or that the disk-drive itself is "dead".
Take your computer to a qualified technician for trouble-shooting.
You may have to replace the "dead" disk-drive with a brand-new one.
Oct 10, 2010 | Computers & Internet
Usb dvd writer can install xp?
Yes you can use a usb external cd/dvd-rom to any operating system as long as the bios allows you to, most bios's have the capability.
When the external usb drive has been connected power up the mechine, in post it should tell what to press to enter your boot menu without entering your bios and choose usb drive to boot.
Jan 22, 2010 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Toshiba A50 Not able to boot from CD
When you load the cd and reboot, when you see the toshiba screen, start tapping F12, see if this brings up the temporary boot menu, if it does choose the cd and watch closely for "press any key". If there is nothing showing, might I suggest you get an external cd drive that attaches by usb. You will then have to get back to the BIOS and set the usb as your first boot device and try to boot again from the usb cd drive. Good luck.
Oct 08, 2009 | Toshiba Sattelite A105-S2071 Notebook
I can't boot from external usb dvd/cd drive
please try to remove the connection between motherboard and vd/dvd drive.
then perform the previous steps.
Jan 27, 2009 | HP Compaq Evo Notebook N1020v PC Notebook
I don´t have internal cd, only external(usb)
You will need an internal CD drive for the machine in order to load XP. If it doesn't recognize the external in the boot menu, then there is no setting to get it to.
Jul 23, 2008 | IBM ThinkPad 600E 2645 Notebook
Non-system disk or disk error - Remove disks or other media.
YEAH
SET THE LAPTOP TO BOOT FROM USB or what ever connection you are using to conect the external drive to the laptop. setting it to boot from cd will look for an internal drive
to boot from the external drive you need to set it to boot from usb
Jan 09, 2008 | Compaq Evo N410C Notebook
Panasonic Toughbook CF-27
i need help i have a panasonic cf-27 toughbook with a usb cd drive and usb floppy drive ive tried both seperate and with a multi usb connector to boot both but it doesnt find them can anyone help me?
Oct 26, 2007 | Panasonic Toughbook CF-27 Notebook
Dell PowerEdge 2600 Server Logo
1,891 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
