Question about PixiModo Photography
Unit wont turn on. it has power, but the display won turn on
Unit wont turn on.
try test the remote using cellphone camera.hold remote facing the camera lense as if u taking a photo. you should see wht appears to be a flashing light when pressing any key on the remote. should you see no flashing i would say the remote is faulty.
Oct 05, 2015 | Heating & Cooling
Lock on display wont power up
What is the make and model number?
May 24, 2013 | Dishwashers
Won't switch on. Display - switch off camera and turn on again.
This is in a service loop and will not stop until the unit is repaired,
Jan 20, 2013 | FUJIFILM FinePix S2500HD Digital Camera
Password reset
Procedure 2.3 - Accessing the User Parameter Program
This procedure allows you to change the following settings:
• Set Measurement Units
• Enable/Disable Password
• Set User Name
Procedure
1. Plug the power cord into the wall outlet, then turn on the treadmill with the circuit breaker.
2. Press keys STOP,5,6,7,1 sequentially.
3. The display will momentarily read SELECT UNITS
4. The currently selected measurement unit will then be displayed.
5. Use the UP, DOWN arrow keys to toggle between U.S. STANDARD and METRIC.
6. Press the ENTER key to select the currently displayed measurement unit.
7. The display will momentarily read, PASSWORD
8. Use the UP, DOWN arrow keys to select either PASSWORD ENABLED or PASSWORD DISABLED
9. Press the STOP or ENTER key to exit the program.
Aug 24, 2012 | Precor 9.31 Treadmill
DOES mr935650 CAR rADIO/cD PLAYER HAVE AN INTERNAL FUSE?
I know its a little but I had same problem with mine power to unit but wont turn on.
I removed the stero removed the plug then hold down the button with return writte under it ( I think its number 3) then plug it back in. as far as the unlock code If the car is registared i8n your name ring Misibishi with thye VIN number they should be able to help you out.
Jun 09, 2012 | Cars & Trucks
My toshiba nb 305 wont start up, do you have any idea why? i was typing when suddenly it turn off, i tried to to turn it on but only the "on" button will power up but the screen wont start. after...
@fitz_quinto
Try to do the following:
1. Remove the battery
2. Press and Hold the power button for 20secs (this will drain the power out of the computer)
3. Insert the AC adapter and turn the unit ON
If the above procedure won't work, this is a sign that the computer's motherboard might have gone bad and you need to have the unit serviced. If you're still under warranty, call 1-800-457-7777 (for US) and 1-800-663-0378 (for Canada).
Good luck.
Sep 11, 2011 | Toshiba NB205-N210 Netbook
DVD player won't eject and an u99 error code is displayed.
Hello
It is an internal circuit problem.
The unit fails to operate properly. Press [POWER] on the main unit to switch the unit to
standby. Now press [POWER] on the main unit again to turn the unit on.
OK
Jun 10, 2011 | Panasonic DMRES30V DVD Recorder/VCR Combo
Water won drain. stuckin last wash cycle and it
sounds like your pump is jammed,or faulty.remove water from unit by hand pull away from wall about 2ft tip unit back so u can look underneath. to the right hand front of the unit u will see a red or black fan on the pump, turn that fan clockwise and anticlockwise to unjam pump if it is jammed.fan should turn easily.please turn off power b4 u work on it, dont want any accidents. when u have done this put unit back level, turn power on select spin and start. please reply 4 more help
Mar 11, 2010 | Fisher and Paykel IWL12 Top Load Washer
Sound without picture unit did not go thru auto set up input will not display
returned defective unit to the store after talking to them and determining the menu would not display.
Jan 01, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
My Acer Aspire 5920 won t turn on The battery light blinks but it is plugged up
try pressing on fn+f5 or fn+f6 a couple of times each. Maybe the screen got switched to projector status by mistake.
Jan 07, 2009 | Acer Aspire 5920-6727 Notebook
Photography Logo
60 people viewed this question
Top PixiModo Photography Experts
Tony
Are you a PixiModo Photography Expert? Answer questions, earn points and help others
