Question about Nady Systems XA-900 Amplifier
Cooling fan right channel do not turn on when amp is operating
    Sergeant:
  • 238 Answers
If the fan is thermally controlled then either that channel is not heating up enough to turn the fan on or either the fan or thermal switch has malfunctioned. The first thing I would try is to swap the fans. If the problem moves with the fan, then the switch is the most likely culprit. The fans are probably termally controlled so that they are not energized when the volume is low to reduce background noise.
Posted on Jun 13, 2014
2 Suggested Answers
  • 6771 Answers
SOURCE: My Nady xa-900 shut off during performance with no prior indication of problems. Now it will not turn on, no lights or anything. I have two of these amps. One was running Hi Packs, and the other 18
The amp top should be removed to check any fuses and the power transformer, a digital meter will be needed to run these tests, post back for instructions if you have one.
Posted on Jul 09, 2012
How to get sound from a nady audio 4130 mpm 4 channel power mixer
First, plug it in. Next connect the speakers. Center all eq controls both master and channel. Turn off any reverb or effects. Turn the master volume 1/2 way up. Plug a sound source into channel 1 wiyj the channel volume all the way off. Turn on the amp. Slowly raise the channel volume until you heat output. If you get nothing, it's broken.
Nov 10, 2016 | Nady Systems Music
There are a couple reasons.
(a). If it's a regular older model Solid-state Amplifier, reason could be a faulty cooling fan.
(b). If it's a more recent Amplifier, reason could be a faulty Temperature Sensor attached to the heat-sink. A faulty fan could be the culprit as well.
May 05, 2014 | Nady Systems XA-900 Amplifier
Power amplifiers cooling fans
If they r thermally activated.. Let amp heat up then check to c...if not thermal power switch for fans may b faulty if not fans themselves..
Mixer to P.A. system connection
You'll want to use the Stereo Out connections at the top right. You might need adapters to plug into whatever system you're trying to use. Also note that this mixer does not provide power, so the speakers you're using have to be self-powered or be driven by a separate amplifier. You would then plug the Stereo Out connections into the INPUTs of the amplifier.
Jun 28, 2013 | Nady Systems Nady SRM-10X 10-Input Mixer
Jul 08, 2012 | Nady Systems XA-900 Amplifier
How to know the serial number of output of nady pmixer 420
Serial #s are usually on the rear or bottom of the device. # of outputs- 2 subs & Mains L&R= 4
you can find the manual below.
http://nady.com/manuals/audio/pmx420.pdf
Good Luck mixing the Next Big Hit!!
Aug 31, 2011 | Nady Systems SPA 2400 Amplifier
Broke the antenna off my Encore II . Where can I get parts?
Contact Nady directly at the number below. They will help with the part number and cost etc.
Dan
Contact: Customer Service Department at (510) 652-2411.
May 21, 2011 | Nady Systems Nady Encore II GT Wireless...
Cant figure out why my protect LED indicators continue to go on.. Why is this happening?
disconnect speakers at the amp, turn unit on, if it goes into protect, it needs service. If it stays on, re-connect speaker wires without speakers attatched at the other side and test again. (make sure wires are separated and not touching metal!) if it stays on still, check speakers one by one, when it goes into protection, you have found your problem. Disconnect the bad speaker and test again. Process of elimination. It can only be one of three things. Internal amp problem(nothing connected and protection) wires(no speakers connected and protection) or speaker(s) (when speaker connected,protection) Hope this helps. If you need deeper troubleshooting with this issue, post a comment and I can help you further.
Nov 04, 2009 | Nady Systems XA-900 Amplifier
Nady 850 amplifier problem
check your speakers cables for short circuit-disconnect all speakers and connect them one by one until you find the bad one and when you find it try the cable first then the speaker -if all above failed you will have a problem in your amp and ask for help from service center
Jul 07, 2008 | Nady Systems SPA 850 Amplifier
Nady Systems XA-900 Amplifier Logo
80 people viewed this question
Top Nady Systems Audio Players & Recorders Experts
Michial Gueffroy
Corey Bartlett
Level 1 Expert
Robert Graf
Are you a Nady Systems Audio Player and Recorder Expert? Answer questions, earn points and help others
