Question about Garden
Starter turns over fast, battery fully charged, z445 mower won't start,is there a carbuerator problem?
thabrain
  • 76 Answers
SOURCE: murray riding lawn mower
with switch off try crossing out the solenoid. take an old screwdriver and place it on the two metal contacts jetting out from the solenoid usually by the battery or close to the ignition. if strarter engages when this is donr replace solenoid. if not replace starter. hope this helps.
Posted on Oct 28, 2008
  • 3 Answers
SOURCE: MURRAY AUTOMATIC DRIVE, 42
Your problem could be caused because your valves are not set properly (they vibrate loose sometimes. Remove your spark plug and try to crank theengine...If it turns freely with the pulug out, reset your valves..be sure to obtain the proper spacing (gap). Hope this helps
Posted on May 06, 2009
  • 57 Answers
SOURCE: Murray 17.5 HP mower - no noise when turning key? Maybe ignition?
Look near the starter solenoid for a fuse. It is probably under the hood near the steering column. If fuse is good, problem is likely a safety switch.
Posted on May 19, 2009
  • 62 Answers
SOURCE: Key start on lawn mower does not work
Check your starter fuse..follow ignition wire to starter..there is a fusable link inline. make sure u have power all throughh line to starter. :)
Posted on Sep 07, 2009
SOURCE: rally ride on lawn mower not starting. briggs and
i have a rally lawn tractor when i hook up the battery it wants to start key is off only thing i did was change the belt. was working fine before .
Posted on Jul 29, 2010
My 18 ova green fields mower fast cut starter motor won't turn engine over fast enough to start it
First check connections at battery solenoid and starter.Try jumping with another battery if it works check alternator to make sure it is charging battery and if it is replace battery
Sep 09, 2017 | Fast Garden
How to take a starter off a eztrak z445 zero turn
this is the starter motor
chase the positive wire from the battery to find the starter
much the same as a car starter could be horizontal
held on by two bolts
Jul 04, 2016 | Garden
Riding mower won't start & makes clicking sound when I turn key over
MAKE SURE BATTERY IS CHARGED IF IS THEN JUMP LAWN MOWER AT STARTER IF STARTS BAD BATTERY ARE STARTER RELAY COST 60.00 I STILL THINK YOUR BATTERY IS BAD OR DEAD NOT ENOUGH CHARGE IN IT
Sep 01, 2014 | Garden
Ariens rideing lawn mower turns over but wont turn over fast enough please help
if your battery is fully charged, then the problem may be the starter its self.could be worn bushings in the starter.
Nov 11, 2013 | Garden
My poulan pro lawn tractor won't start. when i turn the key it click's 1 time can you help ?
Have you checked the battery terminal connections? Is the battery charged fully? Are you sitting on the seat when you try to crank the mower? Could be any of the above but most likely battery connection or the battery is discharged or old.
Aug 20, 2012 | Poulan Pro Lawn Tractor 2006 and Newer...
Why won't my starter turn my engine fast enough on
bypass the battery cables with jumper cables if there bad they will not carry the amps needed to crank it
Apr 23, 2012 | Briggs & Stratton Garden
When turning ignition key to start engine the flywheel only turns 1/4 around and then stops when starting motor.
From experience I would suspect a broken decompressor lever on the camshaft. A battery fails very fast when starter comes to a dead stop a few times. Try a fully charged battery but if the problem comes straight back I'd bet on the camshaft. A car battery can usually push the engine over the excess compression.If it is the decompressor engine has to be taken apart.
Feb 01, 2012 | Craftsman 18.5 HP 42"
MURRAY AUTOMATIC DRIVE, 42" CUT, 17HP, TWINII,MODEL 42A707,TYPE 2653E1,CODE 9710235B. Battery fully charged,starter will not turn fast enough to start engine. acts as tho there is a presure build up....
Dropped / Stuck valve?
Major Overheat?
Battery weak (understand it is fully charged... but is it delivering proper amperage under load?)
bad connections betwixt battery and solenoid, then solenoid to starter?
Weak starter motor?
Mar 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
11 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
